查看: 976|回复: 0
Debian-8+vivado 2016.2仿真使用2
  • 签到天数: 3 天
    发表于 2017-3-9 08:43:16 | 显示全部楼层 |阅读模式
    前言
            为了测试写的代码是否正确肯定要进行仿真,目前是使用VHDL语言进行开发,所以debian上VHDL仿真,暂时电脑存在 vivado 就是用他算了。
    GHDL也能进行VHDL语言仿真,暂时不使用它。
    准备:
    工程代码下载地址:
    https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_1/ug937-design-files.zip
    开始
       创建工程添加代码
    添加完成就这个样子。
    添加sine_high & sine_low & sine_mid ip
       打开IP contalog  在找到DDS compiler 双击修改配置如图
      配置(英文描述)
          o Component Name: type sine_high
           o Configuration Options: select SIN COS LUT only
          o Noise Shaping: select None
          o Under Hardware Parameters, set Phase Width to 16 and Output Width to 20
    On the Implementation tab, set Output Selection to Sine
    On the Detailed Implementation tab, set Control Signals to ARESETn (active-Low)
    下来是sine_mid
    In the IP catalog, double-click the DDS Compiler IP a second time.
    Specify the following on the Configuration tab:
    o Component Name: type sine_mid
    o Under Hardware Parameters, set the Phase Width to 8, and the Output Width to 18
    On the Implementation tab, set the Output Selection to Sine
    Select the Summary tab, review the settings and click OK
    下来增加sine_low ip
    1.In the IP catalog, double-click the DDS Compiler IP for the third time.
    2. Specify the following on the Configuration tab:
    o Component Name: type sine_low
    o Under Hardware Parameters, set the Phase Width to 6 and the Output Width to 16
    3. On the Implementation tab, set the Output Selection to Sine.
    4. On the Detailed Implementation tab, set Control Signals to ARESETn (active-Low)
    5. Select the Summary tab, review the settings as seen  and click OK.
    下来行为仿真
    在左边的project settings中选择如图的配置
    选择好后点 rum simulation  (在左边的flow中),选择run behaiviroal  simulation
    这里有个pre和post 过程。等等就好。
      结果
        学多少写多少。慢慢来。一次学不了那么多内容。
    GMT+8, 2025-2-28 09:53 , Processed in 0.099203 second(s), 14 queries , MemCache On.
