查看: 3464|回复: 0
Arduino UNO、LCD1602、DS1307制作带日历星期的数字时钟
  • 签到天数: 313 天
    发表于 2018-4-17 08:52:51 | 显示全部楼层 |阅读模式
    下面介绍使用Arduino UNO、LCD1602、DS1307制作带日历星期的数字时钟
    硬件连接:
    DS1307模块的SDA SCL连接Arduino UNO数字输入输出上面一排的SDA SCL,DS1307的VCC GND连接Arduino UNO的ICSP的VCC GND
    ICSP排针排列如下
    LCD1602的VCC GND SDA SCL连接到Arduino UNO的5V GND A4 A5
    连接好之后上电,打开Arduino IDE,打开项目--加载库--管理库,搜索安装rtllib库
    如果之前没有安装过LiquidCrystal_I2C库还需要安装这个,安装完成后新建sketch,输入下面代码
    #include <Wire.h>#include <RTClib.h>#include <LiquidCrystal_I2C.h>LiquidCrystal_I2C lcd(0x3F,16,2);RTC_DS1307 RTC;char daysOfTheWeek[7][12] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};void setup () {    Serial.begin(9600);    lcd.init();    lcd.backlight();    Wire.begin();    RTC.begin();    RTC.adjust(DateTime(__DATE__, __TIME__));  }void loop () {      DateTime now = RTC.now();        Serial.print(now.year(), DEC);    Serial.print('-');    Serial.print(now.month(), DEC);    Serial.print('-');    Serial.print(now.day(), DEC);    Serial.print(' ');    Serial.print(now.hour(), DEC);    Serial.print(':');    Serial.print(now.minute(), DEC);    Serial.print(':');    Serial.print(now.second(), DEC);    Serial.print(' ');    Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);    Serial.println();        lcd.setCursor(0,0);    lcd.print(now.year(), DEC);    lcd.print('-');    lcd.print(now.month(), DEC);    lcd.print('-');    lcd.print(now.day(), DEC);    lcd.print(' ');    lcd.print(daysOfTheWeek[now.dayOfTheWeek()]);    lcd.setCursor(0,1);    lcd.print(now.hour(), DEC);    lcd.print(':');    lcd.print(now.minute(), DEC);    lcd.print(':');    lcd.print(now.second(), DEC);    lcd.print(' ');    delay(1000);}
    上传后效果如下
    GMT+8, 2024-12-20 15:13 , Processed in 0.121291 second(s), 18 queries , MemCache On.
