查看: 903|回复: 0
​迅为4412开发板WIFI模块和CAN/RFID模块同时使用的方法
发表于 2017-4-24 09:01:01 | 显示全部楼层 |阅读模式
硬件平台iTOP-4412精英版 ;  iTOP-4412全能版
软件版本Android4.4.4源码
iTOP-4412精英版
file:///C:UsersxunweiAppDataLocalTempksohtmlwps9D38.tmp.jpg
iTOP-4412全能版
file:///C:UsersxunweiAppDataLocalTempksohtmlwps9D49.tmp.jpg
硬件修改:
①精英版,将R27去掉(这是一个0欧姆电阻),在R28上焊上0欧姆电阻;
②全能版,将R97去掉(这是一个0欧姆电阻),在R98上焊上0欧姆电阻;
软件修改:
在内核源码中打开 arch/arm/mach-exynos/mach-itop4412.c文件
1.
rst = EXYNOS4_GPC1(1),//RK30SDK_WIFI_GPIO_RESET_N,//RK30_PIN3_PD0, //MUST set to pin num in target system
修改为:
//  .rst = EXYNOS4_GPC1(1),//RK30SDK_WIFI_GPIO_RESET_N,//RK30_PIN3_PD0, //MUST set to pin num in target system
.rst = EXYNOS4_GPZ(5),
2.  //MT66XX SYSRST
if(gpio_request(EXYNOS4_GPC1(1), "GPC1_1"))
printk(KERN_ERR "failed to request GPC1_1 for MT6620  SYSRST control\n");
修改为:
//MT66XX SYSRST
//  if(gpio_request(EXYNOS4_GPC1(1), "GPC1_1"))
//  printk(KERN_ERR "failed to request GPC1_1 for MT6620  SYSRST control\n");
if(gpio_request(EXYNOS4_GPZ(5), "WIFI_PWDN"))
3.  s3c_gpio_cfgpin(EXYNOS4_GPC1(0), S3C_GPIO_OUTPUT);
s3c_gpio_cfgpin(EXYNOS4_GPC1(1), S3C_GPIO_OUTPUT);
gpio_direction_output(EXYNOS4_GPC1(0), 0);
gpio_direction_output(EXYNOS4_GPC1(1), 0);
gpio_free(EXYNOS4_GPC1(0));
gpio_free(EXYNOS4_GPC1(1));
修改为:
s3c_gpio_cfgpin(EXYNOS4_GPZ(5), S3C_GPIO_OUTPUT);
gpio_direction_output(EXYNOS4_GPZ(5), 0);
gpio_free(EXYNOS4_GPZ(5));
修改完之后,make clean一下,然后重新编译内核和android。这样就会解决wifi和can不能共用或者wifi和RFID不能共用的问题。
GMT+8, 2024-12-21 07:50 , Processed in 0.111170 second(s), 17 queries , MemCache On.
