查看: 2145|回复: 1
VS-RK3399在android下面把声音放到最大时候,播放器自动退出...
  • 签到天数: 53 天
    [LV.5]常住居民I
    发表于 2018-11-27 10:47:20 | 显示全部楼层 |阅读模式
    VS-RK3399在android下面把声音放到最大时候,播放器自动退出问题
    VS-RK3399 在android下面把声音放到最大时候,播放器自动退出问题。使用系统自带的Video.apk播放,当声音放到最大时候,播放视频过一会后自动退出,影响ADC采样,干扰了物理键,返回一个back键出来,刚好Video.apk有处理返回键的相应,导致播放时候退出。
    修改方法:
    \kernel\arch\arm64\boot\dts\rockchip\rk3399-android.dtsi
    rk_key: rockchip-key {
                    compatible = "rockchip,key";
                    status = "okay";
                    io-channels = <&saradc 1>;
                    vol-up-key {
                            linux,code = <115>;
                            label = "volume up";
                            rockchip,adc_value = <1>;
                    vol-down-key {
                            linux,code = <114>;
                            label = "volume down";
                            rockchip,adc_value = <170>;
                    power-key {
                            gpios = <&gpio0 5 GPIO_ACTIVE_LOW>;
                            linux,code = <116>;
                            label = "power";
                            gpio-key,wakeup;
    #if 0
                    menu-key {
                            linux,code = <59>;
                            label = "menu";
                            rockchip,adc_value = <746>;
                    home-key {
                            linux,code = <102>;
                            label = "home";
                            rockchip,adc_value = <355>;
                    back-key {
                            linux,code = <158>;
                            label = "back";
                            rockchip,adc_value = <560>;
                    camera-key {
                            linux,code = <212>;
                            label = "camera";
                            rockchip,adc_value = <450>;
    #endif
    按上面操作,把back键去掉
  • 签到天数: 385 天
    发表于 2018-11-28 16:28:10 | 显示全部楼层
    GMT+8, 2024-11-19 22:28 , Processed in 0.137919 second(s), 18 queries , MemCache On.
