查看: 795|回复: 0
MicroBoard+PmodNAV-3-GPIO驱动
  • 签到天数: 3 天
    发表于 2017-2-9 08:46:02 | 显示全部楼层 |阅读模式
    前言
    承接上篇的2 写这个目的是就是分享过程。我觉得我自身的效率还是很差劲。
    现在记录软件部分。杂谈
    开始
    首先创建一个BSP吧
    这么创建能够设置BSP
    设置完
    打开这里看看
    然后就有他
    我看了 5分钟
    熟悉一下GPIO然后等会要写NAV.H的文件。
    然后同样 继续打开了SPI的这个网页说明文件。看了半天
    就算是该,先看看示例代码吧。
    创建个工程
    选这个
    然后选这个 工程
    然后finish 发现 工程没有任何问题
    然后继续 浏览代码5分钟
    先看看GPIO的基本使用吧
    /***************************** Include Files *********************************/#include "xparameters.h"#include "xgpio.h"/************************** Constant Definitions *****************************/#define LED 0x01   /* Assumes bit 0 of GPIO is connected to an LED  *//* * The following constant maps to the name of the hardware instances that * were created in the EDK XPS system. */#define GPIO_EXAMPLE_DEVICE_ID  XPAR_LEDS_POSITIONS_DEVICE_ID/* * The following constant is used to wait after an LED is turned on to make * sure that it is visible to the human eye.  This constant might need to be * tuned for faster or slower processor speeds. */#define LED_DELAY     1000000/* * The following constant is used to determine which channel of the GPIO is * used for the LED if there are 2 channels supported. */#define LED_CHANNEL 1/**************************** Type Definitions *******************************//***************** Macros (Inline Functions) Definitions *********************/#ifdef PRE_2_00A_APPLICATION/* * The following macros are provided to allow an application to compile that * uses an older version of the driver (pre 2.00a) which did not have a channel * parameter. Note that the channel parameter is fixed as channel 1. */#define XGpio_SetDataDirection(InstancePtr, DirectionMask) \        XGpio_SetDataDirection(InstancePtr, LED_CHANNEL, DirectionMask)#define XGpio_DiscreteRead(InstancePtr) \        XGpio_DiscreteRead(InstancePtr, LED_CHANNEL)#define XGpio_DiscreteWrite(InstancePtr, Mask) \        XGpio_DiscreteWrite(InstancePtr, LED_CHANNEL, Mask)#define XGpio_DiscreteSet(InstancePtr, Mask) \        XGpio_DiscreteSet(InstancePtr, LED_CHANNEL, Mask)#endif/************************** Function Prototypes ******************************//************************** Variable Definitions *****************************//* * The following are declared globally so they are zeroed and so they are * easily accessible from a debugger */XGpio Gpio; /* The Instance of the GPIO Driver *//*****************************************************************************//**** The purpose of this function is to illustrate how to use the GPIO level 1* driver to turn on and off an LED.** @param        None** @return        XST_FAILURE to indicate that the GPIO Intialisation had failed.** @note                This function will not return if the test is running.*******************************************************************************/int main(void){        u32 Data;        int Status;        volatile int Delay;        /*         * Initialize the GPIO driver         */        Status = XGpio_Initialize(&Gpio, GPIO_EXAMPLE_DEVICE_ID);        if (Status != XST_SUCCESS) {                return XST_FAILURE;        }        /*         * Set the direction for all signals to be inputs except the         * LED output         */        XGpio_SetDataDirection(&Gpio, LED_CHANNEL, ~LED);        /* Loop forever blinking the LED */        while (1) {                /*                 * Read the state of the data so that only the LED state can be                 * modified                 */                Data = XGpio_DiscreteRead(&Gpio, LED_CHANNEL);                /*                 * Set the LED to the opposite state such that it blinks using                 * the first method, two methods are used for illustration                 * purposes only                 */                if (Data & LED) {                        XGpio_DiscreteWrite(&Gpio, LED_CHANNEL, Data & ~LED);                } else {                        XGpio_DiscreteWrite(&Gpio, LED_CHANNEL, Data | LED);                }                /* Wait a small amount of time so the LED is visible */                for (Delay = 0; Delay < LED_DELAY; Delay++);                /*                 * Read the state of the data so that only the LED state can be                 * modified                 */                Data = XGpio_DiscreteRead(&Gpio, LED_CHANNEL);                /*                 * Set the LED to the opposite state such that it blinks using                 * the other API functions                 */                if (Data & LED) {                        XGpio_DiscreteClear(&Gpio, LED_CHANNEL, LED);                } else {                        XGpio_DiscreteSet(&Gpio, LED_CHANNEL, LED);                }                /* Wait a small amount of time so the LED is visible */                for (Delay = 0; Delay < LED_DELAY; Delay++);        }        return XST_SUCCESS;}再看看SPI吧
    /***************************** Include Files *********************************/#include "xparameters.h"        /* XPAR parameters */#include "xspi.h"                /* SPI device driver */#include "xspi_l.h"/************************** Constant Definitions *****************************//* * The following constants map to the XPAR parameters created in the * xparameters.h file. They are defined here such that a user can easily * change all the needed parameters in one place. */#define SPI_DEVICE_ID                XPAR_SPI_0_DEVICE_ID/* *  This is the size of the buffer to be transmitted/received in this example. */#define BUFFER_SIZE                12/**************************** Type Definitions *******************************//* * The following data type is used to send and receive data on the SPI * interface. */typedef u8 DataBuffer[BUFFER_SIZE];/***************** Macros (Inline Functions) Definitions *********************//************************** Function Prototypes ******************************/int SpiPolledExample(XSpi *SpiInstancePtr, u16 SpiDeviceId);/************************** Variable Definitions *****************************//* * The instances to support the device drivers are global such that the * are initialized to zero each time the program runs. */static XSpi  SpiInstance;         /* The instance of the SPI device *//* * The following variables are used to read and write to the  Spi device, they * are global to avoid having large buffers on the stack. */u8 ReadBuffer[BUFFER_SIZE];u8 WriteBuffer[BUFFER_SIZE];/*****************************************************************************//**** Main function to call the Spi Polled example.** @param        None** @return        XST_SUCCESS if successful, otherwise XST_FAILURE.** @note                None*******************************************************************************/int main(void){        int Status;        /*         * Run the Spi Polled example.         */        Status = SpiPolledExample(&SpiInstance, SPI_DEVICE_ID);        if (Status != XST_SUCCESS) {                return XST_FAILURE;        }        return XST_SUCCESS;}/*****************************************************************************//**** This function does a minimal test on the Spi device and driver as a* design example. The purpose of this function is to illustrate how to use* the XSpi component using the polled mode.** This function sends data and expects to receive the same data.*** @param        SpiInstancePtr is a pointer to the instance of Spi component.* @param        SpiDeviceId is the Device ID of the Spi Device and is the*                XPAR_<SPI_instance>_DEVICE_ID value from xparameters.h.** @return        XST_SUCCESS if successful, otherwise XST_FAILURE.** @note** This function contains an infinite loop such that if the Spi device is not* working it may never return.*******************************************************************************/int SpiPolledExample(XSpi *SpiInstancePtr, u16 SpiDeviceId){        int Status;        u32 Count;        u8 Test;        XSpi_Config *ConfigPtr;        /* Pointer to Configuration data */        /*         * Initialize the SPI driver so that it is  ready to use.         */        ConfigPtr = XSpi_LookupConfig(SpiDeviceId);        if (ConfigPtr == NULL) {                return XST_DEVICE_NOT_FOUND;        }        Status = XSpi_CfgInitialize(SpiInstancePtr, ConfigPtr,                                  ConfigPtr->BaseAddress);        if (Status != XST_SUCCESS) {                return XST_FAILURE;        }        /*         * Perform a self-test to ensure that the hardware was built correctly.         */        Status = XSpi_SelfTest(SpiInstancePtr);        if (Status != XST_SUCCESS) {                return XST_FAILURE;        }        /*         * Run loopback test only in case of standard SPI mode.         */        if (SpiInstancePtr->SpiMode != XSP_STANDARD_MODE) {                return XST_SUCCESS;        }        /*         * Set the Spi device as a master and in loopback mode.         */        Status = XSpi_SetOptions(SpiInstancePtr, XSP_MASTER_OPTION |                                         XSP_LOOPBACK_OPTION);        if (Status != XST_SUCCESS) {                return XST_FAILURE;        }        /*         * Start the SPI driver so that the device is enabled.         */        XSpi_Start(SpiInstancePtr);        /*         * Disable Global interrupt to use polled mode operation         */        XSpi_IntrGlobalDisable(SpiInstancePtr);        /*         * Initialize the write buffer with pattern to write, initialize the         * read buffer to zero so it can be verified after the read, the         * Test value that is added to the unique value allows the value to be         * changed in a debug environment.         */        Test = 0x10;        for (Count = 0; Count < BUFFER_SIZE; Count++) {                WriteBuffer[Count] = (u8)(Count + Test);                ReadBuffer[Count] = 0;        }        /*         * Transmit the data.         */        XSpi_Transfer(SpiInstancePtr, WriteBuffer, ReadBuffer, BUFFER_SIZE);        /*         * Compare the data received with the data that was transmitted.         */        for (Count = 0; Count < BUFFER_SIZE; Count++) {                if (WriteBuffer[Count] != ReadBuffer[Count]) {                        return XST_FAILURE;                }        }        return XST_SUCCESS;}这里有一些坑。就是这里 SPI工作模式使用的是LOOP模式。就是没有跟外部的chip通信。
    所以要配置工作模式,配置SPI的寄存器。这个寄存器简单的low_level实现就是xil_regout(addr,reg_value);
    要么就是使用xspi.h提供的函数,这算不上什么难度了。
    使用这个
    XSpi_SetOptions(&my_spi, XSP_MASTER_OPTION|XSP_MANUAL_SSELECT_OPTION|XSP_CLK_ACTIVE_LOW_OPTION|XSP_CLK_PHASE_1_OPTION);如果不这么配置的话,IP处于未知的状态。或者是使用在edk或者vivado中配置好的ip设置,这么做,要很熟悉这个qspi flash 的 ip。
    还有就是
    status =XSpi_SetSlaveSelect(&my_spi,0x01);这里一定要设置这个ss端口。即使你可能不会用到。(在使用xspi.h函数通信的情况下。使用low_level配置reg可以忽略)我就是在这里坑的, debug的时候发现的。
    XSpi_IntrGlobalDisable(SpiInstancePtr); 还有这个。一般情况下,使用它spi的中断,我没有使用中断模式。我使用的polled模式、
    因此要关闭。
    最后初始化完成后。
    XSpi_Start(SpiInstancePtr);这句也坑重要。
    结语
    整个过程中debug中有几个点。一是fpga在第一次下载download.bit后 debug  mdm时候,第二次重新debug时候,这是后进行spi  gpio的初始化会失败。
    因为xspi.h的函数会检查spi是否启动。在第一次debug的时候,已经startspi一次了。所以这时候reset最好。
    历史
      v 0.1  2017.2.6创建
      v 0.2 2017.2.8 修改代码license信息
      v 0.3 20.17.2.9 修改结语
    GMT+8, 2024-11-19 16:23 , Processed in 0.118798 second(s), 17 queries , MemCache On.
