查看: 1086|回复: 0
【二叔科技】52pi's BPI 1602 LCD 完整样板
    擦汗
    2015-3-6 13:14
  • 签到天数: 6 天
    发表于 2015-2-2 08:48:11 | 显示全部楼层 |阅读模式
    52pi老邓做了个LCD屏幕,
            这个屏幕是给BPI也就是香蕉派制作的,
            通过一个叫mcp23017的i2c芯片,
            扩展出了16个双向I/O,
            一个模块集成了三种功能,
            1、一块1602屏幕,蓝屏
            2、一个RGB-LED,亮瞎眼,盲打中
            3、五个独立按键
          #include    #include    #include    #include    #include    #include    int page=3;    int select=1;    int display;    int color=0;    pthread_t id;    void show()    {    time_t timep;    structtm *ptm;    digitalWrite ( 113, LOW);    digitalWrite ( 114, LOW);    digitalWrite ( 115, LOW);    lcdPosition(display,0,0);    switch(page)    {    case 0:    if (select==1)    {    lcdPrintf(display,">>1.Joytag Time ");    lcdPrintf(display," 2.Uncle's RGB ");    }    else    {    lcdPrintf(display," 1.Joytag Time ");    lcdPrintf(display,">>2.Uncle's RGB ");    }    break;    case 1:    time(&timep);    ptm=localtime(&timep);    lcdPrintf(display," d/d/d ",1900+ptm->tm_year, 1+ptm->tm_mon, ptm->tm_mday);    lcdPrintf(display," d:d:d ",ptm->tm_hour, ptm->tm_min, ptm->tm_sec);    break;    case 2:    lcdPrintf(display," **Uncle's RGB**");    lcdPrintf(display," Color: %d ",color);    digitalWrite ( 113, color&0x01);    digitalWrite ( 114, color&0x02);    digitalWrite ( 115, color&0x04);    color=(color+1)%8;    delay(400);    break;    case 3:    lcdPrintf(display,"RGB&1602 Module ");    lcdPrintf(display,"For BPI 52pi.net");    break;    }    delay(100);    }    void key(void)    {    int i;    while(1)    {    for(i=108;i<113;i++)    {    if (digitalRead(i)>0)    {    switch(i)    {    case 108:    page=0;    break;    case 109:    select=select%2+1;    break;    case 110:    page=3;    break;    case 111:    page=select;    break;    case 112:    select=select%2+1;    break;    }    delay(400);    }    }    delay(100);    }    }    int main()    {    wiringPiSetup();    mcp23017Setup (100, 0x20);    pthread_create(&id,NULL,(void *)key,NULL);    digitalWrite(107,1);    digitalWrite(101,0);    display=lcdInit(2,16,4,100,102,103,104,105,106,0,0,0,0);    lcdHome(display);    while(1)    show();    }
             首先是欢迎界面,点击右边单独的按键进入菜单
            一共两个选项,没做翻页,
            1、卓泰的时间
            2、二叔的LED
            上下键选择,右键选定,左键可以进入欢迎页面
            点击右边单独的键,退回到Menu
            千万不要直视,会死人的!
            运行办法:
    • gcc bpi1602.c -lwiringPi /opt/gpio-lib/WiringBPi_Beta_V2.0/devLib/lcd.o -o bpi1602
    • ./bpi1602
            二叔科技原创,关注二叔科技 https://2.liub.org
            二叔科技.创客空间 167153362
    GMT+8, 2024-12-19 05:16 , Processed in 0.114373 second(s), 16 queries , MemCache On.
