查看: 9455|回复: 7
如何在pcDuino上运行simpleCV
 关闭 [复制链接]
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2013-3-25 11:36:00 | 显示全部楼层 |阅读模式
    这篇文章里我们会演示如何在pcDuino上运行simpleCV,
    在开始之前要确保有一个兼容USB 摄像头的万能接头,还要在这里下载万能USB摄像头驱动程序的内核补丁。在pcDuino终端上下载这个补丁后,用以下命令解压:
    1. $ tar -zxvf uImage_20130316.tar.gz
    注:如果你在这篇文章后已经释放一个图像,说明你可能已经有正确的驱动程序那么你可以跳过这一步。
    使用以下命令应用补丁:
    1、更新内核
    1. sudo mount /dev/nanda /boot
    2. sudo cp uImage /boot/ -f
    2、安装guvcview
    1. sudo apt-get install guvcview
    3、重新启动后运行guvcview
    1. sudo reboot
    从以下菜单运行gucvviewStart Menu ==> Sound Video => guvcview,检查相机是否工作。
    按照以下步骤安装simpleCV
    1. sudo apt-get install ipython python-opencv python-scipy python-numpy python-setuptools python-pip
    2. sudo pip install https://github.com/ingenuitas/SimpleCV/zipball/master
    3. sudo apt-get install python-pygame
    4. sudo apt-get install python-imaging
    键入 “$ simpleCV”启动simpleCV,simpleCV是交互式的shell,我们可以输入以下命令:
    1. ubuntu@ubuntu:~$ simplecv
    2. +-----------------------------------------------------------+
    3. SimpleCV 1.3.0 [interactive shell] - http://simplecv.org
    4. +-----------------------------------------------------------+
    5. Commands:
    6. "exit()" or press "Ctrl+ D" to exit the shell
    7. "clear" to clear the shell screen
    8. "tutorial" to begin the SimpleCV interactive tutorial
    9. "example" gives a list of examples you can run
    10. "forums" will launch a web browser for the help forums
    11. "walkthrough" will launch a web browser with a walkthrough
    12. Usage:
    13. dot complete works to show library
    14. for example: Image().save("/tmp/test.jpg") will dot complete
    15. just by touching TAB after typing Image().
    16. Documentation:
    17. help(Image), ?Image, Image?, or Image()? all do the same
    18. "docs" will launch webbrowser showing documentation
    19. SimpleCV:1> cam=Camera()
    20. VIDIOC_QUERYMENU: Invalid argument
    21. VIDIOC_QUERYMENU: Invalid argument
    22. VIDIOC_QUERYMENU: Invalid argument
    23. VIDIOC_QUERYMENU: Invalid argument
    24. VIDIOC_QUERYMENU: Invalid argument
    25. VIDIOC_QUERYMENU: Invalid argument
    26. VIDIOC_QUERYMENU: Invalid argument
    27. SimpleCV:2> img=cam.getImage()
    28. SimpleCV:3> img.show()
    29. SimpleCV:5:
    以下是截图
  • 签到天数: 1341 天
    发表于 2013-3-25 11:47:03 | 显示全部楼层
    提个建议哈 :
    我觉得树莓派能这么火 一方面是由于占领了市场先机,另一方面是35美元在国外相当于白菜价,从而带动了很多玩家 论坛 等服务
    pcDuino的话 我觉得为了推广 一方面是降低些成本 另一方面 可以派发一些板子 给热心的大牛 通过大家的努力 让大家看到pcDuino的优点 和更多的扩展方案。
    我菜鸟一个 刚接触Debian
    发表于 2013-3-25 13:11:25 | 显示全部楼层
    没有新的例程啊
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2013-3-25 16:48:42 | 显示全部楼层
    wangku001wei 发表于 2013-3-25 11:47
    提个建议哈 :
    我觉得树莓派能这么火 一方面是由于占领了市场先机,另一方面是35美元在国外相当于白菜价, ...
    你的建议不错,我们会考虑的
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2013-3-25 16:55:47 | 显示全部楼层
    aaa 发表于 2013-3-25 13:11
    没有新的例程啊
    正在进行中哦亲
    擦汗
    2013-7-29 11:13
  • 签到天数: 3 天
    发表于 2013-7-14 09:52:27 | 显示全部楼层
    救命啊,我按照你的步骤,复制完uImage重启后,就没有视频输出了,通过串口能看到系统启动了,不过就用了3s,可以输命令,我试着用startx,也不行,hdmi不是没信号,而是黑屏
  • 签到天数: 125 天
    [LV.7]常住居民III
    发表于 2013-7-16 22:11:02 | 显示全部楼层
    坐等相信完善的视频!
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
     楼主| 发表于 2013-7-22 11:40:58 | 显示全部楼层
    喜气洋洋 发表于 2013-7-14 09:52
    救命啊,我按照你的步骤,复制完uImage重启后,就没有视频输出了,通过串口能看到系统启动了,不过就用了3s ...
    尝试重新刷下镜像文件
    GMT+8, 2025-1-20 19:19 , Processed in 0.175692 second(s), 29 queries , MemCache On.
