查看: 2985|回复: 0
盈鹏飞EVB335x试用之一:开箱记录
  • 签到天数: 75 天
    [LV.6]常住居民II
    发表于 2018-5-13 04:48:56 | 显示全部楼层 |阅读模式
    周六傍晚拿到板卡,包装很精美安全。
    板卡面积不小,给它加了八个铜柱支架。
    比较网络资料,
    发现少了两个件。
    资料下载在https://pan.baidu.com/s/1lDeA_1__hmx-umVLxoEs9A#list/path=%2F密码是1s6w,内容大概如下
    我用的 操作环境是64位的WIN7。按照资料的doc中的Getting_Started_EVB335X.pdf操作,先验证串口好用,加电打开开关,听到一声蜂鸣声并有两个灯亮,等待一会后,主板上有一个灯闪烁。 WIN7没有超级终端了,参考下面实现了超级终端,设置为152000,8N1无流控,https://jingyan.baidu.com/article/414eccf6716fa06b431f0a1c.html,运行后终端显示如下:
    U-Boot SPL 2014.04-rc2 (Jun 04 2014 - 17:30:10)
    U-Boot 2014.04-rc2 (Jun 04 2014 - 17:30:10)
    I2C:   ready
    DRAM:  256MiB
    NAND:  512MiB
    MMC:   OMAPSD/MMC: 0, OMAP SD/MMC: 1
    *** Warning - bad CRC, using default environment
    Net:   cpsw(一个CPU口两个NET口)
    Hit any key to stop autoboot: 0
    NAND read: device 0 offset 0x280000, size 0x300000
    3145728 bytes read: OK
    NAND read: device 0 offset 0x580000, size 0x400000
    4194304 bytes read: OK
    ## Booting kernel from Legacy Image at 82000000 ...
       Image Name:   Linux-3.2.0
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    2961496 Bytes = 2.8 MiB
       Load Address: 80008000
       Entry Point:  80008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    Starting kernel ...
    [    0.000000] Linux version3.2.0 (ronggang@axcor-RD001) (gcc version 4.7.3 201
    30226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313- Linaro GCC
    2013.03) ) #59 Fri Jun 609:41:48 CST 2014
    [    0.000000] CPU: ARMv7Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
    [    0.000000] CPU: PIPT /VIPT nonaliasing data cache, VIPT aliasing instructio
    n cache
    [    0.000000] Machine:com335x
    [    0.000000] Memory policy:ECC disabled, Data cache writeback
    [    0.000000] AM335X ES2.1(neon )
    [    0.000000] Built 1zonelists in Zone order, mobility grouping on. Total pag
    es: 65024
    [    0.000000] Kernel commandline: console=ttyO0,115200n8 root=ubi0:rootfs ubi.
    mtd=8,2048 rootfstype=ubifs rw rootwait=1 lcdtype=AUO_AT070TN94consoleblank=0
    [    0.000000] PID hash tableentries: 1024 (order: 0, 4096 bytes)
    [    0.000000] Dentry cachehash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Inode-cachehash table entries: 16384 (order: 4, 65536 bytes)
    [    0.000000] Memory: 256MB =256MB total
    [    0.000000] Memory:253756k/253756k available, 8388k reserved, 0K highmem
    [    0.000000] Virtual kernelmemory layout:
    [    0.000000]     vector : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap : 0xfff00000 - 0xfffe0000   ( 896kB)
    [    0.000000]     vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
    [    0.000000]     lowmem : 0xc0000000 - 0xd0000000   ( 256MB)
    [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16MB)
    [    0.000000]       .text : 0xc0008000 - 0xc0534000   (5296 kB)
    [    0.000000]       .init : 0xc0534000 - 0xc056e000   ( 232 kB)
    [    0.000000]       .data : 0xc056e000 - 0xc05c5320   ( 349 kB)
    [    0.000000]        .bss : 0xc05c5344 - 0xc05f42e4   ( 188 kB)
    [    0.000000] NR_IRQS:396
    [    0.000000] IRQ: Found anINTC at 0xfa200000 (revision 5.0) with 128 interrup
    ts
    [    0.000000] Total of 128interrupts on 1 active controller
    [    0.000000] OMAP clockeventsource: GPTIMER2 at 24000000 Hz
    [    0.000000]omap_dm_timer_switch_src: Switching to HW default clocksource(sys
    _clkin_ck) for timer1, this may impact timekeeping in low powerstate
    [    0.000000] OMAPclocksource: GPTIMER1 at 24000000 Hz
    [    0.000000] sched_clock: 32bits at 24MHz, resolution 41ns, wraps every 17895
    6ms
    [    0.000000] Console: colourdummy device 80x30
    [    0.000181] Calibratingdelay loop... 795.44 BogoMIPS (lpj=3977216)
    [    0.087387] pid_max:default: 32768 minimum: 301
    [    0.087495] SecurityFramework initialized
    [    0.087588] Mount-cachehash table entries: 512
    [    0.087945] CPU: Testingwrite buffer coherency: ok
    [    0.088664] devtmpfs:initialized
    [    0.107985] omap_hwmod:gfx: failed to hardreset
    [    0.123856] omap_hwmod:pruss: failed to hardreset
    [    0.124884]print_constraints: dummy:
    [    0.125235] NET: Registeredprotocol family 16
    [    0.127272] OMAP GPIOhardware version 0.1
    [    0.129503] omap_mux_init:Add partition: #1: core, flags: 0
    [    0.131552]  omap_i2c.1: alias fck already exists
    [    0.132196] omap-gpmcomap-gpmc: GPMC revision 6.0
    [    0.132213] RegisteringNAND on CS0
    [    0.132802]  omap_hsmmc.0: alias fck already exists
    [    0.134203]  omap_i2c.2: alias fck already exists
    [    0.134622] [ext_uartplatform init]: gpmc mem base is 0x01000000
    [    0.134648] gpmc_cssp_initfor ST16C554 device succeeded
    [    0.134840] com335x: mcasp1init
    [    0.134923]  davinci-mcasp.1: alias fck already exists
    [    0.135365]  da8xx_lcdc.0: alias fck already exists
    [    0.135839]  omap_i2c.3: alias fck already exists
    [    0.136714]  edma.0: alias fck already exists
    [    0.136735]  edma.0: alias fck already exists
    [    0.136751]  edma.0: alias fck already exists
    [    0.154954] bio: createslab <bio-0> at 0
    [    0.156914] SCSI subsysteminitialized
    [    0.157648] usbcore:registered new interface driver usbfs
    [    0.157937] usbcore:registered new interface driver hub
    [    0.158120] usbcore:registered new device driver usb
    [    0.158439] registerdcppi-dma Intr @ IRQ 17
    [    0.158452] Cppi41 InitDone Qmgr-base(d087a000) dma-base(d0878000)
    [    0.158460] Cppi41 InitDone
    [    0.158487] musb-ti81xxmusb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
    [    0.158777] musb-ti81xxmusb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
    [    0.159853] omap_i2comap_i2c.1: bus 1 rev2.4.0 at 400 kHz
    [    0.160778] pca953x 1-0074:interrupt support not compiled in
    [    0.318208] tps652171-0024: TPS65217 ID 0xe version 1.2
    [    0.319102]print_constraints: DCDC1: 900 <--> 1800 mV at 1500 mV
    [    0.320014]print_constraints: DCDC2: 900 <--> 3300 mV at 1275 mV
    [    0.320933]print_constraints: DCDC3: 900 <--> 1500 mV at 1125 mV
    [    0.321835]print_constraints: LDO1: 1000 <--> 3300 mV at 1800 mV
    [    0.322732]print_constraints: LDO2: 900 <--> 3300 mV at 3300 mV
    [    0.323622]print_constraints: LDO3: 1800 <--> 3300 mV at 1800 mV
    [    0.324533]print_constraints: LDO4: 1800 <--> 3300 mV at 3300 mV
    [    0.337413] omap_i2comap_i2c.2: bus 2 rev2.4.0 at 400 kHz
    [    0.357393] omap_i2comap_i2c.3: bus 3 rev2.4.0 at 400 kHz
    [    0.359046] Advanced LinuxSound Architecture Driver Version 1.0.24.
    [    0.360208] Switching toclocksource gp timer
    [    0.376692] musb-hdrc:version 6.0, ?dma?, otg (peripheral+host)
    [    0.376883] musb-hdrcmusb-hdrc.0: dma type: dma-cppi41
    [    0.377199] MUSB0controller's USBSS revision = 4ea20800
    [    0.377228] musb0: EnabledSW babble control
    [    0.378095] musb-hdrcmusb-hdrc.0: USB OTG mode controller at d084a000 using
    DMA, IRQ 18
    [    0.378254] musb-hdrcmusb-hdrc.1: dma type: dma-cppi41
    [    0.378551] MUSB1controller's USBSS revision = 4ea20800
    [    0.378575] musb1: EnabledSW babble control
    [    0.378988] musb-hdrcmusb-hdrc.1: MUSB HDRC host driver
    [    0.379086] musb-hdrcmusb-hdrc.1: new USB bus registered, assigned bus numbe
    r 1
    [    0.379215] usb usb1: NewUSB device found, idVendor=1d6b, idProduct=0002
    [    0.379229] usb usb1: NewUSB device strings: Mfr=3, Product=2, SerialNumber=
    1
    [    0.379241] usb usb1roduct: MUSB HDRC host driver
    [    0.379250] usb usb1:Manufacturer: Linux 3.2.0 musb-hcd
    [    0.379260] usb usb1:SerialNumber: musb-hdrc.1
    [    0.380142] hub 1-0:1.0:USB hub found
    [    0.380172] hub 1-0:1.0: 1port detected
    [    0.380813] musb-hdrcmusb-hdrc.1: USB Host mode controller at d084c800 using
    DMA, IRQ 19
    [    0.381231] NET: Registeredprotocol family 2
    [    0.381419] IP route cachehash table entries: 2048 (order: 1, 8192 bytes)
    [    0.381695] TCP establishedhash table entries: 8192 (order: 4, 65536 bytes)
    [    0.381839] TCP bind hashtable entries: 8192 (order: 3, 32768 bytes)
    [    0.381924] TCP: Hashtables configured (established 8192 bind 8192)
    [    0.381935] TCP renoregistered
    [    0.381947] UDP hash tableentries: 256 (order: 0, 4096 bytes)
    [    0.381967] UDP-Lite hashtable entries: 256 (order: 0, 4096 bytes)
    [    0.382146] NET: Registeredprotocol family 1
    [    0.382394] RPC: Registerednamed UNIX socket transport module.
    [    0.382404] RPC: Registeredudp transport module.
    [    0.382412] RPC: Registeredtcp transport module.
    [    0.382420] RPC: Registeredtcp NFSv4.1 backchannel transport module.
    [    0.382629] NetWinderFloating Point Emulator V0.97 (double precision)
    [    0.382653] Error: Driver'omap-gpmc' is already registered, aborting...
    [    0.393530] VFS: Diskquotas dquot_6.5.2
    [    0.393595] Dquot-cachehash table entries: 1024 (order 0, 4096 bytes)
    [    0.394099] msgmni has beenset to 495
    [    0.394773] io schedulernoop registered
    [    0.394785] io schedulerdeadline registered
    [    0.394844] io schedulercfq registered (default)
    [    0.396290] da8xx_lcdcda8xx_lcdc.0: GLCD: Found AUO_AT070TN94 panel
    [    0.407137] Console:switching to colour frame buffer device 100x30
    [    0.413684] Serial:8250/16550 driver, 4 ports, IRQ sharing disabled
    [    0.435557] serial8250.0:ttyS0 at MMIO 0x1000000 (irq = 216) is a 16550A
    [    0.456165] serial8250.0:ttyS1 at MMIO 0x1000008 (irq = 217) is a 16550A
    [    0.476656] serial8250.0:ttyS2 at MMIO 0x1000010 (irq = 218) is a 16550A
    [    0.497259] serial8250.0:ttyS3 at MMIO 0x1000018 (irq = 219) is a 16550A
    [    0.497580] serial8250serial8250.0: unable to register port at index 4 (IO0
    MEM3c IRQ0): -28
    [    0.497964] omap_uart.0:ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    1.261142] console [ttyO0]enabled
    [    1.265457] omap_uart.1:ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    1.273335] omap_uart.2:ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    1.281191] omap_uart.3:ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    1.288998] omap_uart.4:ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    1.296853] omap_uart.5:ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    1.314291] brd: moduleloaded
    [    1.322318] loop: moduleloaded
    [    1.326375] at24 1-0050:1024 byte 24c08 EEPROM, writable, 16 bytes/write
    [    1.335827] mtdoops: mtddevice (mtddev=name/number) must be supplied
    [    1.343019] omap2-nanddriver initializing
    [    1.347622] ONFI flashdetected
    [    1.351063] ONFI param page0 valid
    [    1.354718] NAND device:Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron MT29F4G
    08ABADAWP)
    [    1.363324] Creating 9 MTDpartitions on "omap2-nand.0":
    [    1.368902] 0x000000000000-0x000000020000: "SPL"
    [    1.375363]0x000000020000-0x000000040000 : "SPL.backup1"
    [    1.382457]0x000000040000-0x000000060000 : "SPL.backup2"
    [    1.389338]0x000000060000-0x000000080000 : "SPL.backup3"
    [    1.396306]0x000000080000-0x000000260000 : "U-Boot"
    [    1.403517]0x000000260000-0x000000280000 : "U-Boot Env"
    [    1.410402]0x000000280000-0x000000580000 : "logo"
    [    1.417920]0x000000580000-0x000000a80000 : "Kernel"
    [    1.426573]0x000000a80000-0x000020000000 : "File System"
    [    1.640355] OneNAND driverinitializing
    [    1.645112] UBI: attachingmtd8 to ubi0
    [    1.649132] UBI: physicaleraseblock size:   131072 bytes (128 KiB)
    [    1.655723] UBI: logicaleraseblock size:    126976 bytes
    [    1.661388] UBI: smallestflash I/O unit:    2048
    [    1.666306] UBI: VID headeroffset:          2048 (aligned 2048)
    [    1.672598] UBI: dataoffset:                4096
    [    1.690501] usb 1-1: newhigh-speed USB device number 2 using musb-hdrc
    [    1.861228] usb 1-1: NewUSB device found, idVendor=0424, idProduct=2514
    [    1.868245] usb 1-1: NewUSB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.891639] hub 1-1:1.0:USB hub found
    [    1.896732] hub 1-1:1.0: 4ports detected
    [    5.964617] UBI: max.sequence number:       169
    [    5.987308] UBI: attachedmtd8 to ubi0
    [    5.991313] UBI: MTD devicename:            "File System"
    [    5.997053] UBI: MTD devicesize:            501 MiB
    [    6.002254] UBI: number ofgood PEBs:        4012
    [    6.007175] UBI: number ofbad PEBs:         0
    [    6.011827] UBI: number ofcorrupted PEBs:   0
    [    6.016472] UBI: max.allowed volumes:       128
    [    6.021307] UBI:wear-leveling threshold:    4096
    [    6.026225] UBI: number ofinternal volumes: 1
    [    6.030877] UBI: number ofuser volumes:     1
    [    6.035524] UBI: availablePEBs:             0
    [    6.040168] UBI: totalnumber of reserved PEBs: 4012
    [    6.045371] UBI: number ofPEBs reserved for bad PEB handling: 40
    [    6.051755] UBI: max/meanerase counter: 2/0
    [    6.056217] UBI: imagesequence number:  155871075
    [    6.061550] UBI: backgroundthread "ubi_bgt0d" started, PID 547
    [    6.068399] CAN devicedriver interface
    [    6.072438] CAN bus driverfor Bosch D_CAN controller 1.0
    [    6.120268] davinci_mdiodavinci_mdio.0: davinci mdio revision 1.6
    [    6.126746] davinci_mdiodavinci_mdio.0: detected phy mask ffffffef
    [    6.134175] davinci_mdio.0:probed
    [    6.137745] davinci_mdiodavinci_mdio.0: phy[4]: device 0:04, driver unknown
    [    6.145298] PPP genericdriver version 2.4.2
    [    6.150220] PPP BSDCompression module registered
    [    6.155164] PPP DeflateCompression module registered
    [    6.160654] usbcore:registered new interface driver zd1201
    [    6.166664] usbcore:registered new interface driver cdc_ether
    [    6.172927] usbcore:registered new interface driver cdc_eem
    [    6.178990] usbcore:registered new interface driver dm9601
    [    6.184879] cdc_ncm:04-Aug-2011
    [    6.188405] usbcore:registered new interface driver cdc_ncm
    [    6.194526] usbcore:registered new interface driver cdc_acm
    [    6.200464] cdc_acm: USBAbstract Control Model driver for USB modems and ISD
    N adapters
    [    6.208841] InitializingUSB Mass Storage driver...
    [    6.214168] usbcore:registered new interface driver usb-storage
    [    6.220470] USB MassStorage support registered.
    [    6.225633] usbcore:registered new interface driver usbserial
    [    6.231896] USB Serialsupport registered for generic
    [    6.237334] usbcore:registered new interface driver usbserial_generic
    [    6.244180] usbserial: USBSerial Driver core
    [    6.248857] USB Serialsupport registered for GSM modem (1-port)
    [    6.255434] usbcore:registered new interface driver option
    [    6.261288] option:v0.7.2:USB Driver for GSM modems
    [    6.267075] mousedev: PS/2mouse device common for all mice
    [    6.274227] input:gpio-keys-polled as /devices/platform/gpio-keys-polled.0/i
    nput/input0
    [    6.284865] input:ft5x06_ts as /devices/virtual/input/input1
    [    6.351762] rtc-ds13071-0068: rtc core: registered ds1339 as rtc0
    [    6.358389] i2c /deventries driver
    [    6.365704] cpuidle: usinggovernor ladder
    [    6.370487] cpuidle: usinggovernor menu
    [    6.379534] usbcore:registered new interface driver usbhid
    [    6.385422] usbhid: USB HIDcore driver
    [    6.390106] tiadc tiadc:attached adc driver
    [    6.396892] _regulator_get:1-001b supply IOVDD not found, using dummy regula
    tor
    [    6.404736] _regulator_get:1-001b supply DVDD not found, using dummy regulat
    or
    [    6.412448] _regulator_get:1-001b supply AVDD not found, using dummy regulat
    or
    [    6.420125] _regulator_get:1-001b supply DRVDD not found, using dummy regula
    tor
    [    6.430472] asoc:tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
    [    6.441243] ALSA devicelist:
    [    6.444356]   #0: COM335X EVM
    [    6.447456] oprofile:hardware counters not available
    [    6.452757] oprofile: usingtimer interrupt.
    [    6.457249] nf_conntrackversion 0.5.0 (3964 buckets, 15856 max)
    [    6.464019] ip_tables: (C)2000-2006 Netfilter Core Team
    [    6.469703] TCP cubicregistered
    [    6.473115] NET: Registeredprotocol family 17
    [    6.477787] can: controllerarea network core (rev 20090105 abi 8)
    [    6.484351] NET: Registeredprotocol family 29
    [    6.489001] can: rawprotocol (rev 20090105)
    [    6.493478] can: broadcastmanager protocol (rev 20090105 t)
    [    6.499439] Registering thedns_resolver key type
    [    6.504447] VFP supportv0.3: implementor 41 architecture 3 part 30 variant c
    rev 3
    [    6.512486] ThumbEE CPUextension supported.
    [    6.517016] mux: Failed tosetup hwmod io irq -22
    [    6.522589] Power Managementfor AM33XX family
    [    6.527249] pm: Err (-22)setting core voltage setting
    [    6.532855] Trying to loadam335x-pm-firmware.bin (60 secs timeout)
    [    6.539533] Copied the M3firmware to UMEM
    [    6.543889] Cortex M3Firmware Version = 0x184
    [    6.551838] clock:disabling unused clocks to save power
    [    6.559481] DetectedMACID=b0:d5:cc:8:45:7
    [    6.565665] rtc-ds13071-0068: setting system clock to 2017-05-31 03:37:00 UT
    C (1496201820)
    [    6.640023] UBIFS: recoveryneeded
    [    6.818370] UBIFS: recoverycompleted
    [    6.822258] UBIFS: mountedUBI device 0, volume 0, name "rootfs"
    [    6.828548] UBIFS: filesystem size:   247857152 bytes (242048KiB, 236 MiB,
    1952 LEBs)
    [    6.836934] UBIFS: journalsize:       9023488 bytes (8812 KiB, 8MiB, 72 LEB
    s)
    [    6.844591] UBIFS: mediaformat:       w4/r0 (latest is w4/r0)
    [    6.850699] UBIFS: defaultcompressor: lzo
    [    6.854980] UBIFS: reservedfor root:  0 bytes (0 KiB)
    [    6.861541] VFS: Mountedroot (ubifs filesystem) on device 0:14.
    [    6.869947] devtmpfs:mounted
    [    6.873462] Freeing initmemory: 232K
    Starting logging: OK
    Populating /dev using udev: [   7.613122] udevd[664]: starting version 182
    done
    Initializing random number generator... done.
    Starting network...
    [    8.521386] net eth0: CPSWphy found : id is : 0x4dd072
    [    8.527612] PHY 0:01 notfound
    Starting sshd: OK
    Starting vsftpd: OK
    [root@EVB335X /]#
    上述LINUX启动信息很丰富,都弄透彻了就。看到#表示进入linux的终端命令状态了。
    参考文档《EVB-335X接口功能测试手册.pdf》可以做多种功能测试啊
    GMT+8, 2024-11-20 02:43 , Processed in 0.119733 second(s), 16 queries , MemCache On.
