查看: 2458|回复: 0
[原创] TQ210实现nandflash移植
  • 签到天数: 1792 天
    [LV.Master]伴坛终老
    发表于 2018-5-11 17:24:09 | 显示全部楼层 |阅读模式
    移植NAND FLASH比较麻烦,需要改动的地方很多,下面简要是说明一下
    首先在u-boot-2014.04\include\configs\smdkv210.h里面
    #define CONFIG_ENV_IS_IN_ONENAND        1
    换成
    #define CONFIG_ENV_IS_IN_NAND
    新增
    #define CONFIG_SYS_MAX_NAND_DEVICE         1
    #define CONFIG_SYS_NAND_BASE                0xB0E00000
    #define CONFIG_NAND_S5PV210
    改成
    在u-boot-2014.04\drivers\mtd\nand里面
    拷贝s3c2410_nand.c改名为s5pv210_nand.c,里面的内容需要更改,参考2410的更改就行,直接上代码,更改的太多了。
    * (C) Copyright 2006 OpenMoko, Inc.
    * Author: Harald Welte <laforge@openmoko.org>
    * SPDX-License-Identifier:        GPL-2.0+
    #include <common.h>
    #include <nand.h>
    #include <asm/arch/nand_reg.h>
    #include <asm/io.h>
    #define MP0_1CON  (*(volatile u32 *)0xE02002E0)
    #define        MP0_3CON  (*(volatile u32 *)0xE0200320)
    #define        MP0_6CON  (*(volatile u32 *)0xE0200380)
    static void s5pv210_hwcontrol(struct mtd_info *mtd, int cmd, unsigned int ctrl)
            struct nand_chip *chip = mtd->priv;
            struct s5pv210_nand *nand = (struct s5pv210_nand *)samsung_get_base_nand();
            debug("hwcontrol(): 0x%02x 0x%02x\n", cmd, ctrl);
            ulong IO_ADDR_W = (ulong)nand;
            if (ctrl & NAND_CTRL_CHANGE) {
                    if (ctrl & NAND_CLE)
                            IO_ADDR_W = IO_ADDR_W | 0x8;        /* Command Register  */
                    else if (ctrl & NAND_ALE)
                            IO_ADDR_W = IO_ADDR_W | 0xC;        /* Address Register */
                    chip->IO_ADDR_W = (void *)IO_ADDR_W;
                    if (ctrl & NAND_NCE)        /* select */
                            writel(readl(&nand->nfcont) & ~(1 << 1), &nand->nfcont);
                    else                                        /* deselect */
                            writel(readl(&nand->nfcont) | (1 << 1), &nand->nfcont);
            if (cmd != NAND_CMD_NONE)
                    writeb(cmd, chip->IO_ADDR_W);
            else
                    chip->IO_ADDR_W = &nand->nfdata;
    static int s5pv210_dev_ready(struct mtd_info *mtd)
            debug("dev_ready\n");
            return readl(&nand->nfstat) & 0x01;
    void s5pv210_nand_enable_hwecc(struct mtd_info *mtd, int mode)
            debug("s5pv210_nand_enable_hwecc(%p, %d)\n", mtd, mode);
            writel(readl(&nand->nfconf) | S3C2410_NFCONF_INITECC, &nand->nfconf);
    static int s5pv210_nand_calculate_ecc(struct mtd_info *mtd, const u_char *dat,
                                          u_char *ecc_code)
            ecc_code[0] = readb(&nand->nfecc);
            ecc_code[1] = readb(&nand->nfecc + 1);
            ecc_code[2] = readb(&nand->nfecc + 2);
            debug("s5pv210_nand_calculate_hwecc(%p,): 0x%02x 0x%02x 0x%02x\n",
                   mtd , ecc_code[0], ecc_code[1], ecc_code[2]);
            return 0;
    static int s5pv210_nand_correct_data(struct mtd_info *mtd, u_char *dat,
                                         u_char *read_ecc, u_char *calc_ecc)
            if (read_ecc[0] == calc_ecc[0] &&
                read_ecc[1] == calc_ecc[1] &&
                read_ecc[2] == calc_ecc[2])
                    return 0;
            printf("s5pv210_nand_correct_data: not implemented\n");
            return -1;
    #endif
    static void s5pv210_nand_select_chip(struct mtd_info *mtd, int ctl)
            switch (ctl) {
            case -1:        /* deselect the chip */
                    chip->cmd_ctrl(mtd, NAND_CMD_NONE, 0 | NAND_CTRL_CHANGE);
                    break;
            case 0:                /* Select the chip */
                    chip->cmd_ctrl(mtd, NAND_CMD_NONE, NAND_NCE | NAND_CTRL_CHANGE);
                    break;
            default:
                    BUG();
    int board_nand_init(struct nand_chip *nand)
            u32 cfg;
            struct s5pv210_nand *nand_reg = (struct s5pv210_nand *)(struct s5pv210_nand *)samsung_get_base_nand();
            debug("board_nand_init()\n");
            /* initialize hardware */
            /* HCLK_PSYS=133MHz(7.5ns) */
            cfg =        (0x1 << 23) |        /* Disable 1-bit and 4-bit ECC */
                            /* 下面3个时间参数稍微比计算出的值大些(我这里依次加1),否则读写不稳定 */
                            (0x3 << 12) |        /* 7.5ns * 2 > 12ns tALS tCLS */
                            (0x2 << 8) |         /* (1+1) * 7.5ns > 12ns (tWP) */
                            (0x1 << 4) |         /* (0+1) * 7.5 > 5ns (tCLH/tALH) */
                            (0x0 << 3) |         /* SLC NAND Flash */
                            (0x0 << 2) |        /* 2KBytes/Page */
                            (0x1 << 1);                /* 5 address cycle */
            writel(cfg, &nand_reg->nfconf);
            writel((0x1 << 1) | (0x1 << 0), &nand_reg->nfcont);
            /* Disable chip select and Enable NAND Flash Controller */
            /* Config GPIO */
            MP0_1CON &= ~(0xFFFF << 8);
            MP0_1CON |= (0x3333 << 8);
            MP0_3CON = 0x22222222;
            MP0_6CON = 0x22222222;
            /* initialize nand_chip data structure */
            nand->IO_ADDR_R = (void *)&nand_reg->nfdata;
            nand->IO_ADDR_W = (void *)&nand_reg->nfdata;
            nand->select_chip = s5pv210_nand_select_chip;
            /* read_buf and write_buf are default */
            /* read_byte and write_byte are default */
            /* hwcontrol always must be implemented */
            nand->cmd_ctrl = s5pv210_hwcontrol;
            nand->dev_ready = s5pv210_dev_ready;
    #ifdef CONFIG_S3C2410_NAND_HWECC
            nand->ecc.hwctl = s5pv210_nand_enable_hwecc;
            nand->ecc.calculate = s5pv210_nand_calculate_ecc;
            nand->ecc.correct = s5pv210_nand_correct_data;
            nand->ecc.mode = NAND_ECC_HW;
            nand->ecc.size = CONFIG_SYS_NAND_ECCSIZE;
            nand->ecc.bytes = CONFIG_SYS_NAND_ECCBYTES;
            nand->ecc.strength = 1;
    #else
            nand->ecc.mode = NAND_ECC_SOFT;
    #endif
    #ifdef CONFIG_S3C2410_NAND_BBT
            nand->bbt_options |= NAND_BBT_USE_FLASH;
    #endif
            debug("end of nand_init\n");
            return 0;
    同时,目录下面的Makefile里面新增
    obj-$(CONFIG_NAND_S5PV210) += s5pv210_nand.o
    在u-boot-2014.04-5\arch\arm\include\asm\arch-s5pc1xx\cup.h里面新增
    #define S5PV210_NAND_BASE        0xB0E00000
    SAMSUNG_BASE(nand, NAND_BASE)
    编译下载,如图
    有警告啊,使用命令saveenv 将环境变量保存到 NAND 中,下次启动就不会有那样的警告了
    重启结果是
    今天就这样了。
    GMT+8, 2025-1-12 18:54 , Processed in 0.112287 second(s), 17 queries , MemCache On.
