查看: 3084|回复: 1
VS-RK3288板卡RK3399 关于GPU和CPU性能
  • 签到天数: 53 天
    [LV.5]常住居民I
    发表于 2018-11-26 10:09:41 | 显示全部楼层 |阅读模式
    为了VS-RK3399达到最好的性能,需要将CPU 及GPU 定频,特别是GPU。
    CPU 定频方法参考:
    cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
    echo "userspace" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
    echo "1416000" > /sys/devices/system/cpu/cpu0/cpufreq/scaling_setspeed
    echo "userspace" > /sys/devices/system/cpu/cpu1/cpufreq/scaling_governor
    echo "1416000" > /sys/devices/system/cpu/cpu1/cpufreq/scaling_setspeed
    echo "userspace" > /sys/devices/system/cpu/cpu2/cpufreq/scaling_governor
    echo "1416000" > /sys/devices/system/cpu/cpu2/cpufreq/scaling_setspeed
    echo "userspace" > /sys/devices/system/cpu/cpu3/cpufreq/scaling_governor
    echo "1416000" > /sys/devices/system/cpu/cpu3/cpufreq/scaling_setspeed
    echo "userspace" > /sys/devices/system/cpu/cpu4/cpufreq/scaling_governor
    echo "1800000" > /sys/devices/system/cpu/cpu4/cpufreq/scaling_setspeed
    echo "userspace" > /sys/devices/system/cpu/cpu5/cpufreq/scaling_governor
    echo "1800000" > /sys/devices/system/cpu/cpu5/cpufreq/scaling_setspeed
    GPU 定频方法参考:
    echo "userspace" >/sys/devices/platform/ff9a0000.gpu/devfreq/ff9a0000.gpu/governor
    echo "800000000" >/sys/devices/platform/ff9a0000.gpu/devfreq/ff9a0000.gpu/userspace/set_freq
    cat /sys/devices/platform/ff9a0000.gpu/devfreq/ff9a0000.gpu/cur_freq
    GMT+8, 2024-11-19 22:45 , Processed in 0.129235 second(s), 18 queries , MemCache On.
