查看: 1922|回复: 0
Raspberry Pi Zero W安装命令行音乐播放器
  • 签到天数: 313 天
    发表于 2017-7-10 10:12:40 | 显示全部楼层 |阅读模式
    我们可以在Raspberry Pi Zero W上一边写代码一边听音乐互不影响,只需安装一个在命令行里面运行的音乐播放器,而且可以在后台运行即可解决
    打开终端输入如下命令
    sudo apt-get install moc然后创建放配置文件的文件夹.moc
    sudo vi ~/.moc/config按i键然后复制粘贴如下进去
        ReadTags = no    Sort = FileName    ShowStreamErrors = no    Mp3IgnoreCRCErrors = yes    Repeat = yes    Shuffle = no    MusicDir = "/home/pi/Music"    AutoNext = yes    FormatString = "%(n:%n %(a:%a - %(t:%t%(A: \(%A\)"    OutputBuffer = 2048    InputBuffer = 512    Prebuffering = 64    SoundDriver = ALSA    AlsaMixer = PCM    AlsaMixer2 = Master    AlsaDevice = default    ShowHiddenFiles = no    HideFileExtension = no    ShowFormat = yes    ShowTime = IfAvailable    Theme = example_theme    UseMmap = no    SavePlaylist = yes    SyncPlaylist = yes    ASCIILines = no    TagsCacheSize = 256    FollowPlayedFile = yes    CanStartInPlaylist = yes    PlaylistFullPaths = no其中MusicDir = "/home/pi/Music"这行参数的引号里面填写音乐存放目录
    接着下面设置音频输出主设备
    运行如下命令
    sudo vi /etc/asound.conf修改里面为如下如果需要使用模拟音频输出
    pcm.!default {    type hw    card 0    #If you want to set HDMI as output ,turn 0 to 1.    device 0  }  ctl.!default {    type hw    card 0   #If you want to set HDMI as output ,turn 0 to 1.  }打开音频输出通道
    amixer set -c 0 'Audio lineout' unmute然后试试mocp,在终端运行mocp即可显示播放器
    左侧窗口添加音乐文件,右侧为播放列表
    快捷键如下,按h建查看全部快捷键
    GMT+8, 2024-11-19 16:45 , Processed in 0.120343 second(s), 17 queries , MemCache On.
