查看: 1632|回复: 0
[原创] uboot 官方帮助文档 -- 移植手册部分
  • 签到天数: 597 天
    发表于 2019-5-27 22:25:31 | 显示全部楼层 |阅读模式
    uboot  READER 文档,关于如何移植,一共只有两部分信息,截取出来,第一部分如下:
    1. If the system board that you have is not listed, then you will need
    2. to port U-Boot to your hardware platform. To do this, follow these
    3. steps:
    4. 1.  Create a new directory to hold your board specific code. Add any
    5.     files you need. In your board directory, you will need at least
    6.     the "Makefile" and a "<board>.c".
    7. 2.  Create a new configuration file "include/configs/<board>.h" for
    8.     your board.
    9. 3.  If you're porting U-Boot to a new CPU, then also create a new
    10.     directory to hold your CPU specific code. Add any files you need.
    11. 4.  Run "make <board>_defconfig" with your new name.
    12. 5.  Type "make", and you should get a working "u-boot.srec" file
    13.     to be installed on your target system.
    14. 6.  Debug and solve any problems that might arise.
    15.     [Of course, this last step is much harder than it sounds.]
    第二部分如下:典型的 c 代码,我加了注释:
    1. U-Boot Porting Guide:
    2. ----------------------
    3. [Based on messages by Jerry Van Baren in the U-Boot-Users mailing
    4. list, October 2002]
    5. int main(int argc, char *argv[])
    6. {
    7.         sighandler_t no_more_time;
    8.         signal(SIGALRM, no_more_time);
    9.         alarm(PROJECT_DEADLINE - toSec (3 * WEEK));
    10.         if (available_money > available_manpower) {
    11.                 Pay consultant to port U-Boot;
    12.                 return 0;
    13.         }
    14.         Download latest U-Boot source;                                     # 下载源码
    15.         Subscribe to u-boot mailing list;                                  # 订阅邮件
    16.         if (clueless)
    17.                 email("Hi, I am new to U-Boot, how do I get started?");
    18.         while (learning) {
    19.                 Read the README file in the top level directory;               # 读文档
    20.                 Read http://www.denx.de/twiki/bin/view/DULG/Manual;
    21.                 Read applicable doc/*.README;
    22.                 Read the source, Luke;
    23.                 /* find . -name "*.[chS]" | xargs grep -i <keyword> */
    24.         }
    25.         if (available_money > toLocalCurrency ($2500))
    26.                 Buy a BDI3000;
    27.         else
    28.                 Add a lot of aggravation and time;
    29.         if (a similar board exists) {        /* hopefully... */
    30.                 cp -a board/<similar> board/<myboard>                           # 创建板子
    31.                 cp include/configs/<similar>.h include/configs/<myboard>.h      # 创建配置
    32.         } else {
    33.                 Create your own board support subdirectory;
    34.                 Create your own board include/configs/<myboard>.h file;
    35.         }
    36.         Edit new board/<myboard> files                                      # 编辑文件
    37.         Edit new include/configs/<myboard>.h                                # 编辑配置
    38.         while (!accepted) {
    39.                 while (!running) {
    40.                         do {
    41.                                 Add / modify source code;                               # 改源码先编译通过
    42.                         } until (compiles);
    43.                         Debug;
    44.                         if (clueless)
    45.                                 email("Hi, I am having problems...");
    46.                 }                                                               # 改源码运行起来
    47.                 Send patch file to the U-Boot email list;
    48.                 if (reasonable critiques)
    49.                         Incorporate improvements from email list code review;
    50.                 else
    51.                         Defend code as written;
    52.         }        # 改源码直到自己满意
    53.         return 0;
    54. }
    55. void no_more_time (int sig)
    56. {
    57.       hire_a_guru();
    58. }
    两部分都是笼统的讲了一下,其实两部分的内容是一样的,第一部分还详细点,第二部分代入了工作场景。
    大牛看一看就知道怎么移植,小鸟看了跟没看一样,还是云里雾里。
    其实这个移植指导手册也对,只是太笼统了,细节一点没有,需要对 uboot 代码和结构等等都很熟悉,并且对单板也很熟悉,这样就容易移植了。
    官方移植文档就这么多信息,剩下的我来慢慢写,可能很久也写不完,但是不是特别特别详细的话,也很快。所以还是需要有基础。但是门槛肯定比 uboot 官方的门槛低得多了。
    以下是本人读 uboot 做的笔记,原汁原味,内容还是比较多,后续整理发帖出来可能还没有笔记全。
    https://github.com/robe-zhang/mys_y6ulx/tree/master/note_robe/note_uboot
    GMT+8, 2025-1-12 23:18 , Processed in 0.119874 second(s), 15 queries , MemCache On.
