查看: 1201|回复: 0
SAMG53 Xplained Pro初体验
  • 签到天数: 981 天
    发表于 2014-10-30 20:25:43 | 显示全部楼层 |阅读模式
    首先,打开AS6.2,插上SAMG53 Xplained Pro,AS6就识别出SAMG53 Xplained Pro开发板
    点击
    选择CHIPID Example,点击OK,等待载入工程,编译F7。
    编译完毕后,调试下载F5
    点击Continue,选择调试接口
    再次点击调试F5,打开串口助手,设置
    *   - 115200 bauds
    *   - 8 bits of data
    *   - No parity
    *   - 1 stop bit
    *   - No flow control
    按板子上的Reset按键,出现结果
    -- CHIPID Example --
    -- SAMG53_XPLAINED_PRO --
    -- Compiled: Oct 30 2014 19:19:03 --
    Version        0x8.
    Embedded Processor        Cortex-M4.
    Nonvolatile program memory size        512K bytes.
    Second nonvolatile program memory size        None.
    Internal SRAM size        96K bytes.
    Architecture identifier        AT91SAMG53/SAMG54 Series.
    Nonvolatile program memory type        Embedded Flash Memory.
    Extended chip ID does not exist.
    GMT+8, 2024-12-18 23:59 , Processed in 0.118956 second(s), 16 queries , MemCache On.
