查看: 1872|回复: 0
LVDS屏幕只有背光如何解决
  • 签到天数: 64 天
    [LV.6]常住居民II
    发表于 2019-2-15 17:29:35 | 显示全部楼层 |阅读模式
    问:LVDS屏幕uboot和kernel都没显示,只有背光
    答:run load_scr; source;
    setenv disp_fb0_lvds1   "video=mxcfb0:dev=ldb,LDB-WXGA,if=RGB666 ldb=sin1"
    setenv display      "${disp_fb0_lvds1}"
    saveenv; boot
    烧录后环境变量设置
    问:我这个屏的参数U-BOOT班级文件配置:
            .bus    = -1,
            .addr   = 0,
            .pixfmt = IPU_PIX_FMT_RGB666,
            .detect = NULL,
            .enable = enable_lvds,
            .mode   = {
                    .name           = "MYZR-WSVGA",
                    .refresh        = 60,
                    .xres           = 1280,
                    .yres           = 800,
                    .pixclock       = 14507,
                    .left_margin    = 34,
                    .right_margin   = 34,
                    .upper_margin   = 3,
                    .lower_margin   = 3,
                    .hsync_len      = 60,
                    .vsync_len      = 10,
                    .sync           = FB_SYNC_EXT,
                    .vmode          = FB_VMODE_NONINTERLACED
    设备树文件配置:
    lvds-channel@0 {
                    fsl,data-mapping = "spwg";
                    fsl,data-width = <18>;
                    status = "okay";
                    display-timings {
                            native-mode = <&timing0>;
                            timing0: hsd100pxn1 {
                                    clock-frequency = <68930000>;
                                    hactive = <1280>;
                                    vactive = <800>;
                                    hback-porch = <34>;
                                    hfront-porch = <34>;
                                    vback-porch = <3>;
                                    vfront-porch = <3>;
                                    hsync-len = <60>;
                                    vsync-len = <10>;
    屏的参数先不改了吗?
    答:http://wiki.myzr.com.cn/index.ph ... ool-v2.6_User_Guide
    MfgTool-MYIMX6A9-L3.0.35-Base.svn257.20181228.rar
    有解压到到当前文件夹吗?
    GMT+8, 2025-1-12 23:38 , Processed in 0.119040 second(s), 15 queries , MemCache On.
