查看: 972|回复: 0
【F030 Nucleo】6.北斗&GPS;双模定位模块数据的解析
  • 签到天数: 1368 天
    发表于 2015-9-14 08:48:31 | 显示全部楼层 |阅读模式
    手上的模块不能闲着,能连接的都连接上。
        一般的定位模块都是通过串口连接,输出NM0183格式的数据,只要在MCU中解析就可以了。
        这款北斗&GPS模块也不例外,只比普通的GPS模块多输出个BD开头的数据而已,格式都是一样的。
    #include <string.h>
    #include <stdio.h>
    #include <stdlib.h>
    struct GPS
    char AV;    //'A|V'
    char DT[13];   //"150622181500"
    float Lon;   //"117.3185"
    float Lat;   //"39.0940\0"
    char EWNS[3];  //"E|W & N|S"
    float Speed; //"xxx.xx\0" *1.852
    float Dir;   //"xxx.x\0"
    float High;  //"\0"
    unsigned char Star; //"0~F"
    unsigned char ANT;   //'0'正常;'1'短路;'2'开路
    } gpsData;
    float LonLat(char* ll, int len)
    //printf("%s - %d", ll, len);
    char* s;
    memcpy(s, ll, len);
    //printf("%s", s);
    printf("%f", atof(s));
    return atof(s);
    float Speed(char* speed, int len)
    char* s = memmove(s, speed, len);
    return atof(s);
    void RMC(char* data)
    char* s = NULL;
    int len = 0;
    //Time
    char* p = strstr(data, ",");
    int i = p - data + 1;
    gpsData.DT[6] = data; i++;
    gpsData.DT[7] = data; i++;
    gpsData.DT[8] = data; i++;
    gpsData.DT[9] = data; i++;
    gpsData.DT[10] = data; i++;
    gpsData.DT[11] = data; i++;
    //AV
    p = strstr(data + i, ",");
    i = p - data + 1;
    gpsData.AV = data; i++;
    //Lat
    i = p++ - data + 1;
    s = strstr(p + 1, ",");
    len = s - p;
    gpsData.Lat = LonLat(p, len);
    printf("%f", gpsData.Lat);
    //NS
    i = p++ - data + 1;
    gpsData.EWNS[1] = data; i++;
    //Lon
    i = p++ - data + 1;
    len = s - p;
    gpsData.Lon = LonLat(p, len);
    //EW
    i = p++ - data + 1;
    gpsData.EWNS[0] = data; i++;
    //Speed
    i = p++ - data + 1;
    len = s - p;
    gpsData.Speed = Speed(p, len);
    //Dir
    i = p++ - data + 1;
    len = s - p;
    gpsData.Dir = atof(s);
    //Date
    i = p++ - data + 1;
    memmove(&gpsData.DT[4], data + i, 2); i += 2;
    memmove(&gpsData.DT[2], data + i, 2); i += 2;
    memmove(&gpsData.DT[0], data + i, 2); i += 2;
    printf("%f", gpsData.Lon);
    void GGA(char* data)
    void GSA(char* data)
    void GSV(char* data)
    void TXT(char* data)
    void TD3020C(char* data)
    switch (data[1])
    case 'G': //GNRMC; GNGGA; GPGSA; GPGSV; GNTXT;
    switch (data[2])
    case 'N': //GNRMC; GNGGA; GNTXT;
    switch (data[4])
    case 'M': //GNRMC
    RMC(data);
    break;
    case 'G': //GNGGA
    GGA(data);
    break;
    case 'S': //GPGSA
    GSA(data);
    break;
    break;
    case 'P': //GPGSA; GPGSV;
    switch (data[5])
    case 'A': //GPGSA
    GSA(data);
    break;
    case 'V': //GPGSV
    GSV(data);
    break;
    break;
    break;
    case 'B': //BDGSA; BDGSV;
    switch (data[5])
    case 'A': //BDGSA
    GSA(data);
    break;
    case 'V': //BDGSV
    GSV(data);
    break;
    break;
    int main(void)
    TD3020C(GPSData);
        解析的函数封装到一个文件里了,不过只需要调用一个TD3020C(GPSData);就够了。
        GPSData就是串口获取到的定位模块的数据,解析后的结果保存在struct GPS里。
        可以在程序的任何地方调用。
    GMT+8, 2024-12-19 14:45 , Processed in 0.108798 second(s), 17 queries , MemCache On.
