查看: 2496|回复: 0
LCD显示问题求助
发表于 2018-7-15 20:49:23 | 显示全部楼层 |阅读模式
请求帮助,本人用的MINI STM32 ,写的TFTlcd驱动,在执行lcd初始化时一直是灰屏/**
  * @file   : lcd.c
  * @brief  : TFT_LCD 显示驱动程序
  * @par    : none
  * @note   : none
  * @History:
  *  <data>        <version>                                                            <author>                                                              <describe>
  * 2018/07/11        v0.1.0        tlx                                                         实现TFT_LCD显示
/** Includes ---------------------------------------------------------------------------------------------*/
#include "lcd.h"
#include "stm32f10x_gpio.h"
#include "stm32f10x_rcc.h"
/** Define -----------------------------------------------------------------------------------------------*/
#define cs_high()                   GPIO_SetBits(GPIOC, GPIO_Pin_9)
#define cs_low()                    GPIO_ResetBits(GPIOC, GPIO_Pin_9)
#define rs_high()                   GPIO_SetBits(GPIOC, GPIO_Pin_8)
#define rs_low()                    GPIO_ResetBits(GPIOC, GPIO_Pin_8)
#define wr_high()                   GPIO_SetBits(GPIOC, GPIO_Pin_7)
#define wr_low()                    GPIO_ResetBits(GPIOC, GPIO_Pin_7)
#define rd_high()                   GPIO_SetBits(GPIOC, GPIO_Pin_6)
#define rd_low()                    GPIO_ResetBits(GPIOC, GPIO_Pin_6)
#define bl_on()                     GPIO_SetBits(GPIOC, GPIO_Pin_10)
#define bl_off()                    GPIO_ResetBits(GPIOC, GPIO_Pin_10)
#define READ_ID                     0XD3             /**< 读ID指令 */
#define INC_DIR                     0X36             /**< 连续读写时,控制 ILI9341 存储器的读写方向 */
#define SET_X                       0X2A             /**< 设置横坐标 */
#define SET_Y                       0X2B             /**< 设置纵坐标 */
#define WR_GRAM                     0X2C             /**< 向GRAM里写入颜色数据 */
#define RD_GRAM                     0X2E             /**< 从GRAM里读出颜色数据 */
static uint16_t lcd_read_data(void);
static void lcd_write_cmd(uint8_t cmd);
static void lcd_write_data(uint16_t data);
static void lcd_set_cursor(uint16_t x, uint16_t y);
static void lcd_set_color(uint16_t color);
static void lcd_set_y(uint16_t ystart, uint16_t yend);
static void lcd_set_x(uint16_t xstart, uint16_t xend);
static void lcd_set_dir(uint8_t value);
/** Application Function -------------------------------------------------------------------------------------*/
  * @func  : lcd_init()
  * @brief : lcd初始化函数
  * @par   : none
  * @note  : none
  * @return: none
void lcd_init(void)
        GPIO_InitTypeDef GPIO_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);//使能 PORTB,C 时钟以及 AFIO 时钟
        GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable , ENABLE); //开启 SWD
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10 | GPIO_Pin_9 | GPIO_Pin_8 | GPIO_Pin_7 | GPIO_Pin_6; // //PORTC6~10 复用推挽输出
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_Init(GPIOC, &GPIO_InitStructure); //GPIOC
        GPIO_SetBits(GPIOC,GPIO_Pin_10 | GPIO_Pin_9 | GPIO_Pin_8 | GPIO_Pin_7 | GPIO_Pin_6);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All; // PORTB 推挽输出
        GPIO_Init(GPIOB, &GPIO_InitStructure); //GPIOB
        GPIO_SetBits(GPIOB, GPIO_Pin_All);
        delay_ms(50);
        lcd_write_cmd(0xCF);
    lcd_write_data(0x00);
    lcd_write_data(0xC1);
    lcd_write_data(0X30);
    lcd_write_cmd(0xED);
    lcd_write_data(0x64);
    lcd_write_data(0x03);
    lcd_write_data(0X12);
    lcd_write_data(0X81);
    lcd_write_cmd(0xE8);
    lcd_write_data(0x85);
    lcd_write_data(0x10);
    lcd_write_data(0x7A);
    lcd_write_cmd(0xCB);
    lcd_write_data(0x39);
        lcd_write_data(0x2C);
        lcd_write_data(0x34);
        lcd_write_data(0x02);
        lcd_write_cmd(0xF7);
        lcd_write_data(0x20);
        lcd_write_cmd(0xEA);
        lcd_write_cmd(0xC0);    //Power control
    lcd_write_data(0x1B);   //VRH[5:0]
    lcd_write_cmd(0xC1);    //Power control
    lcd_write_data(0x01);   //SAP[2:0];BT[3:0]
    lcd_write_cmd(0xC5);    //VCM control
    lcd_write_data(0x30); //3F
    lcd_write_data(0x30); //3C
    lcd_write_cmd(0xC7);    //VCM control2
    lcd_write_data(0XB7);
    lcd_write_cmd(0x36);    // Memory Access Control
    lcd_write_data(0x48);
    lcd_write_cmd(0x3A);
    lcd_write_data(0x55);
    lcd_write_cmd(0xB1);
    lcd_write_data(0x1A);
    lcd_write_cmd(0xB6);    // Display Function Control
    lcd_write_data(0x0A);
    lcd_write_data(0xA2);
    lcd_write_cmd(0xF2);    // 3Gamma Function Disable
    lcd_write_cmd(0x26);    //Gamma curve selected
    lcd_write_cmd(0xE0);    //Set Gamma
    lcd_write_data(0x0F);
    lcd_write_data(0x2A);
    lcd_write_data(0x28);
    lcd_write_data(0x08);
    lcd_write_data(0x0E);
    lcd_write_data(0x54);
    lcd_write_data(0XA9);
    lcd_write_data(0x43);
    lcd_write_cmd(0XE1);    //Set Gamma
    lcd_write_data(0x15);
    lcd_write_data(0x17);
    lcd_write_data(0x07);
    lcd_write_data(0x06);
    lcd_write_data(0x2B);
    lcd_write_data(0x56);
    lcd_write_data(0x3C);
    lcd_write_data(0x05);
    lcd_write_data(0x3F);
    lcd_write_cmd(0x2B);
    lcd_write_data(0x3f);
    lcd_write_cmd(0x2A);
    lcd_write_data(0xef);
    lcd_write_cmd(0x11); //Exit Sleep
    delay_ms(120);
    lcd_write_cmd(0x29); //display on
         delay_ms(50);
         lcd_write_cmd(0x2c);
    bl_on();
        lcd_clear(WHITE);
//        lcd_draw_window(0, 100, 0, 100, YELLOW);
  * @func  : lcd_write_reg()
  * @brief : lcd写寄存器函数
  * @par   : none
  * @note  : none
  * @return: none
void lcd_write_reg(uint8_t cmd, uint16_t *para, uint16_t size)
        lcd_write_cmd(cmd);
        for(int i = 0; i < size; i ++)
                lcd_write_data(*para);
                para = para +1;
  * @func  : lcd_read_reg()
  * @brief : lcd读寄存器函数
  * @par   : none
  * @note  : none
  * @return: none
void lcd_read_reg(uint8_t cmd, uint16_t *data, uint16_t size)
        lcd_write_cmd(cmd);
        GPIOB->CRL = 0X88888888; //PB0-7  上拉输入
        GPIOB->CRH = 0X88888888; //PB8-15 上拉输入
        GPIOB->ODR = 0XFFFF;    //全部输出高
                *data = lcd_read_data();
                data = data +1;
        GPIOB->CRL = 0X33333333; //PB0-7  上拉输出
        GPIOB->CRH = 0X33333333; //PB8-15 上拉输出
  * @func  : lcd_draw_point()
  * @brief : lcd画点函数
  * @par   : none
  * @note  : none
  * @return: none
void lcd_draw_point(uint16_t x, uint16_t y, uint16_t color)
        lcd_set_cursor(x, y);
        lcd_set_color(color);
  * @brief : lcd画点函数
  * @par   : none
  * @note  : none
  * @return: none
void lcd_draw_window(uint16_t xstart, uint16_t xend, uint16_t ystart, uint16_t yend, uint16_t bkcolor)
        uint16_t n, i;
        n = (xend - xstart + 1) * (yend - ystart + 1);
        lcd_set_x(xstart, xend);
        lcd_set_y(ystart, yend);
        for(i = 0; i < n; i ++)
                lcd_set_color(bkcolor);
  * @brief : lcd画点函数
  * @par   : none
  * @note  : none
  * @return: none
void lcd_clear(uint16_t color)
        uint32_t i;
        lcd_set_cursor(0x00, 0x00);
        lcd_write_cmd(WR_GRAM);
        for(i = 0; i < (240 * 320); i ++)
                lcd_write_data(color);
/** Private Function -------------------------------------------------------------------------------------*/
  * @func  : lcd_write_data()
  * @brief : lcd写参数函数
  * @par   : none
  * @note  : none
  * @return: none
        rd_high();
        rs_high();
        cs_low();
        GPIOB->ODR = data;
        wr_low();
        wr_high();
        cs_high();
  * @func  : lcd_write_cmd()
  * @brief : lcd写命令函数
  * @par   : none
  * @note  : none
  * @return: none
        rd_high();
        rs_low();
        cs_low();
        GPIOB->ODR = cmd;
        wr_low();
        wr_high();
        cs_high();
  * @func  : lcd_read_data()
  * @brief : lcd读数据函数
  * @par   : none
  * @note  : none
  * @return: none
        uint16_t rxbuf;
        wr_high();
        rs_high();
        cs_low();
        rd_low();
        rxbuf = GPIOB->IDR;
        rd_high();
        cs_high();
        return rxbuf;
  * @func  : lcd_set_dir()
  * @brief : lcd扫描方向设置函数
  * @par   : value中高3位决定自增方向,其他位暂为0
  * @note  : none
  * @return: none
        lcd_write_cmd(INC_DIR);
        lcd_write_data(value);
  * @func  : lcd_set_x()
  * @brief : lcd写横坐标函数
  * @par   : 4个字节数据组成两个横坐标(起始坐标和结束坐标)
  * @note  : 当画点时xtart等于xend
  * @return: none
        uint16_t xbuffer[4];
        xbuffer[0] = (uint16_t)((xstart & 0xff00) >> 8);
        xbuffer[1] = (uint16_t)(xstart & 0x00ff);
        xbuffer[2] = (uint16_t)((xend & 0xff00) >> 8);
        xbuffer[3] = (uint16_t)(xend & 0x00ff);
        lcd_write_reg(SET_X, xbuffer, 4);
  * @func  : lcd_set_y()
  * @brief : lcd写纵坐标函数
  * @par   : 4个字节数据组成两个纵坐标(起始坐标和结束坐标)
  * @note  : 当画点时ytart等于yend
  * @return: none
        uint16_t ybuffer[4];
        ybuffer[0] = (uint16_t)((ystart & 0xff00) >> 8);
        ybuffer[1] = (uint16_t)(ystart & 0x00ff);
        ybuffer[2] = (uint16_t)((yend & 0xff00) >> 8);
        ybuffer[3] = (uint16_t)(yend & 0x00ff);
        lcd_write_reg(SET_Y, ybuffer, 4);
  * @func  : lcd_set_color()
  * @brief : lcd设置颜色函数
  * @note  : none
  * @return: none
  * @func  : lcd_set_cursor()
  * @note  : none
  * @return: none
        lcd_set_x(x, x);
        lcd_set_y(y, y);
GMT+8, 2025-1-11 22:45 , Processed in 0.113282 second(s), 15 queries , MemCache On.
