查看: 822|回复: 0
【玩转系列】序列之8:大时钟驾到
  • 签到天数: 709 天
    发表于 2015-4-20 19:22:49 | 显示全部楼层 |阅读模式
    【玩转系列】序列之8:大时钟驾到
    转载请注明出处和作者:请尊重版权所有!否则后果自负,谢谢!!
    本节主要是从下面3个方面进行讲解:
    1.工具准备工作
    2.时钟显示程序
    3.时钟显示效果
    一、工具准备工作
    1.电脑一台;
    2.LCD12864液晶一块;
    3.USB数据线一根;
    4.单片机开发板一块;
    5.杜邦线若干根;
    6.排线一组;
    7.已经装安装MDK和keil软件。
    二、时钟显示程序
    1.时间显示UI界面函数。
    const sWidget MuTime[] ={         0,16,16,112,Def,Def,ShowTime,CTRLTime,ShowTime,TimeYDraw,10,(void*)&InY,        16, 40,16,64,Def,Def,ShowTime,CTRLTime,0       ,TimeHDraw,0,(void*)&InH,    32, 40,16,64,Def,Def,ShowTime,CTRLTime,0       ,DrawOpen,0,(void*)&InO,        32,112,16,16,Def,Def,ShowTime,CTRLTime,0       ,DrawOpenW,0,"",        48, 40,16,64,Def,Def,ShowTime,CTRLTime,0       ,DrawClose,0,(void*)&InC,        48,112,16,16,Def,Def,ShowTime,CTRLTime,0       ,DrawCloseW,0,"",};
    2.时间调整调用函数。
    N8 isSameTime(N8 H,N8 M,N8 S){        if(gST.Hour != H) return 0;        if(gST.Min  != M) return 0;        if(gST.Sec  != S) return 0;        return 1;}void AutoOnOff(void){        if(gLED.AuOn.IsCheck){if(isSameTime(gLED.AuOn.H,gLED.AuOn.M,gLED.AuOn.S))gLED.Run =1;}        if(gLED.AuOf.IsCheck){if(isSameTime(gLED.AuOf.H,gLED.AuOf.M,gLED.AuOf.S))gLED.Run =0;}}void CTRLTime(void){    switch(gUI.Key)    {        case KeyUp:case KeyDown:    break;        case KeyFun:EEP_Save(); UIGoTo(&WinM); break;        case KeyEsc:                break;        case KeyOK:            switch(gUI.iMu)            {            case 3:gLED.AuOn.IsCheck=(gLED.AuOn.IsCheck)?(0)1);break;            case 5:gLED.AuOf.IsCheck=(gLED.AuOf.IsCheck)?(0)1);break;            default:EditInit((sEditInPut*)gUI.pMu->Data);            }            break;                                case KeyRun: LedRunSw();break;    }}void DrawOpen(void){    if(!UI_MuEdit){        sprintf(str,"%.2d:%.2d:%.2d",gLED.AuOn.H,gLED.AuOn.M,gLED.AuOn.S);    }    ASCII8x16(gUI.pMu->A.Top,gUI.pMu->A.Left,(UI_MuEdit)?(gUI.Es)str));}void DrawClose(void){    if(!UI_MuEdit){        sprintf(str,"%.2d:%.2d:%.2d",gLED.AuOf.H,gLED.AuOf.M,gLED.AuOf.S);    }    ASCII8x16(gUI.pMu->A.Top,gUI.pMu->A.Left,(UI_MuEdit)?(gUI.Es)str));}void DrawOpenW(void){    str[0]='a';str[1]=(gLED.AuOn.IsCheck)?('1')'2'); str[2]=str[3]=0;    GBstr(gUI.pMu->A.Top,gUI.pMu->A.Left,Mode_CP,str);}void DrawCloseW(void){    str[0]='a';str[1]=(gLED.AuOf.IsCheck)?('1')'2');str[2]=str[3]=0;    GBstr(gUI.pMu->A.Top,gUI.pMu->A.Left,Mode_CP,str);}void TimeHDraw(void){    if(!UI_MuEdit){        sprintf(str,"%.2d:%.2d:%.2d",gST.Hour,gST.Min,gST.Sec);    }    ASCII8x16(gUI.pMu->A.Top,gUI.pMu->A.Left,(UI_MuEdit)?(gUI.Es)str));}void TimeYDraw(void){    char weak[1];    if(!UI_MuEdit){        sprintf(str,"%.4d  %.2d  %.2d",gST.Year,gST.Month,gST.Day);    }    ASCII8x16(gUI.pMu->A.Top,gUI.pMu->A.Left,(UI_MuEdit)?(gUI.Es)str));       GBstr(gUI.pMu->A.Top  ,gUI.pMu->A.Left+32,Mode_Ad,"年  月  日");    weak[0]=18+gST.Week;    GBi(16,16,Mode_CP,1,weak);}void CallStrTimeY(void){    gST.Year   = (gUI.Es[0]-'0')*1000+(gUI.Es[1]-'0')*100+(gUI.Es[2]-'0')*10+gUI.Es[3]-'0';    gST.Month  = (gUI.Es[6]-'0')*10+gUI.Es[7]-'0';    gST.Day    = (gUI.Es[10]-'0')*10+gUI.Es[11]-'0';    RTC_Set(&gST);}void CallByTimeY(void){    int pro,max,k;    switch(gUI.Ei)    {        case 7:  pro='1';max='2';k=2;break;        case 11: pro='3';max='1';k=1;break;        default: gUI.Es[gUI.Ei]='*';return;    }    if(gUI.Es[gUI.Ei-1]>=pro) gUI.Es[gUI.Ei]=(gUI.Key > k)?(max)gUI.Key+'0');    else gUI.Es[gUI.Ei]= gUI.Key+ '0';}void CallStrTimeH(void){    gST.Hour = (gUI.Es[0]-'0')*10+gUI.Es[1]-'0';    gST.Min  = (gUI.Es[3]-'0')*10+gUI.Es[4]-'0';    gST.Sec  = (gUI.Es[6]-'0')*10+gUI.Es[7]-'0';    RTC_Set(&gST);}void CallStrAon(void){    gLED.AuOn.H= (gUI.Es[0]-'0')*10+gUI.Es[1]-'0';    gLED.AuOn.M= (gUI.Es[3]-'0')*10+gUI.Es[4]-'0';    gLED.AuOn.S= (gUI.Es[6]-'0')*10+gUI.Es[7]-'0';}void CallStrAof(void){    gLED.AuOf.H= (gUI.Es[0]-'0')*10+gUI.Es[1]-'0';    gLED.AuOf.M= (gUI.Es[3]-'0')*10+gUI.Es[4]-'0';    gLED.AuOf.S= (gUI.Es[6]-'0')*10+gUI.Es[7]-'0';}void CallByTimeH(void){    int i=1,pro='2',max='3';    if(gUI.Es[i-1]>=pro) gUI.Es=(gUI.Key > 3)?(max)gUI.Key+'0');    else gUI.Es= gUI.Key+ '0';}void ShowTime(void){    RTC_Get(&gST);    RunMuDraw(0,0xff);}void DrawTime(void){        LCM_CLR();        GBstr(32,0,Mode_CP,"启动");        GBstr(48,0,Mode_CP,"关闭");        ShowTime();}
    3.时间显示函数。
    const sEditInPut InY={"x09x09x09x09  x01r  x03r",CallByTimeY,CallStrTimeY};const sEditInPut InH={"x02r:x05x09:x05x09",CallByTimeH,CallStrTimeH};const sEditInPut InO={"x02r:x05x09:x05x09",CallByTimeH,CallStrAon};const sEditInPut InC={"x02r:x05x09:x05x09",CallByTimeH,CallStrAof};const sWin        WinTime = {MuNum(MuTime),0,1,1,&DrawTime,(void*)0,MuTime};
    三、时钟显示效果
    file:///G:Tempksohtmlwps5D33.tmp.jpg
    file:///G:Tempksohtmlwps5D34.tmp.jpg
    file:///G:Tempksohtmlwps5D45.tmp.jpg
    GMT+8, 2024-12-19 07:12 , Processed in 0.118429 second(s), 17 queries , MemCache On.
