查看: 977|回复: 0
Banana PI Pro 增强版出来了
  • 签到天数: 1368 天
    发表于 2014-10-18 21:44:36 | 显示全部楼层 |阅读模式
    Hardware Specification of Banana ProTM
    Allwinner® A20(sun 7i)
    ARM® Cortex™-A7 Dual-Core1GHz (ARM v7 instruction set)
    Mali400MP2 Complies with OpenGL ES 2.0/1.1 (hardware acceleration support)
    1GB DDR3 (shared with GPU)
    5V @ 2A via MicroUSB (DC in Only) and/or MicroUSB (OTG)
    AXP209
    Features
    40 Pins Header,28×GPIO,  some of which can be used for specific functions including UART, I2C,  SPI, PWM, CAN, I2S, SPDIF, LRADC, ADC, LINE-IN,FM-IN,HP-IN.
    10/100/1000Mbps ethernet (Realtek RTL8211E/D)
    WiFi 802.11 b/g/n
    Optional
    MicroSD (TF) card,SATA 2.0
    Supports multi-channel HD display:HDMI 1.4 (Type A - full)LVDS/RGB/CPU display interface (DSI) for raw LCD panelsComposite video (PAL and NTSC) (via 3.5 mm TRRS jack shared with audio out)
    11 HDMI resolutions from 640×480 to 1920×1080 plus various PAL and NTSC standards
    HD H.264 2160p video decodingMutil-format  FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264  high profile 1080p@30fps or 720p@60fps encoding
    HDMI,analog audio (via 3.5 mm TRRS jack shared with composite video out),I2S audio (also potentially for audio input)
    Parallel 8-bit camera interface
    On board micphone
    2 USB 2.0 host, 1 USB 2.0 OTG (all direct from A20 chip)
    Reset buttonPower buttonU-boot button
    Power status led (red)Ethernet status led (blue)User defined led (green)
    IR reciever
    Interface definition
    SizeWeight
    GMT+8, 2024-12-18 21:08 , Processed in 0.107698 second(s), 15 queries , MemCache On.
