查看: 1909|回复: 0
MY-IMX6-EK200 Linux-4.1.15 测试手册(1)
    无聊
    2016-8-19 09:36
    发表于 2019-1-18 15:39:38 | 显示全部楼层 |阅读模式
    明远智睿MY-IMX6-EK200 Linux-4.1.15 测试手册(1)
    1  测试环境
    开发板型号:MYIMX6EK200-6Q-2G-16G
    内核版本:Linux-4.1.15
    文件系统:L4115-fsl-image-qt5-myimx6a9.tar.bz2
    2  网口测试
    2.1  ETH0
    关闭 ETH1
    # ifconfig eth1 down
    配置 ETH0
    # ifconfig eth0 192.168.137.81
    使用 ping 进行测试
    # ping 192.168.137.99 -c 2 -w 4
    PING 192.168.137.99 (192.168.137.99) 56(84) bytes of data.
    64 bytes from 192.168.137.99: icmp_seq=1 ttl=128 time=0.811 ms
    64 bytes from 192.168.137.99: icmp_seq=2 ttl=128 time=0.324 ms
    --- 192.168.137.99 ping statistics ---
    2 packets transmitted, 2 received, 0% packet loss, time 999ms
    rtt min/avg/max/mdev = 0.324/0.567/0.811/0.244 ms
    2.2  ETH1 测试
    关闭 ETH0
    # ifconfig eth0 down
    配置 ETH0
    # ifconfig eth1 192.168.137.82
    使用 ping 进行测试
    64 bytes from 192.168.137.99: icmp_seq=1 ttl=128 time=1.54 ms
    64 bytes from 192.168.137.99: icmp_seq=2 ttl=128 time=4.03 ms
    2 packets transmitted, 2 received, 0% packet loss, time 1001ms
    rtt min/avg/max/mdev = 1.546/2.792/4.039/1.247 ms
    3  USB 测试
    插入U盘
    usb 1-1.2: new high-speed USB device number 5 using ci_hdrc
    usb-storage 1-1.2:1.0: USB Mass Storage device detected
    scsi host1: usb-storage 1-1.2:1.0
    scsi 1:0:0:0: Direct-Access     TOSHIBA  TransMemory      1.00 PQ: 0 ANSI: 4
    sd 1:0:0:0: [sda] 15148608 512-byte logical blocks: (7.75 GB/7.22 GiB)
    sd 1:0:0:0: [sda] Write Protect is off
    sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
    sda: sda4
    sd 1:0:0:0: [sda] Attached SCSI removable disk
    拔出U盘
    usb 1-1.2: USB disconnect, device number 5
    4  SD卡测试
    插入SD卡
    mmcblk2: mmc2:1234 SA02G 1.83 GiB
    mmcblk2:
    弹出SD卡
    mmc2: card 1234 removed
    5  标准 GPIO 测试
    EIM_A25__GPIO5_IO02 J7:4
    EIM_D23__GPIO3_IO23 J1:12
    EIM_D28__GPIO3_IO28 J1:8
    EIM_D29__GPIO3_IO29 J1:10
    EIM_D30__GPIO3_IO30 J21:12
    SD1_CLK__GPIO1_IO20 J4:8
    SD1_DAT0__GPIO1_IO16 J14:18
    SD2_CMD__GPIO1_IO11 J4:13
    SD2_CLK__GPIO1_IO10 J4:7
    SD2_DAT0__GPIO1_IO15 J4:3
    SD2_DAT1__GPIO1_IO14 J4:5
    SD2_DAT2__GPIO1_IO13 J4:9
    SD2_DAT3__GPIO1_IO12 J4:11
    SD3_DAT5__GPIO7_IO00 J21:11
    GPIO_19__GPIO4_IO05 J7:3
    # OUT_IO_NUMBER=85
    # echo ${OUT_IO_NUMBER} > /sys/class/gpio/export
    # echo out > /sys/class/gpio/gpio${OUT_IO_NUMBER}/direction
    # echo 0 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value
    # echo 1 > /sys/class/gpio/gpio${OUT_IO_NUMBER}/value
    6  GPIO-LED 测试
    led-heartbeat
    说明:led-heartbeat 连接到 D8,系统启动后可以看到 D8 在有规律的闪烁。
    led-timer
    说明:led-timer 连接到 D9,系统启动后可以看到 D9 在有规律的闪烁。
    更改 led-timer (D9) 灭的时间
    # echo 1000 > /sys/class/leds/led-timer/delay_off
    更改 led-timer (D9) 亮的时间
    # echo 2000 > /sys/class/leds/led-timer/delay_on
    led-default
    使 led-default (D7) 灭
    echo 0 > /sys/class/leds/default/brightness
    使 led-default (D7) 常亮
    echo 1 > /sys/class/leds/default/brightness
    led-gpio
    使 led-gpio (D10) 灭
    echo 0 > /sys/class/leds/gpio/brightness
    使 led-gpio (D10) 常亮
    echo 1 > /sys/class/leds/gpio/brightness
    7  GPIO-KEY 测试
    运行 evtest 准备测试
    # evtest
    No device specified, trying to scan all of /dev/input/event*
    Available devices:
    /dev/input/event0:  WM8962 Beep Generator
    /dev/input/event1:  gpio-keys
    Select the device event number [0-1]:
    选择 gpio-keys 所对应的序号
    Select the device event number [0-1]: 1
    Input driver version is 1.0.1
    Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
    Input device name: "gpio-keys"
    Supported events:
      Event type 0 (EV_SYN)
      Event type 1 (EV_KEY)
        Event code 114 (KEY_VOLUMEDOWN)
        Event code 115 (KEY_VOLUMEUP)
        Event code 116 (KEY_POWER)
    Properties:
    Testing ... (interrupt to exit)
    按动开发板上的按键
    Event: time 1537921332.815219, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 1
    Event: time 1537921332.815219, -------------- SYN_REPORT ------------
    Event: time 1537921332.985211, type 1 (EV_KEY), code 114 (KEY_VOLUMEDOWN), value 0
    Event: time 1537921332.985211, -------------- SYN_REPORT ------------
    Event: time 1537921335.355204, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 1
    Event: time 1537921335.355204, -------------- SYN_REPORT ------------
    Event: time 1537921335.535203, type 1 (EV_KEY), code 115 (KEY_VOLUMEUP), value 0
    Event: time 1537921335.535203, -------------- SYN_REPORT ------------
    Event: time 1537921337.375207, type 1 (EV_KEY), code 116 (KEY_POWER), value 1
    Event: time 1537921337.375207, -------------- SYN_REPORT ------------
    Event: time 1537921337.535204, type 1 (EV_KEY), code 116 (KEY_POWER), value 0
    Event: time 1537921337.535204, -------------- SYN_REPORT ------------
    8  串口测试8.1  UART2
    位置:J1:7,9
    设备:/dev/ttymxc1
    测试指令
    # /my-demo/linux-4.1.15/MY_SERIAL_TEST_L4115_MYIMX6A9.out /dev/ttymxc1
    Welcome to TTYtest
    Send test data
    read char is w
    read char is w
    read char is w
    read char is .
    read char is m
    read char is y
    read char is z
    read char is r
    read char is .
    read char is c
    read char is o
    read char is m
    read char is .
    read char is c
    read char is n
    Read Test Data finished,Read Test Data is
    【下章节为明远智睿MY-IMX6-EK200 Linux-4.1.15 测试手册2)】
    GMT+8, 2025-1-10 06:16 , Processed in 0.119506 second(s), 15 queries , MemCache On.
