• MCO from ST-LINK: MCO output of ST-LINK MCU is used as input clock. This
frequency cannot be changed, it is fixed at 8 MHz and connected to PF0/PD0/PH0-
OSC_IN of STM32 microcontroller.
我手头有片Nucleo STM32F411RE BOARD,外部晶振8MZ,固定不能改,我在Keil C/C++ 页面定义:USE_STDPERIPH_DRIVER,STM32F411xE,我移值标准固件库,
SYSTEM_STMF32F4XX.H,下列判断STM32F411xE关键词有效,就会执行这句 #define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz
就跟原厂定义8MHZ不同,我需要调整为: HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz 8MHZ,还是不用理它!!!!
#if defined(STM32F40_41xxx) || defined(STM32F427_437xx) || defined(STM32F429_439xx) || defined(STM32F401xx) || defined(STM32F411xE)
#if !defined (HSE_VALUE)
#endif /* HSE_VALUE */
#elif defined(STM32F446xx)
#define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
#endif /* STM32F40_41xxx || STM32F427_437xx || STM32F429_439xx || STM32F401xx || STM32F411xE */
