查看: 1843|回复: 0
MY-IMX6-EK200 Linux-4.1.15 测试手册(2)
    无聊
    2016-8-19 09:36
    发表于 2019-1-21 11:07:10 | 显示全部楼层 |阅读模式
    【接上一章节明远智睿MY-IMX6-EK200 Linux-4.1.15 测试手册(1)】
    8.2  UART3
    位置:J1:11,13
    设备:/dev/ttymxc2
    测试指令
    # /my-demo/linux-4.1.15/MY_SERIAL_TEST_L4115_MYIMX6A9.out /dev/ttymxc2"www.myzr.com.cn"
    Welcome to TTYtest
    Send test data
    read char is w
    read char is w
    read char is w
    read char is .
    read char is m
    read char is y
    read char is z
    read char is r
    read char is .
    read char is c
    read char is o
    read char is m
    read char is .
    read char is c
    read char is n
    Read Test Data finished,Read Test Data is
    8.3  UART4
    位置:J1:15,17
    设备:/dev/ttymxc3
    测试指令
    # /my-demo/linux-4.1.15/MY_SERIAL_TEST_L4115_MYIMX6A9.out /dev/ttymxc3 "www.myzr.com.cn"
    Welcome to TTYtest
    Send test data
    read char is w
    read char is w
    read char is w
    read char is .
    read char is m
    read char is y
    read char is z
    read char is r
    read char is .
    read char is c
    read char is o
    read char is m
    read char is .
    read char is c
    read char is n
    8.4  UART5
    位置:J1:16,18
    设备:/dev/ttymxc4
    测试指令
    # /my-demo/linux-4.1.15/MY_SERIAL_TEST_L4115_MYIMX6A9.out /dev/ttymxc4 "www.myzr.com.cn"
    Welcome to TTYtest
    Send test data
    read char is w
    read char is w
    read char is w
    read char is .
    read char is m
    read char is y
    read char is z
    read char is r
    read char is .
    read char is c
    read char is o
    read char is m
    read char is .
    read char is c
    read char is n
    9  CAN 测试
    测试准备
    CAN1的CAN_L与CAN2的CAN_L连接;将CAN1的CAN_H与CAN2的CAN_H连接。
    配置 CAN1 (can0)
    # ip link set can0 up type can bitrate 125000
    配置 CAN2 (can1)
    # ip link set can1 up type can bitrate 125000
    CAN1 (can0) 后台接收
    # candump can0 &
    CAN2 (can1) 发送数据
    # cansend can1 1F334455#1122334455667788
    10  SPI测试10.1  ECSPI1 测试
    位置:J7:7,9
    测试设备:/dev/spidev0.1
    测试指令
    # /my-demo/linux-4.1.15/MY_SPIDEV_TEST_L4115_MYIMX6A9.out -D /dev/spidev0.0
    spi mode: 0
    bits per word: 8
    max speed: 500000 Hz (500 KHz)
    FF FF FF FF FF FF
    40 00 00 00 00 95
    FF FF FF FF FF FF
    FF FF FF FF FF FF
    FF FF FF FF FF FF
    DE AD BE EF BA AD
    F0 0D
    10.2  ECSPI2 测试
    位置:J7: 8,10
    测试设备:/dev/spidev1.0
    测试指令
    # /my-demo/linux-4.1.15/MY_SPIDEV_TEST_L4115_MYIMX6A9.out -D /dev/spidev1.0
    spi mode: 0
    bits per word: 8
    FF FF FF FF FF FF
    40 00 00 00 00 95
    FF FF FF FF FF FF
    FF FF FF FF FF FF
    FF FF FF FF FF FF
    DE AD BE EF BA AD
    F0 0D
    11  Watchdog 测试11.1  超时复位测试
    # /unit_tests/wdt_driver_test.out 10 15 1
    Starting wdt_driver (timeout: 10, sleep: 15, test: write)
    Trying to set timeout value=10 seconds
    The actual timeout was set to 10 seconds
    Now reading back -- The timeout is 10 seconds
    U-Boot 2016.03-svn270 (Oct 09 2018 - 14:44:15 +0800)
    CPU:   Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
    CPU:   Extended Commercial temperature grade (-20C to 105C) at 45C
    Reset cause: WDOG
    Board: MYZR i.MX6 Evaluation Kit
    11.2  喂狗测试
    # /unit_tests/wdt_driver_test.out 4 2 1 &
    [1] 748
    Starting wdt_driver (timeout: 4, sleep: 2, test: write)
    Trying to set timeout value=4 seconds
    The actual timeout was set to 4 seconds
    Now reading back -- The timeout is 4 seconds
    12  RTC 测试
    查看当前系统时钟
    # date
    Wed Sep 26 00:27:45 UTC 2018
    查看当前RTC芯片时钟
    # hwclock
    Wed Sep 26 00:28:01 2018  0.000000 seconds
    设置系统时钟,并同步到RTC芯片
    # date -s "2018-09-21 12:34:56"
    Fri Sep 21 12:34:56 UTC 2018
    将系统时钟写入硬件时钟
    # hwclock -w
    断电重启评估板
    查看当前系统时钟
    # date
    Fri Sep 21 12:36:11 UTC 2018
    查看当前RTC芯片时钟
    # hwclock
    Fri Sep 21 12:36:16 2018  0.000000 seconds
    【下章节为明远智睿MY-IMX6-EK200 Linux-4.1.15 测试手册(3)】
    GMT+8, 2025-1-10 05:41 , Processed in 0.111945 second(s), 15 queries , MemCache On.
