查看: 1225|回复: 0
XMEGA256 SPI方式读写SD
  • 签到天数: 115 天
    [LV.6]常住居民II
    发表于 2016-4-18 08:39:58 | 显示全部楼层 |阅读模式
    硬件使用XMEGA256A3BU XPLAINED 开发板 + SD扩展小板,
    SD部分的线路图如下:
    相关的源码如下:
    #include <asf.h>
    #include "macros.h"
    #include "sd.h"
    int main (void)
    // Insert system clock initialization code here (sysclk_init()).
    board_init();
    sysclk_init();
    ioport_configure_pin(sd_cs,  IOPORT_INIT_HIGH | IOPORT_DIR_OUTPUT);
    ioport_configure_pin(sd_mosi, IOPORT_INIT_HIGH | IOPORT_DIR_OUTPUT);
    ioport_configure_pin(sd_miso, IOPORT_DIR_INPUT | IOPORT_PULL_UP);
    ioport_configure_pin(sd_clk,  IOPORT_INIT_HIGH | IOPORT_DIR_OUTPUT);
    sd_card_init();
    uint8_t buff[512];
    uint16_t i;
    for(i = 0;i < 512;i++) {
    buff = 0xED;
    sd_wr_block(222,buff);
    buff = 0x00;
    sd_rd_block(222,buff);
    asm("nop");
    // Insert application code here, after the board has been initialized.
    可以看出,SD卡写入和读出都正确,以此为基础,后续可以加载
    FAT文件系统,用以测试文件系统是否正确工作!
    GMT+8, 2024-12-20 01:59 , Processed in 0.120310 second(s), 17 queries , MemCache On.
