查看: 1183|回复: 0
pcDuino与Arduino通过xbee模块实现双灯互控
    发表于 2013-6-3 18:15:31 | 显示全部楼层 |阅读模式
    操作演示如下:
    一、 I2C的连线方式如图
    正面
    背面
    二、线路连接好之后,打开LXTerminal,进入目录,如图所示
    三.打开代码,见下图
    四、、代码打开成功之后,输入make进行编译,出现可执行文件,如下图
    五、 运行代码,简单快捷的I2C通信就能在您的Pcduino上实现了
    /*This sketch prints "Hello World!" to the LCDand shows the time.The circuit:* 5V to Arduino 5V pin* GND to Arduino GND pin* SCL to Analog #5* SDA to Analog #4*/ include the library code:#include <core.h>#include "Wire.h"#include "LiquidCrystal.h"// Connect via i2c, default address #0 (A0-A2 not jumpered)LiquidCrystal lcd(0);void setup() {// set up the LCD's number of rows and columns:lcd.begin(16, 2);// Print a message to the LCD.lcd.print("hello, world!");}void loop() {// set the cursor to column 0, line 1// (note: line 1 is the second row, since counting begins with 0):lcd.setCursor(0, 1);// print the number of seconds since reset:lcd.print(millis()/1000);lcd.setBacklight(HIGH);delay(500);lcd.setBacklight(LOW);delay(500);}
    GMT+8, 2025-2-28 10:00 , Processed in 0.110257 second(s), 17 queries , MemCache On.
