查看: 1754|回复: 0
视壮嵌入式板卡rk3399 kernel通用GPIO驱动控制
  • 签到天数: 53 天
    [LV.5]常住居民I
    发表于 2018-7-5 09:54:36 | 显示全部楼层 |阅读模式
    内核已经自带了通用GPIO驱动,可以直接在用户空间操作.
    路径: /sys/class/gpio
    rk3399_mid:/ $ ls /sys/class/gpio
    export       gpiochip1032 gpiochip1096 unexport
    gpiochip1000 gpiochip1064 gpiochip1128
    操作GPIO0_A6作为高电平输出有效, 操作步骤:
    1. 计算对应的gpio number的值
    通过/sys/kernel/debug/gpio查询信息:
    rk3399_mid:/ $ cat /sys/kernel/debug/gpio
    GPIOs 1000-1031, platform/pinctrl, gpio0:
    gpio-1002 (                    |3G_power            ) out lo
    gpio-1004 (                    |bt_default_wake_host) in  lo
    gpio-1005 (                    |power               ) in  hi
    gpio-1009 (                    |bt_default_reset    ) out lo
    gpio-1010 (                    |reset               ) out hi
    gpio-1011 (                    |pwd_en_3G           ) out hi
    GPIOs 1032-1063, platform/pinctrl, gpio1:
    gpio-1033 (                    |led_Test            ) in  lo
    gpio-1034 (                    |int-n               ) in  hi
    gpio-1035 (                    |vbus-5v             ) out hi
    gpio-1045 (                    |enable              ) out lo
    gpio-1046 (                    |vsel                ) out hi
    gpio-1049 (                    |vsel                ) out lo
    GPIOs 1064-1095, platform/pinctrl, gpio2:
    gpio-1076 (                    |camsys_gpio         ) out lo
    gpio-1083 (                    |bt_default_rts      ) in  hi
    gpio-1090 (                    |bt_default_wake     ) in  lo
    gpio-1091 (                    |camsys_gpio         ) out lo
    可以看到gpio0是以nubmer为1000开始, 那么GPIO0_A6就是 1000+ 6 = 1006
    2. 设置该gpio为输出
    rk3399_mid:/ $ cd /sys/class/gpio/
    rk3399_mid:/sys/class/gpio $ echo 1006 > export
    /system/bin/sh: can't create export: Permission denied
    1|rk3399_mid:/sys/class/gpio $ su
    rk3399_mid:/sys/class/gpio # echo 1006 > export
    rk3399_mid:/sys/class/gpio # ls
    export   gpiochip1000 gpiochip1064 gpiochip1128
    gpio1006 gpiochip1032 gpiochip1096 unexport
    rk3399_mid:/sys/class/gpio # cd gpio1006/
    rk3399_mid:/sys/class/gpio/gpio1006 # echo out > direction
    3. 设置该gpio输出高电平
    rk3399_mid:/sys/class/gpio/gpio1006 # echo 1 > value
    rk3399_mid:/sys/class/gpio/gpio1006 # cat value
    1
    GMT+8, 2024-11-20 02:28 , Processed in 0.119575 second(s), 17 queries , MemCache On.
