查看: 4339|回复: 0
Khadas VIM2 Basic串口诊断教程
  • 签到天数: 313 天
    发表于 2018-2-5 09:12:31 | 显示全部楼层 |阅读模式
    Khadas VIM2 Basic的诊断串口在40针GPIO上,GPIO定义如下
    使用串口线GND TX RX分别连接Pin17 Pin18 Pin19,打开串口终端软件,然后设置串口线串口号、波特率115200后给开发板上电,开发板启动后开始打印信息
    可以看到是双通道DDR4,内存每个1024MB,CPU主频1.2Ghz
    默认加载驱动模块如下
    内存、闪存、SWAP分区信息如下
    CPU信息如下
    启动串口诊断信息如下
    GXM:BL1:dc8b51:76f1a5;FEAT:ADFC318C:0OC:3;RCY:0;EMMC:0;READ:0;0.0;CHK:0;TE: 100896BL2 Built : 11:58:42, May 27 2017.gxl gc3c9a84 - xiaobo.gu@droid05
    set vdd cpu_a to 1120 mvset vdd cpu_b to 1050 mvset vddee to 1000 mvBoard ID = 6CPU clk: 1200MHzDQS-corr enabledDDR scramble enabledDDR4 chl: Rank0+1 @ 1008MHzRank0: 1024MB(auto)-2T-18Rank1: 1024MB(auto)-2T-18DataBus test pass!AddrBus test pass!-sLoad fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000New fip structure!Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600Load bl31 from eMMC, src: 0x00020200, des: 0x05100000, size: 0x00018400Load bl33 from eMMC, src: 0x0003c200, des: 0x01000000, size: 0x00055e00NOTICE:  BL3-1: v1.0(release):3348978NOTICE:  BL3-1: Built : 15:44:01, May 12 2017NOTICE:  BL3-1: BL33 decompress passmpu_config_enablek[Image: gxl_v1.1.3221-2cfba69 2017-05-27 16:03:58 qiufang.dai@droid07]OPS=0x82wdt: reset registers!17 f9 d8 20 f8 a0 37 9b b 37 41 3e [0.297309 Inits done]secure task start!high task start!low task start!ERROR:   Error initializing runtime service opteed_fast
    U-Boot 2015.01-g0002a8d (Oct 28 2017 - 15:36:16)
    DRAM:  2 GiBRelocation Offset is: 76ece000register usb cfg[0][1] = 0000000077f58c98[CANVAS]canvas initvpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parametersvpu: clk_level = 7vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)vpu: vpu_clk_gate_init_offvpp: vpp_initMMC:   aml_priv->desc_buf = 0x0000000073ece640aml_priv->desc_buf = 0x0000000073ed0960SDIO Port B: 0, SDIO Port C: 1emmc/sd response timeout, cmd8, status=0x3ff2800emmc/sd response timeout, cmd55, status=0x3ff2800init_part() 293: PART_TYPE_AML[mmc_init] mmc init successdtb magic edfe0dd0start dts,buffer=0000000073ed31b0,dt_addr=0000000073ed31b0parts: 1000:      logo   0000000002000000 101:  recovery   0000000002000000 102:       rsv   0000000000800000 103:       tee   0000000000800000 104:     crypt   0000000002000000 105:      misc   0000000002000000 106:      boot   0000000002000000 107:    system   0000000080000000 108:     cache   0000000020000000 209:      data   ffffffffffffffff 4init_part() 293: PART_TYPE_AMLeMMC/TSD partition table have been checked OK!check pattern successmmc env offset: 0x27400000In:    serialOut:   serialErr:   serialreboot_mode=cold_boothpd_state=0cvbs performance type = 6, table = 0[store]To run cmd[emmc dtb_read 0x1000000 0x40000]_verify_dtb_checksum()-917: calc 869bec18, store 869bec18_verify_dtb_checksum()-917: calc 869bec18, store 869bec18dtb_read()-1039: total valid 2dtb_read()-1106: do nothingvpp: vpp_pq_load pq val error !!![store]To run cmd[emmc dtb_read 0x1000000 0x40000]dtb_read_shortcut()-975: short cut in...Net:   __phy_realtek_initdwmac.c9410000amlkey_init() enter![EFUSE_MSG]keynum is 4[BL31]: tee size: 0
    Start read misc partition datas!info->attemp_times = 0info->active_slot = 0info->slot_info[0].bootable = 0info->slot_info[0].online = 0info->slot_info[1].bootable = 0info->slot_info[1].online = 0info->attemp_times = 0boot-info is invalid. Resetting.save boot-infoinfo->attemp_times = 0info->active_slot = 0info->slot_info[0].bootable = 1info->slot_info[0].online = 1info->slot_info[1].bootable = 0info->slot_info[1].online = 0info->attemp_times = 0attemp_times = 0active slot = 0wipe_data=successfulwipe_cache=successfulupgrade_step=2[OSD]load fb addr from dts[OSD]fb_addr for logo: 0x7f851000[OSD]load fb addr from dts[OSD]fb_addr for logo: 0x7f851000[CANVAS]addr=0x7f851000 width=3840, height=2160amlkey_init() enter!amlkey_init() 71: already init![EFUSE_MSG]keynum is 4[BL31]: tee size: 0[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet[BL31]: tee size: 0
    mac address: [KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yetsaradc - saradc sub-system
    Usage:saradc saradc open <channel>            - open a SARADC channelsaradc close    - close the SARADCsaradc getval   - get the value in current channelsaradc get_in_range <min> <max> - return 0 if current value in the range of curr        ent channel
    gpio: pin GPIOAO_2 (gpio 102) value is 1Product checking: pass!normal power onboot wol: disableHit Enter or space or Ctrl+C key to stop autoboot -- :  0ee_gate_off ...## Booting Android Image at 0x01080000 ...reloc_addr =73f53360copy doneKernel command line: buildvariant=userdebugload dtb from 0x1000000 ......   Uncompressing Kernel Image ... OK   kernel loaded at 0x01080000, end = 0x021b6a20   Loading Ramdisk to 73d4c000, end 73ebbbab ... OK   Loading Device Tree to 000000001fff2000, end 000000001fffff28 ... OKfdt_instaboot: no instaboot image
    Starting kernel ...
    uboot time: 1961336 us[    0.000000@0] Initializing cgroup subsys cpu[    0.000000@0] Initializing cgroup subsys cpuacct[    0.000000@0] Linux version 3.14.29-g596e723 (terry@Server) (gcc version 4.8.        4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #80 SMP PREEMPT Sat Oct 28 11:33:50 C        ST 2017[    0.000000@0] CPU: AArch64 Processor [410fd034] revision 4[    0.000000@0] no prop version_code[    0.000000@0] bootconsole [earlycon0] enabled[    0.000000@0] fdt Reserved memory table:[    0.000000@0]                  linux,di: 0x0000000076200000 - 0x0000000078000        000  (30 MiB)[    0.000000@0] DI: DI reserved memory: created CMA memory pool at 0x0000000076        200000, size 30 MiB[    0.000000@0]             linux,ion-dev: 0x000000006fd4c000 - 0x0000000073d4c        000  (64 MiB)[    0.000000@0]           linux,vdin1_cma: 0x0000000075000000 - 0x0000000076000        000  (16 MiB)[    0.000000@0] cma: Reserved 16 MiB at 75000000, total cma pages:4096[    0.000000@0]               linux,ppmgr: 0x0000000076200000 - 0x0000000076200        000  (0 MiB)[    0.000000@0]        linux,codec_mm_cma: 0x0000000063c00000 - 0x000000006fc00        000  (192 MiB)[    0.000000@0] cma: Reserved 192 MiB at 63c00000, total cma pages:53248[    0.000000@0]              linux,picdec: 0x0000000076200000 - 0x0000000076200        000  (0 MiB)[    0.000000@0] Reserved memory: incorrect alignment of CMA region[    0.000000@0]   linux,codec_mm_reserved: 0x000000005fb00000 - 0x0000000063c00        000  (65 MiB)[    0.000000@0] fdt Reserved memory total:  371 MiB[    0.000000@0] cma: Reserved 8 MiB at 74800000, total cma pages:55296[    0.000000@0] psci: Using PSCI v0.1 Function IDs from DT[    0.000000@0] PERCPU: Embedded 12 pages/cpu @ffffffc07616c000 s19968 r8192 d2        0992 u49152[    0.000000@0] Built 1 zonelists in Zone order, mobility grouping on.  Total p        ages: 479936[    0.000000@0] Kernel command line: rootfstype=ramfs init=/init console=ttyS0,        115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ra        moops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permiss        ive logo=osd1,loaded,0x3d800000,576cvbs maxcpus=8 vout=576cvbs,enable hdmimode=1        080p60hz cvbsmode=576cvbs hdmitx= ddr_size=2 cvbsdrv=0 pq= androidboot.firstboot        =0 jtag=disable androidboot.hardware=amlogic mac= androidboot.m        ac=98:aa:fc:60:46:ad androidboot.slot_suffix=_a wol_enable=0 buildvariant=userde        bug[    0.000000@0] logo: osd1[    0.000000@0] logo: loaded[    0.000000@0] logo: 0x3d800000[    0.000000@0] logo: 576cvbs[    0.000000@0] vout_serve: 576cvbs[    0.000000@0] vout_serve: enable: 1[    0.000000@0] logo: get hdmimode: 1080p60hz[    0.000000@0] logo: get cvbsmode: 576cvbs[    0.000000@0] tv_vout: cvbs performance line = 0[    0.000000@0] [amvecm] pq string error !!![    0.000000@0] jtag: jtag select -1[    0.000000@0] realtek init mac-addr: [    0.000000@0] PID hash table entries: 4096 (order: 3, 32768 bytes)[    0.000000@0] Dentry cache hash table entries: 262144 (order: 9, 2097152 byte        s)[    0.000000@0] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes        )[    0.000000@0] Memory: 1508316K/1961984K available (10949K kernel code, 1230K        rwdata, 4132K rodata, 1307K init, 3784K bss, 453668K reserved)[    0.000000@0] Virtual kernel memory layout:[    0.000000@0]     vmalloc : 0xffffff8000000000 - 0xffffff8040000000   (  1024        MB)[    0.000000@0]     vmemmap : 0xffffff8040010000 - 0xffffff8042950000   (    41        MB)[    0.000000@0]     modules : 0xffffffbffc000000 - 0xffffffc000000000   (    64        MB)[    0.000000@0]     memory  : 0xffffffc000000000 - 0xffffffc078000000   (  1920        MB)[    0.000000@0]       .init : 0xffffffc001f3c000 - 0xffffffc002082e00   (  1308        kB)[    0.000000@0]       .text : 0xffffffc001080000 - 0xffffffc001f3b794   ( 15086        kB)[    0.000000@0]       .data : 0xffffffc002083000 - 0xffffffc0021b6a20   (  1231        kB)[    0.000000@0] PM: Registered nosave memory: [mem 0x01080000-0x01f3afff][    0.000000@0] SLUB: HWalign=64, Order=0-1, MinObjects=0, CPUs=8, Nodes=1[    0.000000@0] arch_multi_cluster:1[    0.000000@0] Preemptible hierarchical RCU implementation.[    0.000000@0] NR_IRQS:64 nr_irqs:64 0[    0.000000@0] Architected cp15 timer(s) running at 24.00MHz (phys).[    0.000004@0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 286        3311519744ns[    0.008244@0] meson_bc_timer: mclk->mux_reg =ffffff8000014990,mclk->reg =ffff        ff8000016994[    0.016841@0] Console: colour dummy device 80x25[    0.021097@0] Calibrating delay loop (skipped), value calculated using timer        frequency.. 48.00 BogoMIPS (lpj=240000)[    0.031672@0] pid_max: default: 32768 minimum: 301[    0.036593@0] Security Framework initialized[    0.040787@0] SELinux:  Initializing.[    0.044542@0] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)[    0.051368@0] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 byte        s)[    0.065305@0] Initializing cgroup subsys debug[    0.065345@0] Initializing cgroup subsys freezer[    0.068860@0] ftrace: allocating 37824 entries in 148 pages[    0.124686@0] /cpus/cpu@0: Missing clock-frequency property[    0.124726@0] /cpus/cpu@1: Missing clock-frequency property[    0.130306@0] /cpus/cpu@2: Missing clock-frequency property[    0.135933@0] /cpus/cpu@3: Missing clock-frequency property[    0.141506@0] /cpus/cpu@100: Missing clock-frequency property[    0.147288@0] /cpus/cpu@101: Missing clock-frequency property[    0.153058@0] /cpus/cpu@102: Missing clock-frequency property[    0.158838@0] /cpus/cpu@103: Missing clock-frequency property[    0.164607@0] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 count        ers available[    0.214956@0] Meson chip version = RevA (22:A - 82:0)[    0.233346@1] CPU1: Booted secondary processor[    0.253309@2] CPU2: Booted secondary processor[    0.273315@3] CPU3: Booted secondary processor[    0.293347@4] CPU4: Booted secondary processor[    0.313347@5] CPU5: Booted secondary processor[    0.333355@6] CPU6: Booted secondary processor[    0.353386@7] CPU7: Booted secondary processor[    0.353478@0] Brought up 8 CPUs[    0.382296@0] SMP: Total of 8 processors activated.[    0.396623@2] sched: registering cpufreq notifiers for scale-invariant loads[    0.398152@2] instabooting: 0[    0.412603@2] cma: cma_init_reserved_areas, use_cma_first:1[    0.412708@2] pinctrl core: initialized pinctrl subsystem[    0.418732@2] regulator-dummy: no parameters[    0.423258@3] NET: Registered protocol family 16[    0.429549@2] ramoops: using module parameters[    0.432053@2] console [pstore-1] enabled[    0.435371@2] pstore: Registered ramoops as persistent store backend[    0.441772@2] ramoops: attached 0x100000@0x7300000, ecc: 0/0[    0.448486@2] cpuidle: using governor menu[    0.451863@3] aml_vdac_init: module init[    0.455697@2] register canvas platform driver[    0.459962@3] register rdma platform driver[    0.466384@3] vdso: 2 pages (1 code, 1 data) at base ffffffc00208c000[    0.470633@3] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.[    0.477943@3] DMA: preallocated 256 KiB pool for atomic allocations[    0.484826@3] software IO TLB [mem 0x5c000000-0x5c400000] (4MB) mapped at [ff        ffffc05c000000-ffffffc05c3fffff][    0.493823@3] Serial: AMBA PL011 UART driver[    0.498849@3] aml_i2c version: 20140813[    0.502244@2] i2c-core: driver [pmu4] using legacy resume method[    0.508219@2] codec_mm:codec_mm_module_init[    0.512296@2] media_configs_system_init[    0.516230@2] aml_watch_point_probe, in[    0.520391@2] meson_mpll_clk: register mpll_clk_out0 success done[    0.526070@2] meson_mpll_clk: register mpll_clk_out1 success done[    0.532149@2] meson_mpll_clk: register mpll_clk_out2 success done[    0.538486@2] clk_sys: register PLL sys_pll success done[    0.543616@2] gxl_clk: [ xtal        ] ->clockrate: 24000000Hz[    0.548991@2] gxl_clk: [ 32Khz       ] ->clockrate: 32000Hz[    0.554110@2] gxl_clk: [ clk81       ] ->clockrate: 166666666Hz[    0.559627@2] gxl_clk: [ fixed_pll   ] ->clockrate: 2000000000Hz[    0.565571@2] gxl_clk: [ fclk_div2   ] ->clockrate: 1000000000Hz[    0.571536@2] gxl_clk: [ fclk_div3   ] ->clockrate: 666666666Hz[    0.577384@2] gxl_clk: [ fclk_div4   ] ->clockrate: 500000000Hz[    0.583251@2] gxl_clk: [ fclk_div5   ] ->clockrate: 400000000Hz[    0.589109@2] gxl_clk: [ fclk_div7   ] ->clockrate: 285714285Hz[    0.595004@2] gxl_clk: clock initialization complete[    0.600137@2] clkmsr: Gxl msr_clk_reg0=ffffff800003c75c,msr_clk_reg2=ffffff80        0003e764[    0.610603@2] aml_iomap: amlogic iomap probe done[    0.613124@2] pinmux-gxl c1109880.pinmux: Init pinux probe![    0.619518@3] pinmux-gxl c1109880.pinmux: Probed amlogic pinctrl driver[    0.625516@3] aml-i2c c1108500.i2c: add adapter aml_i2c_adap1(ffffffc05ce088e        0)[    0.633208@2] aml-i2c c11087c0.i2c: add adapter aml_i2c_adap2(ffffffc05ce090e        0)[    0.639898@2] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type        +0x0/0xbc)[    0.647575@2] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type        +0x0/0xbc)[    0.655848@2] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type        +0x0/0xbc)[    0.663669@2] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type        +0x0/0xbc)domain-0 init dvfs: 4domain-1 init dvfs: 4[    0.684341@3] codec_mm has 2 memory regions[    0.684413@3] codec_mm codec_mm.18: assigned reserved memory node linux,codec        _mm_cma ok[    0.691018@3] codec_mm codec_mm.18: assigned reserved memory node linux,codec        _mm_reserved ok[    0.699674@2] codec_mm has 2 memory regions[    0.703730@2] codec_mm codec_mm.18: assigned reserved memory node linux,codec        _mm_cma ok[    0.711755@2] codec_mm codec_mm.18: assigned reserved memory node linux,codec        _mm_reserved ok[    0.722794@2] vpu: driver version: v04[    0.724020@2] vpu: load vpu_clk: 666667000Hz(7)[    0.728660@3] vpu: vpu_probe OK[    0.733629@2] tv_vout: tvout_probe[    0.735117@2] tv_vout: chrdev devno 266338304 for disp[    0.740286@2] vout_notify: vout_register_server[    0.744823@2] tv_vout: register tv module server ok[    0.749967@2] tv_vout: create cdev tv[    0.753413@2] tv_vout: tvout_probe OK[    0.757949@2] canvas_probe reg=00000000c8838000,size=400[    0.762439@2] canvas maped reg_base =ffffff800009e000[    0.771750@2] rdma_probe[    1.170729@3] bio: create slab <bio-0> at 0[    1.171934@0] SCSI subsystem initialized[    1.174055@0] usbcore: registered new interface driver usbfs[    1.179098@3] usbcore: registered new interface driver hub[    1.184667@0] usbcore: registered new device driver usb[    1.190730@0] i2c-gpio i2c_gpio.39: using pins 172 (SDA) and 173 (SCL)[    1.196739@3] Linux video capture interface: v2.00[    1.201450@1] pps_core: LinuxPPS API ver. 1 registered[    1.206274@1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Gio        metti <giometti@linux.it>[    1.215747@1] PTP clock support registered[    1.220503@1] hdmitx: system: Ver: 2014May6[    1.224154@1] hdmitx: amhdmitx_probe[    1.228619@0] hdmitx: hdmi_init_chip_type: 0[    1.231833@0] hdmitx: system: not find match init-data[    1.237024@0] hdmitx hpd irq = 89[    1.241144@1] hdmitx20: Mapped PHY: 0xc1100000[    1.244782@1] hdmitx20: Mapped PHY: 0xc8834400[    1.249309@1] hdmitx20: Mapped PHY: 0xd0100000[    1.253710@1] hdmitx20: Mapped PHY: 0xc8100000[    1.258163@1] hdmitx20: Mapped PHY: 0xc883c000[    1.262642@1] hdmitx20: Mapped PHY: 0xc1104400[    1.267085@1] hdmitx20: Mapped PHY: 0xc883a000[    1.271548@1] hdmitx20: Mapped PHY: 0xda83a000[    1.276063@1] hdmitx20: Mapped PHY: 0xd0044000[    1.280717@1] avmute set to 1[    1.283453@1] hdmitx: attr default[    1.287504@3] tv_vout: tv_set_current_vmode[925]fps_target_mode=8[    1.292990@3] tv_vout: mode is 8,sync_duration_den=1,sync_duration_num=50[    1.299844@3] tv_vout: already display in uboot[    1.304360@3] vout_serve: vinfo mode is: 576cvbs[    1.308997@3] vout_serve: init mode 576cvbs[    1.313458@0] vout_serve: create_vout_fops OK[    1.317583@0] vout_serve: create vout attribute OK[    1.322384@0] vout_serve: meson_vout_probe OK[    1.326994@3] logo: logo_init[    1.330209@3] osd_rdma: osd_rdma_init: rdma_table p=0x74841000,op=0x74841000        , v=0xffffff80000d9000[    1.338891@3] rdma_register, rdma_table_addr ffffff80000db000 rdma_table_addr        _phy 74842000 reg_buf ffffffc05cda4000[    1.349353@3] rdma_register success, handle 1 table_size 4096[    1.355110@3] osd_rdma: osd_rdma_initsd reset rdma handle = 1.[    1.361174@3] rdma_register, rdma_table_addr ffffff80000dd000 rdma_table_addr        _phy 74843000 reg_buf ffffffc05cda5000[    1.371653@3] rdma_register success, handle 2 table_size 4096[    1.377422@3] osd_rdma: osd_rdma_initsd rdma handle = 2.[    1.383487@0] Advanced Linux Sound Architecture Driver Initialized.[    1.389931@3] Bluetooth: Core ver 2.18[    1.393136@3] NET: Registered protocol family 31[    1.397636@3] Bluetooth: HCI device and connection manager initialized[    1.404217@3] Bluetooth: HCI socket layer initialized[    1.409275@3] Bluetooth: L2CAP socket layer initialized[    1.414571@3] Bluetooth: SCO socket layer initialized[    1.419603@3] NetLabel: Initializing[    1.423184@3] NetLabel:  domain hash size = 128[    1.427740@3] NetLabel:  protocols = UNLABELED CIPSOv4[    1.432945@3] NetLabel:  unlabeled traffic allowed by default[    1.441414@3] Switched to clocksource arch_sys_counter[    1.484503@0] register gxtv_demod demod driver[    1.484939@3] [amlatvdemod..]aml_atvdemod_init.[    1.488047@3] NET: Registered protocol family 2[    1.493087@3] TCP established hash table entries: 16384 (order: 5, 131072 byt        es)[    1.500063@3] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)[    1.507014@3] TCP: Hash tables configured (established 16384 bind 16384)[    1.513795@3] TCP: reno registered[    1.516906@3] UDP hash table entries: 1024 (order: 3, 32768 bytes)[    1.523257@3] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)[    1.530040@3] NET: Registered protocol family 1[    1.534603@3] RPC: Registered named UNIX socket transport module.[    1.540435@3] RPC: Registered udp transport module.[    1.545367@3] RPC: Registered tcp transport module.[    1.550234@3] RPC: Registered tcp NFSv4.1 backchannel transport module.[    1.557060@3] pwm: output_co = 16 ; clock_co = 8[    1.561579@3] pwm: npwm= 16[    1.564577@0] pwm: probe ok[    1.567569@3] wifi: power_on_pin_OD = 0;[    1.571068@3] aml_wifi wifi.34: [wifi_dev_probe] no power_on_pin2[    1.577232@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] pwm phandle val=        3e;pwm-channel1=4;pwm-channel2=12[    1.587281@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] pwm_config1[0] =        30541[    1.594963@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] pwm_config2[0] =        30518[    1.602656@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] pwm_config1[1] =        15270[    1.610349@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] pwm_config2[1] =        15259[    1.618055@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] pwm_config1[2] =        6[    1.625415@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] pwm_config2[2] =        9[    1.632755@3] aml_wifi wifi.34: [pwm_double_channel_conf_dt] wifi pwm dt ok[    1.639767@3] aml_wifi wifi.34: [pwm_double_channel_conf] wifi pwm conf ok[    1.646724@3] aml_wifi wifi.34: [wifi_dev_probe] dhd_static_buf setup[    1.653217@3] Wifi: bcmdhd_init_wlan_mem: bcmdhd_init_wlan_mem: WIFI MEM Allo        cated[    1.660749@3] aml_wifi wifi.34: [wifi_dev_probe] interrupt_pin=241[    1.666969@3] aml_wifi wifi.34: [wifi_dev_probe] irq_num=100, irq_trigger_typ        e=1[    1.674408@3] aml_wifi wifi.34: [wifi_dev_probe] power_on_pin=240[    1.680524@3] aml_wifi wifi.34: [wifi_dev_probe] clock_32k_pin=0[    1.686890@0] aml_wifi wifi.34: [wifi_setup_dt] wifi_setup_dt[    1.692422@0] aml_wifi wifi.34: [wifi_setup_dt] inter
    GMT+8, 2025-1-20 03:04 , Processed in 0.121611 second(s), 18 queries , MemCache On.
