查看: 1430|回复: 0
明远智睿R16 android4.4 常见问题参考手册
    无聊
    2016-8-19 09:36
    发表于 2019-3-18 16:39:44 | 显示全部楼层 |阅读模式
    1  R16 android4.4 常见问题
    1.1  在内核中添加spi驱动
    $cd lichee/linux-3.4 $make ARCH=arm menuconfig $lunch astar_parrot-tina
    $make kernel_menuconfig
    Device Drivers ---> SPI support ---> <*> User mode SPI device driver support
    修改
    lichee/tools/pack/chips/sun8iw5p1/configs/evb-30/sys_config.fex
    [spi_board0]
    modalias      = "at25df641"
    sflash_size   = 32
    max_speed_hz  = 50000000
    bus_num       = 0
    chip_select   = 0
    mode          = 0
    修改成
    [spi_board0]
    modalias      = "spidev"
    sflash_size   = 32
    bus_num       = 0
    chip_select   = 0
    mode          = 0
    1.2  以太网不能用
    在内核增加驱动
    Device Drivers --->
       Network device support --->
           USB Network Adapters --->
                  <*> Multi-purpose USB Networking Frameworksuch as cable modems)
                  <*> SMSC LAN95XX based USB 2.0 10/100 ethernet devices
    1.3  默认勾选使用以太网
    1)在frameworks\base\packages\SettingsProvider\res\values\default.xml
      <bool name="def_ethernet_on">true</bool>  改成true
      <bool name="def_ethernet_mode">true</bool> 添加以下这两句
         <bool name="def_ethernet_conf">true</bool>
          <string name="def_ethernet_ifname" translatable="false">eth0</string>
    2)在frameworks\base\packages\SettingsProvider\src\com\android\providers\settings\DatabaseHelper.java 添加
           loadBooleanSetting(stmt, Settings.Global.ETHERNET_CONF, R.bool.def_ethernet_conf)
           loadStringSetting(stmt, Settings.Global.ETHERNET_IFNAME, R.string.def_ethernet_ifname)
    GMT+8, 2025-1-9 21:54 , Processed in 0.107932 second(s), 15 queries , MemCache On.
