编译主机环境- 编译主机CPU架构:64位
- 编译主机系统:Linux
- Linux发行版:Ubuntu
- Ubuntu版本号:14.04.5
- Ubuntu版本类型:桌面版
- Ubuntu系统类型:x86-64
安装 SDK下载 SDK 在网盘“2.3_系统_Linux-4.1.15/03_工具”目录中下载 SDK 包文件。
- MY-IMX6-EK140、MY-IMX-EK40P:
fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa7hf-neon-toolchain-4.1.15-2.1.0.sh
- MY-IMX6-EK200、MY-IMX-EK314、MY-IMX-EK336:
fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa9hf-neon-toolchain-4.1.15-2.1.0.sh 准备安装- 把下载的包文件复制到编译主机中。
- 修改预安装目录的权限
$ chmod 777 /opt -R SDK 安装(MY-IMX6-EK140、MY-IMX-EK40P)$ ./fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa7hf-neon-toolchain-4.1.15-2.1.0.sh Freescale i.MX Release Distro SDK installer version 4.1.15-2.1.0 ================================================================ Enter target directory for SDK (default: /opt/fsl-imx-fb/4.1.15-2.1.0): You are about to install the SDK to "/opt/fsl-imx-fb/4.1.15-2.1.0". Proceed[Y/n]? Y Extracting SDK.......................................................................................................................................................done Setting it up...done SDK has been successfully set up and is ready to be used. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g. $ . /opt/fsl-imx-fb/4.1.15-2.1.0/environment-setup-cortexa7hf-neon-poky-linux-gnueabi- 创建 oe-device-extra.pri 文件防止 qmake 时报错
$ touch /opt/fsl-imx-fb/4.1.15-2.1.0/sysroots/cortexa7hf-neon-poky-linux-gnueabi/usr/lib/qt5/mkspecs/oe-device-extra.pri SDK 安装(MY-IMX6-EK200、MY-IMX-EK314、MY-IMX-EK336)$ ./fsl-imx-fb-glibc-x86_64-meta-toolchain-qt5-cortexa9hf-neon-toolchain-4.1.15-2.1.0.sh Freescale i.MX Release Distro SDK installer version 4.1.15-2.1.0 ================================================================ Enter target directory for SDK (default: /opt/fsl-imx-fb/4.1.15-2.1.0): You are about to install the SDK to "/opt/fsl-imx-fb/4.1.15-2.1.0". Proceed[Y/n]? Y Extracting SDK..............................................................................................................................................................done Setting it up...done SDK has been successfully set up and is ready to be used. Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g. $ . /opt/fsl-imx-fb/4.1.15-2.1.0/environment-setup-cortexa9hf-neon-poky-linux-gnueabi- 创建 oe-device-extra.pri 文件防止 qmake 时报错
touch /opt/fsl-imx-fb/4.1.15-2.1.0/sysroots/cortexa9hf-neon-poky-linux-gnueabi/usr/lib/qt5/mkspecs/oe-device-extra.pri
编译 QT 应用程序配置交叉编译工具环境变量- MY-IMX6-EK140、MY-IMX-EK40P
$ source /opt/fsl-imx-fb/4.1.15-2.1.0/environment-setup-cortexa7hf-neon-poky-linux-gnueabi- MY-IMX6-EK200、MY-IMX-EK314、MY-IMX-EK336
$ source /opt/fsl-imx-fb/4.1.15-2.1.0/environment-setup-cortexa9hf-neon-poky-linux-gnueabi 准备编译工程- 下载 QT Demo 源码包
在网盘“2.3_系统_Linux-4.1.15/05_MY-Demo”中下载 myzr-qt5-demo.tar 并复制到编译主机中。 - 解压 QT Demo 源码包
$ tar xf myzr-qt5-demo.tar$ cd myzr-qt5-demo/AboutUs$ qmake 编译工程- MY-IMX6-EK140、MY-IMX-EK40P
$ make /opt/fsl-imx-fb/4.1.15-2.1.0/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/uic widget.ui -o ui_widget.h ...... arm-poky-linux-gnueabi-g++ -march=armv7ve -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a7 --sysroot=/opt/fsl-imx-fb/4.1.15-2.1.0/sysroots/cortexa7hf-neon-poky-linux-gnueabi -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o AboutUs main.o widget.o qrc_source.o moc_widget.o -lQt5Widgets -lQt5Gui -lQt5Core -lGLESv2 -lEGL -lpthread- MY-IMX6-EK200、MY-IMX-EK314、MY-IMX-EK336
$ make /opt/fsl-imx-fb/4.1.15-2.1.0/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/uic widget.ui -o ui_widget.h ...... arm-poky-linux-gnueabi-g++ -march=armv7-a -mfpu=neon -mfloat-abi=hard -mcpu=cortex-a9 --sysroot=/opt/fsl-imx-fb/4.1.15-2.1.0/sysroots/cortexa9hf-neon-poky-linux-gnueabi -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed -Wl,-O1 -o AboutUs main.o widget.o qrc_source.o moc_widget.o -lQt5Widgets -lQt5Gui -lQt5Core -lGLESv2 -lEGL -lpthread 目标可执行文件$ file AboutUs AboutUs: ELF 32-bit LSB executable, ARM, EABI5 version 1 (GNU/Linux), dynamically linked, interpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 2.6.32, BuildID[sha1]=38367b0a95b8fe7402e2377c11626581c07f9c9d, not stripped
运行目标程序1.把编译生成的 AboutUs 复制到评估板上。
2.运行目标程序
$ ./AboutUs -platform eglfs -plugin evdevtouch:/dev/input/event0 QEglFSVivIntegration will set environment variable FB_MULTI_BUFFER=2 to enable double buffering and vsync. If this is not desired, you can override this via: export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1 Unable to query physical screen size, defaulting to 100 dpi. To override, set QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT (in millimeters).
