对于熟悉ROS的朋友们来说,图像的topic有了,我们就可以开始自己想干的事情了。这里我创建一个名为hs_image_sub的package来处理角蜂鸟的图像,图像的topic 名字为上一篇提到的:/hs/camera/image_raw. 也是我们打开rqt_image_view窗口看到的东西。
这篇博客主要是利用opencv来获取角蜂鸟图像,然后做一个阈值处理,并且打开窗口显示原图和处理后的图像。有了opencv想做什么处理都可以了,这篇文章主要是教大家在ROS里获取并调用图像。
- cd ~/catkin_ws/src
- catkin_create_pkg hs_image_sub roscpp sensor_msgs cv_bridge
复制代码 然后
- cd ~/catkin_ws/src/hs_image_sub/src
- touch hs_image_sub_node.cpp
- gedit hs_image_sub_node.cpp
复制代码 填入以下代码
- #include <ros/ros.h>
- #include <sensor_msgs/Image.h>
- #include <sensor_msgs/image_encodings.h>
- #include <image_transport/image_transport.h>
- #include <cv_bridge/cv_bridge.h>
- // OpenCV
- #include <opencv2/opencv.hpp>
- #include <opencv2/imgproc/imgproc.hpp>
- #include <opencv2/highgui/highgui.hpp>
- using namespace std;
- using namespace cv;
- const string Original_winName = "Original Image";
- const string Thresh_winName = "Threshed Image";
- Mat cameraFeed;
- Mat HSV;
- Mat threshold_ori;
- void rgbCallback(const sensor_msgs::ImageConstPtr& msg)
- cv_bridge::CvImageConstPtr cv_ptr;
- try
- cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::BGR8); // Caution the type here.
- catch (cv_bridge::Exception& ex)
- ROS_ERROR("cv_bridge exception in rgbcallback: %s", ex.what());
- exit(-1);
- cameraFeed = cv_ptr->image.clone();
- cvtColor(cameraFeed,HSV,COLOR_BGR2HSV);
- inRange(HSV,Scalar(0,133,0),Scalar(21,256,256),threshold_ori);
- //show frames
- imshow(Original_winName,cameraFeed);
- imshow(Thresh_winName,threshold_ori);
- //delay 10ms so that screen can refresh.
- //image will not appear without this waitKey() command
- waitKey(10);
- int main(int argc, char *argv[])
- ros::init(argc, argv, "HornedSungemGrabber");
- ros::NodeHandle n;
- // topic name of HornedSungem
- ros::Subscriber rgb_sub = n.subscribe("/hs/camera/image_raw", 1, rgbCallback);
- ROS_INFO("Subscribe to the HS color image topic.");
- ros::spin();
- return 0;
复制代码代码比较简单,主要是订阅图像源,调用回调函数做阈值处理。 注意这里的topic name 和回调函数里的格式:BGR8,只能是这个。
保存,然后 cd ~/catkin_ws/src/hs_image_sub/ gedit CMakeLists.txt 全选,替换为以下内容 - cmake_minimum_required(VERSION 2.8.3)
- project(hs_image_sub)
- find_package(OpenCV REQUIRED)
- find_package(catkin REQUIRED COMPONENTS
- cv_bridge
- roscpp
- sensor_msgs
- catkin_package(
- # INCLUDE_DIRS include
- # LIBRARIES hs_image_sub
- # CATKIN_DEPENDS cv_bridge roscpp sensor_msgs
- # DEPENDS system_lib
- include_directories(
- # include
- ${catkin_INCLUDE_DIRS}
- add_executable(${PROJECT_NAME}_node src/hs_image_sub_node.cpp)
- target_link_libraries(${PROJECT_NAME}_node
- ${catkin_LIBRARIES} ${OpenCV_LIBS}
复制代码 接着编译
- cd ~/catkin_ws
- catkin_make
看到编译成功,运行角蜂鸟ROS的官方程序,启动相机发布图像源,来供我们这里的程序调用
- roslaunch horned_sungem_launch hs_camera.launch cnn_type:=googlenet camera:=hs pixels:=360
- rosrun hs_image_sub hs_image_sub_node
有了opencv想做什么处理都可以了比如追踪
作者:yaked
来源:CSDN
相关文章阅读
(一)开箱及软件开发环境配置
(二)人工智能深度体验
(三)ROS案例
(四)ROS下订阅并处理图像
