手绘识别
本文主要给大家介绍下在Android平台下使用角蜂鸟实现手绘识别功能
准备工作
- 配置环境等详情请参照Hello 2018里的快速开始,此处不具体阐述
- 下载物体检测所需模型graph_sg文件,在您Android Studio中,当前module下新建assets包,将下载的模型文件复制到该目录下
- 因工程需要处理图像,所以使用了javacv库,可从GitHub自行下载或点击链接从示例工程中libs下拷贝到自己工程
- 将class_list_chn.txt文件拷贝到Android设备的存储空间下,用于345种物体的比对
具体实现- int status = allocateGraphByAssets("graph_sg");
复制代码- try {
- BufferedReader bufferedReader = new BufferedReader(new FileReader(Environment.getExternalStorageDirectory().getAbsolutePath() + "/hs/class_list_chn.txt"));
- for (int i = 0; i < 345; i++) {
- String line = bufferedReader.readLine();
- if (line != null) {
- String[] strings = line.split(" ");
- mObjectNames[i] = strings[0];
- bufferedReader.close();
- } catch (FileNotFoundException e) {
- e.printStackTrace();
- Log.e("SketchGuessThread", "FileNotFoundException");
- } catch (IOException e) {
- Log.e("SketchGuessThread", "IOException");
复制代码- byte[] bytes = deviceGetImage();
注意:开发者也可以根据自己需求选择自己外部摄像头数据。
- opencv_core.IplImage bgrImage = opencv_core.IplImage.create(FRAME_W, FRAME_H, opencv_core.IPL_DEPTH_8U, 3);
- bgrImage.getByteBuffer().put(bytes_frame);
- int sg_weight = (int) (FRAME_W * roi_ratio);
- //crop
- opencv_core.CvRect cvRect = opencv_core.cvRect((int) (FRAME_W * (0.5 - roi_ratio / 2)), (int) (FRAME_H * 0.5 - sg_weight / 2), sg_weight, sg_weight);
- cvSetImageROI(bgrImage, cvRect);
- opencv_core.IplImage cropped = cvCreateImage(cvGetSize(bgrImage), bgrImage.depth(), bgrImage.nChannels());
- cvCopy(bgrImage, cropped);
- //canny
- opencv_core.IplImage image_canny = opencv_core.IplImage.create(sg_weight, sg_weight, opencv_core.IPL_DEPTH_8U, 1);
- cvCanny(cropped, image_canny, 120, 45);
- //dilate
- opencv_core.IplImage image_dilate = opencv_core.IplImage.create(sg_weight, sg_weight, opencv_core.IPL_DEPTH_8U, 1);
- //kernel = np.ones((4,4),np.uint8)
- opencv_core.IplConvKernel iplConvKernel = cvCreateStructuringElementEx(4, 4, 0, 0, CV_SHAPE_RECT);
- cvDilate(image_canny, image_dilate, iplConvKernel, 1);
- opencv_core.IplImage image_dilate_rgba = opencv_core.IplImage.create(sg_weight, sg_weight, opencv_core.IPL_DEPTH_8U, 4);
- cvCvtColor(image_dilate, image_dilate_rgba, CV_GRAY2RGBA);
- //resize
- opencv_core.IplImage image_load = opencv_core.IplImage.create(28, 28, opencv_core.IPL_DEPTH_8U, 4);
- cvResize(image_dilate_rgba, image_load);
- //把该image_dilate转化成float类型传送给角蜂鸟
- Bitmap bitmap_tensor = IplImageToBitmap(image_load);
- Message message1 = new Message();
- message1.arg1 = 2;
- message1.obj = bitmap_tensor;
- mHandler.sendMessage(message1);
- int[] pixels = new int[28 * 28];
- bitmap_tensor.getPixels(pixels, 0, 28, 0, 0, 28, 28);
- float[] floats = new float[28 * 28 * 3];
- for (int i = 0; i < 28 * 28; i++) {
- floats[i] = Color.red(pixels[i]) * 0.007843f - 1;
- floats[3 * i + 1] = Color.green(pixels[i]) * 0.007843f - 1;
- floats[3 * i + 2] = Color.blue(pixels[i]) * 0.007843f - 1;
- int status_tensor = loadTensor(floats, floats.length, 0);
复制代码- float[] result = mHsApi.getResult(0);
复制代码- 处理result返回值,排列取出最大的5个数对应的idex.
- public String[] sortMax5(float[] result) {
- HashMap<Integer, Float> integerFloatHashMap = new HashMap<>();
- String[] object_names = new String[5];
- for (int i = 0; i < result.length; i++) {
- integerFloatHashMap.put(i, result[i]);
- Arrays.sort(result);
- if (integerFloatHashMap.get(i) == result[result.length - 1]) {
- object_names[0] = mObjectNames[i] + " " + result[result.length - 1];
- if (integerFloatHashMap.get(i) == result[result.length - 2]) {
- object_names[1] = mObjectNames[i] + " " + result[result.length - 2];
- if (integerFloatHashMap.get(i) == result[result.length - 3]) {
- object_names[2] = mObjectNames[i] + " " + result[result.length - 3];
- if (integerFloatHashMap.get(i) == result[result.length - 4]) {
- object_names[3] = mObjectNames[i] + " " + result[result.length - 4];
- if (integerFloatHashMap.get(i) == result[result.length - 5]) {
- object_names[4] = mObjectNames[i] + " " + result[result.length - 5];
- return object_names;
友好提醒:因Android设备基本都是USB2.0,所以不建议使用1080P的图像,传输比较耗时,会有卡顿感,可以使用360P的图像,铺满屏幕即可
