查看: 3953|回复: 0
[原创] 米尔 mys-y6ull-iot ,内核代码追踪
  • 签到天数: 597 天
    发表于 2018-9-8 00:36:36 | 显示全部楼层 |阅读模式
    内核总共就这么多,前面汇编太详细了,内核中间部分暂时不全,后面和驱动相关的部分写了:
    1. /* =============================(arch/arm/kernel/head.S) */
    2. (arch/arm/kernel/head.S):
    3.         #define KERNEL_RAM_VADDR        (PAGE_OFFSET + TEXT_OFFSET)
    4.         #define PG_DIR_SIZE        0x4000
    5.         #define PMD_ORDER        2
    6.         .equ        swapper_pg_dir, KERNEL_RAM_VADDR - PG_DIR_SIZE
    7.         .macro        pgtbl, rd, phys                                        /* 宏定义 */
    8.         add        \rd, \phys, #TEXT_OFFSET
    9.         sub        \rd, \rd, #PG_DIR_SIZE
    10.         .endm
    11.
    12.         ENTRY(stext)
    13.                  ARM_BE8(setend        be )                        @ ensure we are in BE8 mode
    14.                  THUMB(        adr        r9, BSYM(1f)        )        @ Kernel is always entered in ARM.
    15.                  THUMB(        bx        r9                )        @ If this is a Thumb-2 kernel,
    16.                  THUMB(        .thumb                        )        @ switch to Thumb now.
    17.                  THUMB(1:                        )
    18.
    19.                 bl        __hyp_stub_install
    20.
    21.         safe_svcmode_maskall r9 /* safe_svcmode_maskall r9 */
    22.         mrc        p15, 0, r9, c0, c0                @ get processor id
    23.         bl        __lookup_processor_type                @ r5=procinfo r9=cpuid
    24.         beq        __error_p                        @ yes, error 'p'
    25.
    26.         blo        __error_lpae                        @ only classic page table format
    27. #ifndef CONFIG_XIP_KERNEL
    28.         adr        r3, 2f
    29.         ldmia        r3, {r4, r8}
    30.         sub        r4, r3, r4                        @ (PHYS_OFFSET - PAGE_OFFSET)
    31.         add        r8, r8, r4                        @ PHYS_OFFSET
    32. #else
    33.         ldr        r8, =PLAT_PHYS_OFFSET                @ always constant in this case
    34. #endif
    35.
    36.         /*
    37.          * r1 = machine no, r2 = atags or dtb,
    38.          * r8 = phys_offset, r9 = cpuid, r10 = procinfo
    39.          */
    40.          bl        __vet_atags
    41. #ifdef CONFIG_SMP_ON_UP
    42.         bl        __fixup_smp
    43. #endif
    44. #ifdef CONFIG_ARM_PATCH_PHYS_VIRT
    45.         bl        __fixup_pv_table
    46. #endif
    47.         bl        __create_page_tables
    48.
    49.         ldr        r13, =__mmap_switched                @ address to jump to after
    50.                                                 @ mmu has been enabled
    51.         adr        lr, BSYM(1f)                        @ return (PIC) address
    52.         mov        r8, r4                                @ set TTBR1 to swapper_pg_dir
    53.         ldr        r12, [r10, #PROCINFO_INITFUNC]
    54.         add        r12, r12, r10
    55.         ret        r12
    56. 1:        b        __enable_mmu
    57. ENDPROC(stext)
    58. /* ============================= __hyp_stub_install (arch/arm/kernel/hyp-stub.S) */
    59. ENTRY(__hyp_stub_install)
    60.         store_primary_cpu_mode        r4, r5, r6                /* 保存primary_cpu模式到寄存器中 */
    61. ENDPROC(__hyp_stub_install)
    62.         .macro        store_primary_cpu_mode        reg1, reg2, reg3
    63.         mrs        \reg1, cpsr
    64.         and        \reg1, \reg1, #MODE_MASK
    65.         adr        \reg2, .L__boot_cpu_mode_offset
    66.         ldr        \reg3, [\reg2]
    67.         str        \reg1, [\reg2, \reg3]
    68.         .endm
    69. /* ============================= safe_svcmode_maskall (arch/arm/include/asm/assembler.h)*/
    70. .macro safe_svcmode_maskall reg:req
    71. #if __LINUX_ARM_ARCH__ >= 6 && !defined(CONFIG_CPU_V7M)
    72.         mrs        \reg , cpsr
    73.         eor        \reg, \reg, #HYP_MODE
    74.         tst        \reg, #MODE_MASK
    75.         bic        \reg , \reg , #MODE_MASK
    76.         orr        \reg , \reg , #PSR_I_BIT | PSR_F_BIT | SVC_MODE
    77. THUMB(        orr        \reg , \reg , #PSR_T_BIT        )
    78.         bne        1f
    79.         orr        \reg, \reg, #PSR_A_BIT
    80.         adr        lr, BSYM(2f)
    81.         msr        spsr_cxsf, \reg
    82.         __MSR_ELR_HYP(14)
    83.         __ERET
    84. 1:        msr        cpsr_c, \reg
    85. 2:
    86. #else
    87. /*
    88. * workaround for possibly broken pre-v6 hardware
    89. * (akita, Sharp Zaurus C-1000, PXA270-based)
    90. */
    91.         setmode        PSR_F_BIT | PSR_I_BIT | SVC_MODE, \reg
    92. #endif
    93. .endm
    94. /* ============================= __lookup_processor_type(arch/arm/kernel/head-common.S) */
    95. /*
    96. * Read processor ID register (CP#15, CR0), and look up in the linker-built
    97. * supported processor list.  Note that we can't use the absolute addresses
    98. * for the __proc_info lists since we aren't running with the MMU on
    99. * (and therefore, we are not in the correct address space).  We have to
    100. * calculate the offset.
    101. *
    102. *        r9 = cpuid
    103. * Returns:
    104. *        r3, r4, r6 corrupted
    105. *        r5 = proc_info pointer in physical address space
    106. *        r9 = cpuid (preserved)
    107. */
    108. __lookup_processor_type:
    109.         adr        r3, __lookup_processor_type_data
    110.         ldmia        r3, {r4 - r6}
    111.         sub        r3, r3, r4                        @ get offset between virt&phys
    112.         add        r5, r5, r3                        @ convert virt addresses to
    113.         add        r6, r6, r3                        @ physical address space
    114. 1:        ldmia        r5, {r3, r4}                        @ value, mask
    115.         and        r4, r4, r9                        @ mask wanted bits
    116.         teq        r3, r4
    117.         beq        2f
    118.         add        r5, r5, #PROC_INFO_SZ                @ sizeof(proc_info_list)
    119.         cmp        r5, r6
    120.         blo        1b
    121.         mov        r5, #0                                @ unknown processor
    122. 2:        ret        lr
    123. ENDPROC(__lookup_processor_type)
    124. /* ============================= __error_p (arch/arm/kernel/head-common.S)*/
    125. __error_p:
    126. #ifdef CONFIG_DEBUG_LL
    127.         adr        r0, str_p1
    128.         bl        printascii
    129.         mov        r0, r9
    130.         bl        printhex8
    131.         adr        r0, str_p2
    132.         bl        printascii
    133.         b        __error
    134. str_p1:        .asciz        "\nError: unrecognized/unsupported processor variant (0x"
    135. str_p2:        .asciz        ").\n"
    136.         .align
    137. #endif
    138. ENDPROC(__error_p)
    139. /* ============================= __error_lpae (arch/arm/kernel/head-common.S)*/
    140. /*  printascii,printhex8 (arch/arm/kernel/debug.S)*/
    141. __error_lpae:
    142. #ifdef CONFIG_DEBUG_LL
    143.         adr        r0, str_lpae
    144.         bl         printascii
    145.         b        __error
    146. str_lpae: .asciz "\nError: Kernel with LPAE support, but CPU does not support LPAE.\n"
    147. #else
    148.         b        __error
    149. #endif
    150.         .align
    151. ENDPROC(__error_lpae)
    152. /* ============================= __vet_atags(arch/arm/kernel/head-common.S) */
    153. __vet_atags:
    154.         tst        r2, #0x3                        @ aligned?
    155.         bne        1f
    156.         ldr        r5, [r2, #0]
    157. #ifdef CONFIG_OF_FLATTREE
    158.         ldr        r6, =OF_DT_MAGIC                @ is it a DTB?
    159.         cmp        r5, r6
    160.         beq        2f
    161. #endif
    162.         cmp        r5, #ATAG_CORE_SIZE                @ is first tag ATAG_CORE?
    163.         cmpne        r5, #ATAG_CORE_SIZE_EMPTY
    164.         bne        1f
    165.         ldr        r5, [r2, #4]
    166.         ldr        r6, =ATAG_CORE
    167.         cmp        r5, r6
    168.         bne        1f
    169. 2:        ret        lr                                @ atag/dtb pointer is ok
    170. 1:        mov        r2, #0
    171.         ret        lr
    172. ENDPROC(__vet_atags)
    173. /* ============================= __fixup_smp(arch/arm/kernel/head.S)  */
    174. __fixup_smp:
    175.         and        r3, r9, #0x000f0000        @ architecture version
    176.         teq        r3, #0x000f0000                @ CPU ID supported?
    177.         bne        __fixup_smp_on_up        @ no, assume UP
    178.         bic        r3, r9, #0x00ff0000
    179.         bic        r3, r3, #0x0000000f        @ mask 0xff00fff0
    180.         mov        r4, #0x41000000
    181.         orr        r4, r4, #0x0000b000
    182.         orr        r4, r4, #0x00000020        @ val 0x4100b020
    183.         teq        r3, r4                        @ ARM 11MPCore?
    184.         reteq        lr                        @ yes, assume SMP
    185.         mrc        p15, 0, r0, c0, c0, 5        @ read MPIDR
    186.         and        r0, r0, #0xc0000000        @ multiprocessing extensions and
    187.         teq        r0, #0x80000000                @ not part of a uniprocessor system?
    188.         bne    __fixup_smp_on_up        @ no, assume UP
    189.         @ Core indicates it is SMP. Check for Aegis SOC where a single
    190.         @ Cortex-A9 CPU is present but SMP operations fault.
    191.         mov        r4, #0x41000000
    192.         orr        r4, r4, #0x0000c000
    193.         orr        r4, r4, #0x00000090
    194.         teq        r3, r4                        @ Check for ARM Cortex-A9
    195.         retne        lr                        @ Not ARM Cortex-A9,
    196.         @ If a future SoC *does* use 0x0 as the PERIPH_BASE, then the
    197.         @ below address check will need to be #ifdef'd or equivalent
    198.         @ for the Aegis platform.
    199.         mrc        p15, 4, r0, c15, c0        @ get SCU base address
    200.         teq        r0, #0x0                @ '0' on actual UP A9 hardware
    201.         beq        __fixup_smp_on_up        @ So its an A9 UP
    202.         ldr        r0, [r0, #4]                @ read SCU Config
    203. ARM_BE8(rev        r0, r0)                        @ byteswap if big endian
    204.         and        r0, r0, #0x3                @ number of CPUs
    205.         teq        r0, #0x0                @ is 1?
    206.         retne        lr
    207. __fixup_smp_on_up:
    208.         adr        r0, 1f
    209.         ldmia        r0, {r3 - r5}
    210.         sub        r3, r0, r3
    211.         add        r4, r4, r3
    212.         add        r5, r5, r3
    213.         b        __do_fixup_smp_on_up
    214. ENDPROC(__fixup_smp)
    215. /* ========== */
    216. __do_fixup_smp_on_up:
    217.         cmp        r4, r5
    218.         reths        lr
    219.         ldmia        r4!, {r0, r6}
    220. ARM(        str        r6, [r0, r3]        )
    221. THUMB(        add        r0, r0, r3        )
    222. #ifdef __ARMEB__
    223. THUMB(        mov        r6, r6, ror #16        )        @ Convert word order for big-endian.
    224. #endif
    225. THUMB(        strh        r6, [r0], #2        )        @ For Thumb-2, store as two halfwords
    226. THUMB(        mov        r6, r6, lsr #16        )        @ to be robust against misaligned r3.
    227. THUMB(        strh        r6, [r0]        )
    228.         b        __do_fixup_smp_on_up
    229. ENDPROC(__do_fixup_smp_on_up)
    230. /* ============================= __fixup_pv_table (arch/arm/kernel/head.S)*/
    231. __fixup_pv_table:
    232.         adr        r0, 1f
    233.         ldmia        r0, {r3-r7}
    234.         mvn        ip, #0
    235.         subs        r3, r0, r3        @ PHYS_OFFSET - PAGE_OFFSET
    236.         add        r4, r4, r3        @ adjust table start address
    237.         add        r5, r5, r3        @ adjust table end address
    238.         add        r6, r6, r3        @ adjust __pv_phys_pfn_offset address
    239.         add        r7, r7, r3        @ adjust __pv_offset address
    240.         mov        r0, r8, lsr #PAGE_SHIFT        @ convert to PFN
    241.         str        r0, [r6]        @ save computed PHYS_OFFSET to __pv_phys_pfn_offset
    242.         strcc        ip, [r7, #HIGH_OFFSET]        @ save to __pv_offset high bits
    243.         mov        r6, r3, lsr #24        @ constant for add/sub instructions
    244.         teq        r3, r6, lsl #24 @ must be 16MiB aligned
    245. THUMB(        it        ne                @ cross section branch )
    246.         bne        __error
    247.         str        r3, [r7, #LOW_OFFSET]        @ save to __pv_offset low bits
    248.         b        __fixup_a_pv_table
    249. ENDPROC(__fixup_pv_table)
    250.         .align
    251. 1:        .long        .
    252.         .long        __pv_table_begin
    253.         .long        __pv_table_end
    254. 2:        .long        __pv_phys_pfn_offset
    255.         .long        __pv_offset
    256.         .text
    257. __fixup_a_pv_table:
    258.         adr        r0, 3f
    259.         ldr        r6, [r0]
    260.         add        r6, r6, r3
    261.         ldr        r0, [r6, #HIGH_OFFSET]        @ pv_offset high word
    262.         ldr        r6, [r6, #LOW_OFFSET]        @ pv_offset low word
    263.         mov        r6, r6, lsr #24
    264.         cmn        r0, #1
    265. #ifdef CONFIG_THUMB2_KERNEL
    266.         moveq        r0, #0x200000        @ set bit 21, mov to mvn instruction
    267.         lsls        r6, #24
    268.         beq        2f
    269.         clz        r7, r6
    270.         lsr        r6, #24
    271.         lsl        r6, r7
    272.         bic        r6, #0x0080
    273.         lsrs        r7, #1
    274.         orrcs        r6, #0x0080
    275.         orr        r6, r6, r7, lsl #12
    276.         orr        r6, #0x4000
    277.         b        2f
    278. 1:        add     r7, r3
    279.         ldrh        ip, [r7, #2]
    280. ARM_BE8(rev16        ip, ip)
    281.         tst        ip, #0x4000
    282.         and        ip, #0x8f00
    283.         orrne        ip, r6        @ mask in offset bits 31-24
    284.         orreq        ip, r0        @ mask in offset bits 7-0
    285. ARM_BE8(rev16        ip, ip)
    286.         strh        ip, [r7, #2]
    287.         bne        2f
    288.         ldrh        ip, [r7]
    289. ARM_BE8(rev16        ip, ip)
    290.         bic        ip, #0x20
    291.         orr        ip, ip, r0, lsr #16
    292. ARM_BE8(rev16        ip, ip)
    293.         strh        ip, [r7]
    294. 2:        cmp        r4, r5
    295.         ldrcc        r7, [r4], #4        @ use branch for delay slot
    296.         bcc        1b
    297.         bx        lr
    298. #else
    299. #ifdef CONFIG_CPU_ENDIAN_BE8
    300.         moveq        r0, #0x00004000        @ set bit 22, mov to mvn instruction
    301. #else
    302.         moveq        r0, #0x400000        @ set bit 22, mov to mvn instruction
    303. #endif
    304.         b        2f
    305. 1:        ldr        ip, [r7, r3]
    306. #ifdef CONFIG_CPU_ENDIAN_BE8
    307.         @ in BE8, we load data in BE, but instructions still in LE
    308.         bic        ip, ip, #0xff000000
    309.         tst        ip, #0x000f0000        @ check the rotation field
    310.         orrne        ip, ip, r6, lsl #24 @ mask in offset bits 31-24
    311.         biceq        ip, ip, #0x00004000 @ clear bit 22
    312.         orreq        ip, ip, r0      @ mask in offset bits 7-0
    313. #else
    314.         bic        ip, ip, #0x000000ff
    315.         tst        ip, #0xf00        @ check the rotation field
    316.         orrne        ip, ip, r6        @ mask in offset bits 31-24
    317.         biceq        ip, ip, #0x400000        @ clear bit 22
    318.         orreq        ip, ip, r0        @ mask in offset bits 7-0
    319. #endif
    320.         str        ip, [r7, r3]
    321. 2:        cmp        r4, r5
    322.         ldrcc        r7, [r4], #4        @ use branch for delay slot
    323.         bcc        1b
    324.         ret        lr
    325. #endif
    326. ENDPROC(__fixup_a_pv_table)
    327. /* ============================= __create_page_tables (arch/arm/kernel/head.S)*/
    328. __create_page_tables:
    329.         pgtbl        r4, r8                                @ page table address
    330.         /*
    331.          * Clear the swapper page table
    332.          */
    333.         mov        r0, r4
    334.         mov        r3, #0
    335.         add        r6, r0, #PG_DIR_SIZE
    336. 1:        str        r3, [r0], #4
    337.         str        r3, [r0], #4
    338.         str        r3, [r0], #4
    339.         str        r3, [r0], #4
    340.         teq        r0, r6
    341.         bne        1b
    342. #ifdef CONFIG_ARM_LPAE
    343.         /*
    344.          * Build the PGD table (first level) to point to the PMD table. A PGD
    345.          * entry is 64-bit wide.
    346.          */
    347.         mov        r0, r4
    348.         add        r3, r4, #0x1000                        @ first PMD table address
    349.         orr        r3, r3, #3                        @ PGD block type
    350.         mov        r6, #4                                @ PTRS_PER_PGD
    351.         mov        r7, #1 << (55 - 32)                @ L_PGD_SWAPPER
    352. 1:
    353. #ifdef CONFIG_CPU_ENDIAN_BE8
    354.         str        r7, [r0], #4                        @ set top PGD entry bits
    355.         str        r3, [r0], #4                        @ set bottom PGD entry bits
    356. #else
    357.         str        r3, [r0], #4                        @ set bottom PGD entry bits
    358.         str        r7, [r0], #4                        @ set top PGD entry bits
    359. #endif
    360.         add        r3, r3, #0x1000                        @ next PMD table
    361.         subs        r6, r6, #1
    362.         bne        1b
    363.         add        r4, r4, #0x1000                        @ point to the PMD tables
    364. #ifdef CONFIG_CPU_ENDIAN_BE8
    365.         add        r4, r4, #4                        @ we only write the bottom word
    366. #endif
    367. #endif
    368.         ldr        r7, [r10, #PROCINFO_MM_MMUFLAGS] @ mm_mmuflags
    369.         /*
    370.          * Create identity mapping to cater for __enable_mmu.
    371.          * This identity mapping will be removed by paging_init().
    372.          */
    373.         adr        r0, __turn_mmu_on_loc
    374.         ldmia        r0, {r3, r5, r6}
    375.         sub        r0, r0, r3                        @ virt->phys offset
    376.         add        r5, r5, r0                        @ phys __turn_mmu_on
    377.         add        r6, r6, r0                        @ phys __turn_mmu_on_end
    378.         mov        r5, r5, lsr #SECTION_SHIFT
    379.         mov        r6, r6, lsr #SECTION_SHIFT
    380. 1:        orr        r3, r7, r5, lsl #SECTION_SHIFT        @ flags + kernel base
    381.         str        r3, [r4, r5, lsl #PMD_ORDER]        @ identity mapping
    382.         cmp        r5, r6
    383.         addlo        r5, r5, #1                        @ next section
    384.         blo        1b
    385.         /*
    386.          * Map our RAM from the start to the end of the kernel .bss section.
    387.          */
    388.         add        r0, r4, #PAGE_OFFSET >> (SECTION_SHIFT - PMD_ORDER)
    389.         ldr        r6, =(_end - 1)
    390.         orr        r3, r8, r7
    391.         add        r6, r4, r6, lsr #(SECTION_SHIFT - PMD_ORDER)
    392. 1:        str        r3, [r0], #1 << PMD_ORDER
    393.         add        r3, r3, #1 << SECTION_SHIFT
    394.         cmp        r0, r6
    395.         bls        1b
    396. #ifdef CONFIG_XIP_KERNEL
    397.         /*
    398.          * Map the kernel image separately as it is not located in RAM.
    399.          */
    400. #define XIP_START XIP_VIRT_ADDR(CONFIG_XIP_PHYS_ADDR)
    401.         mov        r3, pc
    402.         mov        r3, r3, lsr #SECTION_SHIFT
    403.         orr        r3, r7, r3, lsl #SECTION_SHIFT
    404.         add        r0, r4,  #(XIP_START & 0xff000000) >> (SECTION_SHIFT - PMD_ORDER)
    405.         str        r3, [r0, #((XIP_START & 0x00f00000) >> SECTION_SHIFT) << PMD_ORDER]!
    406.         ldr        r6, =(_edata_loc - 1)
    407.         add        r0, r0, #1 << PMD_ORDER
    408.         add        r6, r4, r6, lsr #(SECTION_SHIFT - PMD_ORDER)
    409. 1:        cmp        r0, r6
    410.         add        r3, r3, #1 << SECTION_SHIFT
    411.         strls        r3, [r0], #1 << PMD_ORDER
    412.         bls        1b
    413. #endif
    414.         /*
    415.          * Then map boot params address in r2 if specified.
    416.          * We map 2 sections in case the ATAGs/DTB crosses a section boundary.
    417.          */
    418.         mov        r0, r2, lsr #SECTION_SHIFT
    419.         movs        r0, r0, lsl #SECTION_SHIFT
    420.         subne        r3, r0, r8
    421.         addne        r3, r3, #PAGE_OFFSET
    422.         addne        r3, r4, r3, lsr #(SECTION_SHIFT - PMD_ORDER)
    423.         orrne        r6, r7, r0
    424.         strne        r6, [r3], #1 << PMD_ORDER
    425.         addne        r6, r6, #1 << SECTION_SHIFT
    426.         strne        r6, [r3]
    427. #if defined(CONFIG_ARM_LPAE) && defined(CONFIG_CPU_ENDIAN_BE8)
    428.         sub        r4, r4, #4                        @ Fixup page table pointer
    429.                                                 @ for 64-bit descriptors
    430. #endif
    431. #ifdef CONFIG_DEBUG_LL
    432. #if !defined(CONFIG_DEBUG_ICEDCC) && !defined(CONFIG_DEBUG_SEMIHOSTING)
    433.         /*
    434.          * Map in IO space for serial debugging.
    435.          * This allows debug messages to be output
    436.          * via a serial console before paging_init.
    437.          */
    438.         addruart r7, r3, r0
    439.         mov        r3, r3, lsr #SECTION_SHIFT
    440.         mov        r3, r3, lsl #PMD_ORDER
    441.         add        r0, r4, r3
    442.         mov        r3, r7, lsr #SECTION_SHIFT
    443.         ldr        r7, [r10, #PROCINFO_IO_MMUFLAGS] @ io_mmuflags
    444.         orr        r3, r7, r3, lsl #SECTION_SHIFT
    445. #ifdef CONFIG_ARM_LPAE
    446.         mov        r7, #1 << (54 - 32)                @ XN
    447. #ifdef CONFIG_CPU_ENDIAN_BE8
    448.         str        r7, [r0], #4
    449.         str        r3, [r0], #4
    450. #else
    451.         str        r3, [r0], #4
    452.         str        r7, [r0], #4
    453. #endif
    454. #else
    455.         orr        r3, r3, #PMD_SECT_XN
    456.         str        r3, [r0], #4
    457. #endif
    458. #else /* CONFIG_DEBUG_ICEDCC || CONFIG_DEBUG_SEMIHOSTING */
    459.         /* we don't need any serial debugging mappings */
    460.         ldr        r7, [r10, #PROCINFO_IO_MMUFLAGS] @ io_mmuflags
    461. #endif
    462. #if defined(CONFIG_ARCH_NETWINDER) || defined(CONFIG_ARCH_CATS)
    463.         /*
    464.          * If we're using the NetWinder or CATS, we also need to map
    465.          * in the 16550-type serial port for the debug messages
    466.          */
    467.         add        r0, r4, #0xff000000 >> (SECTION_SHIFT - PMD_ORDER)
    468.         orr        r3, r7, #0x7c000000
    469.         str        r3, [r0]
    470. #endif
    471. #ifdef CONFIG_ARCH_RPC
    472.         /*
    473.          * Map in screen at 0x02000000 & SCREEN2_BASE
    474.          * Similar reasons here - for debug.  This is
    475.          * only for Acorn RiscPC architectures.
    476.          */
    477.         add        r0, r4, #0x02000000 >> (SECTION_SHIFT - PMD_ORDER)
    478.         orr        r3, r7, #0x02000000
    479.         str        r3, [r0]
    480.         add        r0, r4, #0xd8000000 >> (SECTION_SHIFT - PMD_ORDER)
    481.         str        r3, [r0]
    482. #endif
    483. #endif
    484. #ifdef CONFIG_ARM_LPAE
    485.         sub        r4, r4, #0x1000                @ point to the PGD table
    486.         mov        r4, r4, lsr #ARCH_PGD_SHIFT
    487. #endif
    488.         ret        lr
    489. ENDPROC(__create_page_tables)
    490. /* ============================= __mmap_switched(arch/arm/kernel/head-common.S) */
    491. __mmap_switched:
    492.         adr        r3, __mmap_switched_data
    493.         ldmia        r3!, {r4, r5, r6, r7}
    494.         cmp        r4, r5                                @ Copy data segment if needed
    495. 1:        cmpne        r5, r6
    496.         ldrne        fp, [r4], #4
    497.         strne        fp, [r5], #4
    498.         bne        1b
    499.         mov        fp, #0                                @ Clear BSS (and zero fp)
    500. 1:        cmp        r6, r7
    501.         strcc        fp, [r6],#4
    502.         bcc        1b
    503. ARM(        ldmia        r3, {r4, r5, r6, r7, sp})
    504. THUMB(        ldmia        r3, {r4, r5, r6, r7}        )
    505. THUMB(        ldr        sp, [r3, #16]                )
    506.         str        r9, [r4]                        @ Save processor ID
    507.         str        r1, [r5]                        @ Save machine type
    508.         str        r2, [r6]                        @ Save atags pointer
    509.         cmp        r7, #0
    510.         strne        r0, [r7]                        @ Save control register values
    511.         b        start_kernel
    512. ENDPROC(__mmap_switched)
    513.         .align        2
    514.         .type        __mmap_switched_data, %object
    515. __mmap_switched_data:
    516.         .long        __data_loc                        @ r4
    517.         .long        _sdata                                @ r5
    518.         .long        __bss_start                        @ r6
    519.         .long        _end                                @ r7
    520.         .long        processor_id                        @ r4
    521.         .long        __machine_arch_type                @ r5
    522.         .long        __atags_pointer                        @ r6
    523. #ifdef CONFIG_CPU_CP15
    524.         .long        cr_alignment                        @ r7
    525. #else
    526.         .long        0                                @ r7
    527. #endif
    528.         .long        init_thread_union + THREAD_START_SP @ sp
    529.         .size        __mmap_switched_data, . - __mmap_switched_data
    530. /* ============================= __enable_mmu (arch/arm/kernel/head.S)*/
    531. /*
    532. * Setup common bits before finally enabling the MMU.  Essentially
    533. * this is just loading the page table pointer and domain access
    534. * registers.
    535. *
    536. *  r0  = cp#15 control register
    537. *  r1  = machine ID
    538. *  r2  = atags or dtb pointer
    539. *  r4  = page table (see ARCH_PGD_SHIFT in asm/memory.h)
    540. *  r9  = processor ID
    541. *  r13 = *virtual* address to jump to upon completion
    542. */
    543. __enable_mmu:
    544. #if defined(CONFIG_ALIGNMENT_TRAP) && __LINUX_ARM_ARCH__ < 6
    545.         orr        r0, r0, #CR_A
    546. #else
    547.         bic        r0, r0, #CR_A
    548. #endif
    549. #ifdef CONFIG_CPU_DCACHE_DISABLE
    550.         bic        r0, r0, #CR_C
    551. #endif
    552. #ifdef CONFIG_CPU_BPREDICT_DISABLE
    553.         bic        r0, r0, #CR_Z
    554. #endif
    555. #ifdef CONFIG_CPU_ICACHE_DISABLE
    556.         bic        r0, r0, #CR_I
    557. #endif
    558. #ifndef CONFIG_ARM_LPAE
    559.         mov        r5, #(domain_val(DOMAIN_USER, DOMAIN_MANAGER) | \
    560.                       domain_val(DOMAIN_KERNEL, DOMAIN_MANAGER) | \
    561.                       domain_val(DOMAIN_TABLE, DOMAIN_MANAGER) | \
    562.                       domain_val(DOMAIN_IO, DOMAIN_CLIENT))
    563.         mcr        p15, 0, r5, c3, c0, 0                @ load domain access register
    564.         mcr        p15, 0, r4, c2, c0, 0                @ load page table pointer
    565. #endif
    566.         b        __turn_mmu_on
    567. ENDPROC(__enable_mmu)
    568. /*
    569. * Enable the MMU.  This completely changes the structure of the visible
    570. * memory space.  You will not be able to trace execution through this.
    571. * If you have an enquiry about this, *please* check the linux-arm-kernel
    572. * mailing list archives BEFORE sending another post to the list.
    573. *
    574. *  r0  = cp#15 control register
    575. *  r1  = machine ID
    576. *  r2  = atags or dtb pointer
    577. *  r9  = processor ID
    578. *  r13 = *virtual* address to jump to upon completion
    579. *
    580. * other registers depend on the function called upon completion
    581. */
    582.         .align        5
    583.         .pushsection        .idmap.text, "ax"
    584. ENTRY(__turn_mmu_on)
    585.         mov        r0, r0
    586.         instr_sync
    587.         mcr        p15, 0, r0, c1, c0, 0                @ write control reg
    588.         mrc        p15, 0, r3, c0, c0, 0                @ read id reg
    589.         instr_sync
    590.         mov        r3, r3
    591.         mov        r3, r13
    592.         ret        r3
    593. __turn_mmu_on_end:
    594. ENDPROC(__turn_mmu_on)
    595. /*================头文件 */
    596. #include "head-common.S"
    597. #include <asm/assembler.h>
    598. /*=================================================start_kernel (init/main.c:) */
    599. lockdep_init:                                                        初始化 (2^12个)classhash_table 链表头
    600.        初始化 (2^15个)chainhash_table 链表头
    601.        全局静态变量置1
    602. rest_init
    603.         kernel_init
    604.                 kernel_init_freeable
    605.                         do_basic_setup
    606.                                 driver_init
    607.                                         void __init driver_init(void)
    608.                                         {
    609.                                                 /* These are the core pieces */
    610.                                                 devtmpfs_init();
    611.                                                 devices_init();
    612.                                                 buses_init();
    613.                                                 classes_init();
    614.                                                 firmware_init();
    615.                                                 hypervisor_init();
    616.                                                 /* These are also core pieces, but must come after the
    617.                                                  * core core pieces.
    618.                                                  */
    619.                                                 platform_bus_init();
    620.                                                 cpu_dev_init();
    621.                                                 memory_dev_init();
    622.                                                 container_dev_init();
    623.                                                 of_core_init();
    624.                                         }
    第二部部分是 整理好的 链接文件,对着看:
    1. /* arch/arm/kernel/vmlinux.lds
    2. * Automatically generated file; DO NOT EDIT.
    3. * Linux/arm 4.1.15 Kernel Configuration
    4. */
    5. OUTPUT_ARCH(arm)
    6. ENTRY(stext)
    7. jiffies = jiffies_64;
    8. SECTIONS
    9. {
    10.         /*
    11.          * XXX: The linker does not define how output sections are
    12.          * assigned to input sections when there are multiple statements
    13.          * matching the same input section name.  There is no documented
    14.          * order of matching.
    15.          *
    16.          * unwind exit sections must be discarded before the rest of the
    17.          * unwind sections get included.
    18.          */
    19.   /DISCARD/ : {
    20.        *(.ARM.exidx.exit.text)
    21.        *(.ARM.extab.exit.text)
    22.        *(.exitcall.exit)
    23.        *(.discard)
    24.        *(.discard.*)
    25.   }
    26.   . = 0x80000000 + 0x00008000;
    27.   .head.text : {
    28.                                                 _text = .;                                *(.head.text)
    29.   }
    30.   .text : { /* Real text segment                */
    31.                                                 _stext = .;        /* Text and read-only data        */
    32.                 . = ALIGN(8);        __idmap_text_start = .; *(.idmap.text)
    33.                                                 __idmap_text_end = .;
    34.                 . = ALIGN((1 << 12));
    35.                                                 __hyp_idmap_text_start = .;
    36.        *(.hyp.idmap.text)
    37.                                                 __hyp_idmap_text_end = .;
    38.                                                 __exception_text_start = .;
    39.        *(.exception.text)
    40.                                                 __exception_text_end = .;
    41.                 . = ALIGN(8);                                                         *(.text.hot)
    42.        *(.text .text.fixup)
    43.        *(.ref.text)
    44.        *(.text.unlikely)
    45.                 . = ALIGN(8);         __sched_text_start = .;
    46.        *(.sched.text)
    47.                                                 __sched_text_end = .;
    48.                 . = ALIGN(8);         __lock_text_start = .;         *(.spinlock.text)
    49.                                                 __lock_text_end = .;
    50.                 . = ALIGN(8);         __kprobes_text_start = .;
    51.        *(.kprobes.text)
    52.                                                 __kprobes_text_end = .;
    53.        *(.gnu.warning)
    54.        *(.glue_7)
    55.        *(.glue_7t)
    56.                 . = ALIGN(4);                                                        *(.got)                                         /* Global offset table                */
    57.                 . = ALIGN(4);         __proc_info_begin = .;         *(.proc.info.init)
    58.                                                 __proc_info_end = .;
    59.   }
    60.                 . = ALIGN(((1 << 12)));
    61.   .rodata : AT(ADDR(.rodata) - 0) {
    62.                                                 __start_rodata = .;         *(.rodata) /* start of rodata section */
    63.        *(.rodata.*)
    64.        *(__vermagic)
    65.                 . = ALIGN(8);         __start___tracepoints_ptrs = .;
    66.        *(__tracepoints_ptrs)
    67.                                                 __stop___tracepoints_ptrs = .;
    68.        *(__tracepoints_strings)
    69.   }
    70.   .rodata1 : AT(ADDR(.rodata1) - 0) {                         *(.rodata1)
    71.   }
    72.                 . = ALIGN(8);
    73.   __bug_table : AT(ADDR(__bug_table) - 0) {
    74.                                                 __start___bug_table = .;
    75.        *(__bug_table)
    76.                                                 __stop___bug_table = .;
    77.   }
    78.   .pci_fixup : AT(ADDR(.pci_fixup) - 0) {
    79.                                                 __start_pci_fixups_early = .;
    80.        *(.pci_fixup_early)
    81.                                                 __end_pci_fixups_early = .;
    82.                                                 __start_pci_fixups_header = .;
    83.        *(.pci_fixup_header)
    84.                                                 __end_pci_fixups_header = .;
    85.                                                 __start_pci_fixups_final = .;
    86.        *(.pci_fixup_final)
    87.                                                 __end_pci_fixups_final = .;
    88.                                                 __start_pci_fixups_enable = .;
    89.        *(.pci_fixup_enable)
    90.                                                 __end_pci_fixups_enable = .;
    91.                                                 __start_pci_fixups_resume = .;
    92.        *(.pci_fixup_resume)
    93.                                                 __end_pci_fixups_resume = .;
    94.                                                 __start_pci_fixups_resume_early = .;
    95.        *(.pci_fixup_resume_early)
    96.                                                 __end_pci_fixups_resume_early = .;
    97.                                                 __start_pci_fixups_suspend = .;
    98.        *(.pci_fixup_suspend)
    99.                                                 __end_pci_fixups_suspend = .;
    100.                                                 __start_pci_fixups_suspend_late = .;
    101.        *(.pci_fixup_suspend_late)
    102.                                                 __end_pci_fixups_suspend_late = .;
    103.   }
    104.   .builtin_fw : AT(ADDR(.builtin_fw) - 0) {
    105.                                                 __start_builtin_fw = .; *(.builtin_fw)
    106.                                                 __end_builtin_fw = .;
    107.   }
    108. /* >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  syscall 用的 >>>>>>>>>>>>>>> */
    109.   __ksymtab : AT(ADDR(__ksymtab) - 0) {
    110.                                                 __start___ksymtab = .;         *(SORT(___ksymtab+*))
    111.                                                 __stop___ksymtab = .;
    112.   }
    113.   __ksymtab_gpl : AT(ADDR(__ksymtab_gpl) - 0) {
    114.                                                 __start___ksymtab_gpl = .;
    115.        *(SORT(___ksymtab_gpl+*))
    116.                                                 __stop___ksymtab_gpl = .;
    117.   }
    118.   __ksymtab_unused : AT(ADDR(__ksymtab_unused) - 0) {
    119.                                                 __start___ksymtab_unused = .;
    120.        *(SORT(___ksymtab_unused+*))
    121.                                                 __stop___ksymtab_unused = .;
    122.   }
    123.   __ksymtab_unused_gpl : AT(ADDR(__ksymtab_unused_gpl) - 0) {
    124.                                                 __start___ksymtab_unused_gpl = .;
    125.        *(SORT(___ksymtab_unused_gpl+*))
    126.                                                 __stop___ksymtab_unused_gpl = .;
    127.   }
    128.   __ksymtab_gpl_future : AT(ADDR(__ksymtab_gpl_future) - 0) {
    129.                                                 __start___ksymtab_gpl_future = .;
    130.        *(SORT(___ksymtab_gpl_future+*))
    131.                                                 __stop___ksymtab_gpl_future = .;
    132.   }
    133.   __kcrctab : AT(ADDR(__kcrctab) - 0) {
    134.                                                 __start___kcrctab = .;         *(SORT(___kcrctab+*))
    135.                                                 __stop___kcrctab = .;
    136.   }
    137.   __kcrctab_gpl : AT(ADDR(__kcrctab_gpl) - 0) {
    138.                                                 __start___kcrctab_gpl = .;
    139.        *(SORT(___kcrctab_gpl+*))
    140.                                                 __stop___kcrctab_gpl = .;
    141.   }
    142.   __kcrctab_unused : AT(ADDR(__kcrctab_unused) - 0) {
    143.                                                 __start___kcrctab_unused = .;
    144.        *(SORT(___kcrctab_unused+*))
    145.                                                 __stop___kcrctab_unused = .;
    146.   }
    147.   __kcrctab_unused_gpl : AT(ADDR(__kcrctab_unused_gpl) - 0) {
    148.                                                 __start___kcrctab_unused_gpl = .;
    149.        *(SORT(___kcrctab_unused_gpl+*))
    150.                                                 __stop___kcrctab_unused_gpl = .;
    151.   }
    152.   __kcrctab_gpl_future : AT(ADDR(__kcrctab_gpl_future) - 0) {
    153.                                                 __start___kcrctab_gpl_future = .;
    154.        *(SORT(___kcrctab_gpl_future+*))
    155.                                                 __stop___kcrctab_gpl_future = .;
    156.   }
    157.   __ksymtab_strings : AT(ADDR(__ksymtab_strings) - 0) {
    158.        *(__ksymtab_strings)
    159.   }
    160. /* <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<  syscall 用的 <<<<<<<<<<<<<<<<<<<<< */
    161.   __init_rodata : AT(ADDR(__init_rodata) - 0) {
    162.        *(.ref.rodata)
    163.   }
    164.   __param : AT(ADDR(__param) - 0) {
    165.                                                 __start___param = .;
    166.        *(__param)
    167.                                                 __stop___param = .;
    168.   }
    169.   __modver : AT(ADDR(__modver) - 0) {
    170.                                                 __start___modver = .;         *(__modver)
    171.                                                 __stop___modver = .;
    172.                 . = ALIGN(((1 << 12)));
    173.                                                 __end_rodata = .; /* End of rodata section */
    174.   }
    175.                 . = ALIGN(((1 << 12)));
    176.                 . = ALIGN(4);
    177.   __ex_table : AT(ADDR(__ex_table) - 0) {
    178.                                                 __start___ex_table = .;        *(__ex_table)
    179.                                                 __stop___ex_table = .;
    180.   }
    181.         /*
    182.          * Stack unwinding tables
    183.          */
    184.                 . = ALIGN(8);
    185.   .ARM.unwind_idx : {          __start_unwind_idx = .;        *(.ARM.exidx*)
    186.                                                 __stop_unwind_idx = .;
    187.   }
    188.   .ARM.unwind_tab : {        __start_unwind_tab = .;        *(.ARM.extab*)
    189.                                                 __stop_unwind_tab = .;
    190.   }
    191.   .notes : AT(ADDR(.notes) - 0) {
    192.                                                 __start_notes = .;                 *(.note.*)
    193.                                                 __stop_notes = .;
    194.   }
    195.                                                 _etext = .;        /* End of text and rodata section */
    196.                 . = ALIGN((1 << 12));
    197.                                                 __init_begin = .;
    198.         /*
    199.          * The vectors and stubs are relocatable code, and the
    200.          * only thing that matters is their relative offsets
    201.          */
    202.                                                 __vectors_start = .;
    203.   .vectors 0 : AT(__vectors_start) {
    204.        *(.vectors)
    205.   }
    206.   . = __vectors_start + SIZEOF(.vectors);
    207.                                                 __vectors_end = .;
    208.                                                 __stubs_start = .;
    209.   .stubs 0x1000 : AT(__stubs_start) {
    210.        *(.stubs)
    211.   }
    212.   . = __stubs_start + SIZEOF(.stubs);
    213.                                                 __stubs_end = .;
    214.                 . = ALIGN(8);
    215.   .init.text : AT(ADDR(.init.text) - 0) {
    216.                                                 _sinittext = .;                 *(.init.text)
    217.        *(.meminit.text)
    218.                                                 _einittext = .;
    219.   }
    220.   .exit.text : {
    221.        *(.exit.text)
    222.        *(.memexit.text)
    223.   }
    224.   .init.proc.info : {
    225.   }
    226.   .init.arch.info : {
    227.                                                 __arch_info_begin = .;
    228.        *(.arch.info.init)
    229.                                                 __arch_info_end = .;
    230.   }
    231.   .init.tagtable : {
    232.                                                 __tagtable_begin = .;
    233.        *(.taglist.init)
    234.                                                 __tagtable_end = .;
    235.   }
    236.   .init.smpalt : {
    237.                                                 __smpalt_begin = .;
    238.        *(.alt.smp.init)
    239.                                                 __smpalt_end = .;
    240.   }
    241.   .init.pv_table : {
    242.                                                 __pv_table_begin = .;
    243.        *(.pv_table)
    244.                                                 __pv_table_end = .;
    245.   }
    246.   .init.data : {        *(.init.data)
    247.        *(.meminit.data)
    248.        *(.init.rodata)
    249.        *(.meminit.rodata)
    250.                 . = ALIGN(8);        __clk_of_table = .;                *(__clk_of_table)
    251.        *(__clk_of_table_end)
    252.                 . = ALIGN(8);        __reservedmem_of_table = .;
    253.        *(__reservedmem_of_table)
    254.        *(__reservedmem_of_table_end)
    255.                 . = ALIGN(8);        __clksrc_of_table = .;         *(__clksrc_of_table)
    256.        *(__clksrc_of_table_end)
    257.                 . = ALIGN(8);        __cpu_method_of_table = .;
    258.        *(__cpu_method_of_table)
    259.        *(__cpu_method_of_table_end)
    260.                 . = ALIGN(8);        __cpuidle_method_of_table = .;
    261.        *(__cpuidle_method_of_table)
    262.        *(__cpuidle_method_of_table_end)
    263.                 . = ALIGN(32);         __dtb_start = .;                 *(.dtb.init.rodata)                __dtb_end = .;
    264.                 . = ALIGN(8);         __irqchip_of_table = .; *(__irqchip_of_table)
    265.        *(__irqchip_of_table_end)
    266.                 . = ALIGN(16);         __setup_start = .;                 *(.init.setup)                        __setup_end = .;
    267.                                                 __initcall_start = .;        *(.initcallearly.init)         __initcall0_start = .;
    268.        *(.initcall0.init)
    269.        *(.initcall0s.init)
    270.                                                 __initcall1_start = .;         *(.initcall1.init)
    271.        *(.initcall1s.init)
    272.                                                 __initcall2_start = .;         *(.initcall2.init)
    273.        *(.initcall2s.init)
    274.                                                 __initcall3_start = .;         *(.initcall3.init)
    275.        *(.initcall3s.init)
    276.                                                 __initcall4_start = .;         *(.initcall4.init)
    277.        *(.initcall4s.init)
    278.                                                 __initcall5_start = .;         *(.initcall5.init)
    279.        *(.initcall5s.init)
    280.                                                 __initcallrootfs_start = .;
    281.        *(.initcallrootfs.init)
    282.        *(.initcallrootfss.init)
    283.                                                 __initcall6_start = .;         *(.initcall6.init)
    284.        *(.initcall6s.init)
    285.                                                 __initcall7_start = .;         *(.initcall7.init)
    286.        *(.initcall7s.init)
    287.                                                 __initcall_end = .;
    288.                                                 __con_initcall_start = .;
    289.        *(.con_initcall.init)
    290.                                                 __con_initcall_end = .;
    291.                                                 __security_initcall_start = .;
    292.        *(.security_initcall.init)
    293.                                                 __security_initcall_end = .;
    294.                 . = ALIGN(4);         __initramfs_start = .;         *(.init.ramfs)
    295.                 . = ALIGN(8);                                                         *(.init.ramfs.info)
    296.   }
    297.   .exit.data : {
    298.        *(.exit.data)
    299.        *(.memexit.data)
    300.        *(.memexit.rodata)
    301.   }
    302.                 . = ALIGN((1 << 12));
    303.   .data..percpu : AT(ADDR(.data..percpu) - 0) {
    304.                                                 __per_cpu_load = .;
    305.                                                 __per_cpu_start = .;         *(.data..percpu..first)
    306.                 . = ALIGN((1 << 12));                                         *(.data..percpu..page_aligned)
    307.                 . = ALIGN((1 << 6));                                         *(.data..percpu..read_mostly)
    308.                 . = ALIGN((1 << 6));                                         *(.data..percpu)
    309.        *(.data..percpu..shared_aligned)
    310.                                                 __per_cpu_end = .;
    311.   }
    312.                 . = ALIGN(((1 << 12) << 1));
    313.                                                 __init_end = .;
    314.                                                 __data_loc = .;
    315.   .data : AT(__data_loc) {
    316.                                                 _data = .;        /* address in memory */
    317.                                                 _sdata = .;
    318.                 /*
    319.                  * first, the init task union, aligned
    320.                  * to an 8192 byte boundary.
    321.                  */
    322.                 . = ALIGN(((1 << 12) << 1));                         *(.data..init_task)
    323.                 . = ALIGN((1 << 12));
    324.                                                 __nosave_begin = .;
    325.        *(.data..nosave)
    326.                 . = ALIGN((1 << 12));
    327.                                                 __nosave_end = .;
    328.                 . = ALIGN((1 << 6));                                         *(.data..cacheline_aligned)
    329.                 . = ALIGN((1 << 6));                                         *(.data..read_mostly)
    330.                 . = ALIGN((1 << 6));
    331.   /*
    332.                  * and the usual data section
    333.                  */
    334.        *(.data)
    335.        *(.ref.data)
    336.        *(.data..shared_aligned)
    337.        *(.data.unlikely)
    338.                 . = ALIGN(32);                                                         *(__tracepoints)
    339.                 . = ALIGN(8);         __start___jump_table = .;
    340.        *(__jump_table)
    341.                                                 __stop___jump_table = .;
    342.                 . = ALIGN(8);         __start___verbose = .;         *(__verbose)
    343.                                                 __stop___verbose = .;
    344.    CONSTRUCTORS
    345.                                                 _edata = .;
    346.   }
    347.                                                 _edata_loc = __data_loc + SIZEOF(.data);
    348.                 . = ALIGN(0);         __bss_start = .;
    349.                 . = ALIGN(0);
    350.   .sbss : AT(ADDR(.sbss) - 0) {                                 *(.sbss)
    351.        *(.scommon)
    352.   }
    353.                 . = ALIGN(0);
    354.   .bss : AT(ADDR(.bss) - 0) {                                         *(.bss..page_aligned)
    355.        *(.dynbss)
    356.        *(.bss)
    357.        *(COMMON)
    358.   }
    359.                 . = ALIGN(0);         __bss_stop = .;
    360.                                                 _end = .;
    361.   .stab 0 : {        *(.stab)
    362.   }
    363.   .stabstr 0 : {        *(.stabstr)
    364.   }
    365.   .stab.excl 0 : {        *(.stab.excl)
    366.   }
    367.   .stab.exclstr 0 : {                                                         *(.stab.exclstr)
    368.   }
    369.   .stab.index 0 : {                                                         *(.stab.index)
    370.   }
    371.   .stab.indexstr 0 : {                                                         *(.stab.indexstr)
    372.   }
    373.   .comment 0 : {        *(.comment)
    374.   }
    375. }
    376. /*
    377. * These must never be empty
    378. * If you have to comment these two assert statements out, your
    379. * binutils is too old (for other reasons as well)
    380. */
    381. ASSERT((__proc_info_end - __proc_info_begin), "missing CPU support")
    382. ASSERT((__arch_info_end - __arch_info_begin), "no machine record defined")
    383. /*
    384. * The HYP init code can't be more than a page long,
    385. * and should not cross a page boundary.
    386. * The above comment applies as well.
    387. */
    388. ASSERT(__hyp_idmap_text_end - (__hyp_idmap_text_start & (~((1 << 12) - 1))) <= (1 << 12),
    389. "HYP init code too big or misaligned")
    评分
    参与人数 1与非币 +80 收起 理由
    satoll + 80 感谢分享
    查看全部评分
    GMT+8, 2025-1-12 20:54 , Processed in 0.126852 second(s), 16 queries , MemCache On.
