查看: 894|回复: 0
SIN210学习笔记__LED
    慵懒
    2016-10-17 12:07
  • 签到天数: 306 天
    发表于 2015-2-15 08:51:23 | 显示全部楼层 |阅读模式
    SIN210的LED硬件连接图如下
                       图3-0:SIN210  LED
            一、编写LED驱动
                     1、LED 驱动属于字符设备,我们进入 Linux 内核的字符设备驱动目录,进行编辑。
             2、新建文件 led.c 并对其进行编辑
             3、在文件中添加如下代码:
    • #include <linux/kernel.h>
    • #include <linux/types.h>
    • #include <linux/init.h>
    • #include <linux/serial_core.h>
    • #include <linux/gpio.h>
    • #include <linux/clk.h>
    • #include <linux/delay.h>
    • #include <linux/usb/ch9.h>
    • #include <linux/pwm_backlight.h>
    • #include <linux/spi/spi.h>
    • #include <linux/gpio_keys.h>
    • #include <asm/mach/arch.h>
    • #include <asm/mach/map.h>
    • #include <asm/setup.h>
    • #include <asm/mach-types.h>
    • #include <mach/map.h>
    • #include <mach/regs-mem.h>
    • #include <mach/regs-gpio.h>
    • #include <mach/gpio-bank.h>
    • #include <plat/s5pv210.h>
    • #include <plat/gpio-cfg.h>
    • #include <mach/gpio-bank-b.h>
    • #define LED_ON 0
    • #define LED_OFF 1
    • static unsigned long led_table [] = {
    • S5PV210_GPJ4(2),
    • S5PV210_GPJ4(1),
    • S5PV210_GPJ4(0),
    • S5PV210_GPJ3(7),
    • static unsigned long led_cfg_table [] = {
    • S3C_GPIO_OUTPUT,
    • S3C_GPIO_OUTPUT,
    • S3C_GPIO_OUTPUT,
    • S3C_GPIO_OUTPUT,
    • staticint led_open(struct inode *inode, struct file *file)
    • int i;
    • for(i = 0; i < 4; i++)
    • s3c_gpio_cfgpin(led_table, led_cfg_table);
    • return 0;
    • staticint led_ioctl(struct inode *indoe, struct file *file,
    • unsigned int cmd, unsigned long arg)
    • if (arg > 4)
    • return -EINVAL;
    • switch(cmd)
    • case LED_ON:
    • s3c_gpio_setpin(led_table[arg], 0);
    • printk("led[%d] on\r\n", arg);
    • break;
    • case LED_OFF:
    • s3c_gpio_setpin(led_table[arg], 1);
    • printk("led[%d] off\r\n", arg);
    • break;
    • default:
    • break;
    • return 0;
    • staticstruct file_operations leds_fops = {
    • .owner = THIS_MODULE,
    • .open
    • = led_open,
    • .ioctl
    • = led_ioctl,
    • staticint __init leds_init(void)
    • struct cdev *led_cdev;
    • structclass *led_class;
    • led_cdev = cdev_alloc();
    • cdev_init(led_cdev, &leds_fops);
    • led_cdev->owner = THIS_MODULE;
    • dev_t devid;
    • alloc_chrdev_region(&devid, 0, 1, "led");
    • cdev_add(led_cdev,devid,1);
    • led_class = class_create(THIS_MODULE,"led_class");
    • device_create(led_class, NULL, devid, NULL,"led");
    • printk("LEDS initialized.\n");
    • module_init(leds_init);
    • MODULE_AUTHOR("alexlee");
    • MODULE_DESCRIPTION("LEDS DRIVER");
    • MODULE_LICENSE("GPL");
            4、编辑好之后,
             修改 kernel/driver/char 目录下的 Makefile 文件,
             目的是将我们的 LED 驱动加入到内核中。
             5、在 Makefile 中添加 led.o
             6、这样我们的 LED 内核驱动就添加完毕了,重新编译内核后,LED 驱动就添加进了内核中。
            二、编写LED应用程序
                     1、创建 led_test.c 文件
             2、加入如下代码:
    • #include <stdio.h>
    • #include <string.h>
    • #include <sys/types.h>
    • #include <sys/stat.h>
    • #include <fcntl.h>
    • #include <linux/input.h>
    • #define IOCTL_LED_ON 0
    • #define IOCTL_LED_OFF 1
    • void usage(char *exename)
    • printf("Usage:\n");
    • printf("
    • %s <led_no> <on/off>\n", exename);
    • printf("
    • led_no = 1, 2, 3, 4\n");
    • int main(int argc, char **argv)
    • unsigned int led_no;
    • int fd = -1;
    • if (argc != 3)
    • goto err;
    • fd = open("/dev/led", O_RDWR);
    • if (fd < 0) {
    • printf("Can't open /dev/leds\n");
    • return -1;
    • led_no = strtoul(argv[1], 0, 0) - 1;
    • if (led_no > 5)
    • goto err;
    • if (!strcmp(argv[2], "on")) {
    • ioctl(fd, IOCTL_LED_ON, led_no);
    • } elseif (!strcmp(argv[2], "off")) {
    • ioctl(fd, IOCTL_LED_OFF, led_no);
    • } else {
    • goto err;
    • printf("IOCTL no = [%d],[%s]\r\n", led_no,argv[2]);
    • close(fd);
    • return 0;
    • err:
    • if (fd > 0)
    • close(fd);
    • usage(argv[0]);
    • return -1;
                              3、在同一个目录下,创建 Makefile 文件
                     4、输入如下代码:
    • # General Makefile
    • Exec := led_test
    • Obj := led_test.c
    • CC := arm-linux-gcc
    • $(Exec) : $(Obj)
    • $(CC) -o $@ $(Obj) $(LDLIBS$(LDLIBS-$(@)))
    • clean:
    • rm -vf $(Exec) *.elf *.o
                             5、在该目录下,直接 make,进行编译,生成可执行文件 led_test
                             6、应用程序使用方法:
                             输入命令格式:led_test [通道:1\2\3\4] [状态n\off]
                             例子:led_test 1 off 关闭通道 1
                                                     如下图所示
        图 3-1
        图 3-2
        图 3-3
                                                     每天进步一点点,每天都有新发现。走在学习的小路上。。。。。。
                            最后非常感谢sinlinx公司提供的sin210开发板。
    GMT+8, 2024-12-19 05:12 , Processed in 0.124113 second(s), 17 queries , MemCache On.
