查看: 1373|回复: 0
MicroBoard+irDA&UART;测试3
  • 签到天数: 3 天
    发表于 2017-3-22 09:06:04 | 显示全部楼层 |阅读模式
    手头有红外发射器和接收器,就做红外的测试
    主要的原理图如下:
     通信接口就是UART
     然后进行仿真测试,由于之前的UART模块是测试好,就不赘述.
    tb的思路就是发送00 - ff 的数据到irDA.
    uart的波特率是115.2Kbps
    下面放出irDA的代码.
    `timescale 1ns / 100psmodule sirendec (         clk16x,           // Input:   16x (chip rate) clock        irrxd,            // Input:   IR RxD input from IR transciever module         nrcven,           // Input:   Active low reset for decode state machine         rxd,              // Output:  Recovered RxD output -> UART's SIN signal         txd,              // Input:   TxD input <- UART's SOUT signal        irtxd              // Output:  TxD LED signal output for IR transciever        ) ;        input clk16x , irrxd , nrcven , txd ; output rxd , irtxd ;/******** Decoder **********/reg q0, q1, q2, q3;reg trigctl, count8reset, one_more; reg clear_ff;wire rxd = ~clear_ff;wire restrigff = nrcven & count8reset;always @ ( negedge irrxd or negedge restrigff ) begin          if ( ~restrigff ) trigctl <= 0;          else trigctl <= 1;end wire reset_count =  ~( (~one_more) | (~trigctl) ) ; always @ ( negedge clk16x or negedge clear_ff ) begin          if (~clear_ff) q0 <= 0;          else q0 <= ( reset_count | (~q0) );end wire din_q1 = ~(reset_count | (~( q0 ^ q1 )) ); always @ ( negedge clk16x or negedge clear_ff ) begin          if ( ~clear_ff ) q1 <= 0;          else q1 <= din_q1;endwire din_q2 = ~(reset_count | (~( q2 ^ (q0 & q1) )) ); always @ ( negedge clk16x or negedge clear_ff ) begin           if (~clear_ff) q2 <= 0;          else q2 <= din_q2;end wire din_q3 = ~(reset_count | (~( ( q0 & q1 & q2 ) ^ q3 )) ); always @ ( negedge clk16x or negedge clear_ff ) begin          if ( ~clear_ff ) q3 <= 0;          else q3 <= din_q3;endwire judge_1 = ~( q0 | q1 | q2 | q3 );wire judge_2 = ~( (~q0) & (~q1) & (~q2) & q3 );always @ ( posedge clk16x or negedge nrcven ) begin          if ( ~nrcven ) count8reset <= 0;          else count8reset <= judge_2;endalways @ ( posedge clk16x or negedge nrcven ) begin          if ( ~nrcven ) clear_ff <= 0;          else clear_ff <= ~(judge_1 & (~trigctl) );endalways @ ( negedge clk16x or negedge nrcven ) begin          if ( ~nrcven ) one_more <= 0;          else one_more <= q3;end/********** Encoder **********/reg [3:0] count4bit ;always @ ( negedge clk16x or posedge txd ) begin          if ( txd ) count4bit <= 4'b0000;          else                   count4bit <= count4bit + 1;endwire dec8clkcount = (~count4bit[0]) | (~count4bit[1] ) | (~count4bit[2]) |                     count4bit[3];         // == 8wire dec10cycclk = count4bit[0] | (~count4bit[1]) | count4bit[2] |                    (~count4bit[3]);         // == 5wire irtxd;jk_ff jk_ff (         .clk ( ~clk16x ),        .J (~dec8clkcount),        .K (dec10cycclk),        .CLR (~txd),        .jkout (irtxd) );endmodule                                // JK flip flop with async. clear  model: 74xx109module jk_ff ( clk , J , K , CLR , jkout ); input clk , J , K , CLR;output jkout ;reg jkout ;always @ ( posedge clk or negedge CLR ) begin           if ( ~CLR ) jkout <= 0 ;           else            case ({ J , K })                      2'b00 : jkout <= 0 ;                      2'b01 : jkout <= jkout ;                      2'b10 : jkout <= ~jkout ;                      2'b11 : jkout <= 1 ;           endcaseendendmoduleirDA的传感器原理如图
      就是个led.
      uart编码是NRZ编码方式.irDA使用的是RZI编码方式.如图.
    这两种编码是反转的.
    其中irDA是半双工,uart是全双工.在每次传输过程中有10ms的延迟.
    这些差别在仿真过程中能很好的发现.
    仿真脚本:
    `timescale 1ns / 100psmodule irda_uart_tb;reg         mclkx16, read, write, irrxd, reset;wire         [7:0] data;wire         irtxd, rxrdy, txrdy, parity_error, framing_error, overrun;parameter baudrate = 500;        // Baudrate specified in ns  integer         testdata;reg [7:0] data_received, data_written;// Instantiate IrDA/UART top level moduleirda_uart irda_uart_test (.data(data), .mclkx16(mclkx16), .write(write), .read(read), .reset(reset),                           .parity_error(parity_error), .framing_error(framing_error), .overrun(overrun),                           .rxrdy(rxrdy), .txrdy(txrdy), .irtxd(irtxd), .irrxd(irrxd));                // Generate 16 times baudrate clock frequency, i.e. Baudrate = mclkx16/16initial begin           mclkx16 = 1;          forever           begin                      #(baudrate/(16*2));                // Divide baudrate periode by 32 to get half mclkx16 period                       mclkx16 = ~mclkx16;              endend// Reset UART. initial begin        #500;           reset = 1;            #2000;           reset = 0;end// Feeding back transmit output to receive inputalways @(irtxd) begin        #1;                                irrxd = ~irtxd;end        // Main test programinitial begin        write = 1;                                // de-assert write initially        read = 1;                                // de-assert read initially        #100;        force irda_uart_tb.rxrdy = 0;                #50;                                        // Necessary for proper initialization        release irda_uart_tb.rxrdy;        #3000;                                        // Wait for reset to go low        // Write every possible combinations to the transmitter.        for (testdata = 8'h0; testdata  <= 8'hff; testdata = testdata + 1)         begin                write = 0;                #100;                force data = testdata;                #50;        write = 1;                data_written = testdata;                // Latch contents of data bus                         #20;                release data;                        wait(rxrdy);                                // Wait for rxrdy/read signal                                read = 0;                                #25;                data_received = data;                        // Latch contents of data bus                        #75;                read = 1;                        end        endendmodule进一步
     进一步的拓展是获取空调遥控的编码信息.随后继续跟进.
    GMT+8, 2024-12-21 10:42 , Processed in 0.119173 second(s), 17 queries , MemCache On.
