查看: 1720|回复: 0
Raspberry Pi Zero W使用LCD1602打造数字时钟
  • 签到天数: 313 天
    发表于 2017-7-25 08:52:17 | 显示全部楼层 |阅读模式
    为了方便随时知道时间,我们可以利用Raspberry Pi Zero W和LCD1602显示屏做一个数字时钟,在使用树莓派开发的时候不忘时间,下面介绍具体实现方法,为了减少连接线的数量,笔者决定使用树莓派ZERO W的I2C接口来驱动LCD1602所以我们需要一个IIC/I2C/接口LCD1602液晶屏转接板
    首先将LCD1602和转换板按下图焊接
    然后用四根杜邦线将转换板上GND VCC SDA SCL分别连接到Raspberry Pi Zero W的GND VCC SDA SCL,参考下面排针GPIO定义即为Pin9 Pin1 Pin3 Pin5
    连接好后将树莓派ZERO W上电,进入终端输入如下命令
    sudo raspi-config按下图操作打开I2C
    然后安装i2c-tools和python-smbus
    sudo apt-get install i2c-tools python-smbus接着输入如下命令查看I2C接口连接设备的物理地址
    i2cdetect -y 1
    可以看到LCD1602位置为3f,接着创建一个数字时钟显示的python脚本lcd1602.py
    sudo vi lcd1602.py复制粘贴如下代码进去
    import smbusimport timeimport osfrom time import gmtime, strftime, localtimeos.environ['TZ'] = 'Asia/Shanghai'time.tzset()bus = smbus.SMBus(1)addr = 0x3fdef writeCommand(command):   bus.write_byte(addr, 0b1100 | command << 4)   time.sleep(0.005)   bus.write_byte(addr, 0b1000 | command << 4)   time.sleep(0.005)def writeWord(word):   for i in range(0,len(word)):      asciiCode =  ord(word)      bus.write_byte(addr, 0b1101 |(asciiCode >> 4 & 0x0F) << 4)      time.sleep(0.0005)      bus.write_byte(addr, 0b1001 |(asciiCode >> 4 & 0x0F) << 4)      time.sleep(0.0005)      bus.write_byte(addr, 0b1101 |(asciiCode & 0x0F) << 4)      time.sleep(0.0005)      bus.write_byte(addr, 0b1001 | (asciiCode & 0x0F) << 4)      time.sleep(0.0005)# initwriteCommand(0b0010)# 4-byte mode, 2 line codewriteCommand(0b0010)writeCommand(0b1111)# set cursor modewriteCommand(0b0000)writeCommand(0b1100)# cursor shift modewriteCommand(0b0000)writeCommand(0b0110)writeWord("Welcome")clear = Truetime.sleep(1)while(1):   # first line first column   writeCommand(0b1000)   writeCommand(0b0000)   writeWord(strftime("%Y-%m-%d, %a ", localtime()))   # second line first column   writeCommand(0b1100)   writeCommand(0b0000)   writeWord(strftime("%H:%M:%S", localtime()))   time.sleep(0.2)然后按ESC键后输入:wq保存脚本,接着输入如下命令运行脚本
    python lcd1602.pyLCD1602液晶屏上会显示如下日期和实时时间
    GMT+8, 2024-11-19 16:23 , Processed in 0.119075 second(s), 17 queries , MemCache On.
