查看: 2360|回复: 0
[原创] TQ210实现上网功能
  • 签到天数: 1792 天
    [LV.Master]伴坛终老
    发表于 2018-5-10 16:35:17 | 显示全部楼层 |阅读模式
    tq210板载的网络芯片是dm9000,uboot里面正好也有dm9000的驱动,直接调用即可,下面详细道来。
    更改u-boot-2014.04\board\samsung\smdkv210\smdkv210.c
    把static void smc9115_pre_init(void)函数直接更换成
    static void dm9000_pre_init(void)
    u32 smc_bw_conf, smc_bc_conf;
            /* Ethernet needs bus width of 16 bits */
            smc_bw_conf = SMC_DATA16_WIDTH(CONFIG_ENV_SROM_BANK)
                    | SMC_BYTE_ADDR_MODE(CONFIG_ENV_SROM_BANK);
            smc_bc_conf = SMC_BC_TACS(0) | SMC_BC_TCOS(1) | SMC_BC_TACC(2)
                    | SMC_BC_TCOH(1) | SMC_BC_TAH(0) | SMC_BC_TACP(0) | SMC_BC_PMC(0);
            /* Select and configure the SROMC bank */
            s5p_config_sromc(CONFIG_ENV_SROM_BANK, smc_bw_conf, smc_bc_conf);
    然后更改
    int board_init(void)
            //smc9115_pre_init();
            dm9000_pre_init();
            gd->bd->bi_arch_number = MACH_TYPE_SMDKC100;
            gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100;
            return 0;
    再更改
    int board_eth_init(bd_t *bis)
            int rc = 0;
    #ifdef CONFIG_SMC911X
            rc = smc911x_initialize(0, CONFIG_SMC911X_BASE);
    #elif defined(CONFIG_DRIVER_DM9000)
            rc = dm9000_initialize(bis);
    #endif
            return rc;
    随后更改\u-boot-2014.04\include\configs\smdkv210.h
    #if 0
    #define CONFIG_SMC911X         1       /* we have a SMC9115 on-board   */
    #define CONFIG_SMC911X_16_BIT  1       /* SMC911X_16_BIT Mode          */
    #define CONFIG_SMC911X_BASE    0x98800300      /* SMC911X Drive Base   */
    #endif
    #define CONFIG_ENV_SROM_BANK   1       /* Select SROM Bank-3 for Ethernet*/
    /* add by yin */
    #define CONFIG_DRIVER_DM9000
    #define CONFIG_DM9000_NO_SROM
    #define CONFIG_DM9000_BASE                0x88000000
    #define DM9000_IO                (CONFIG_DM9000_BASE)
    #define DM9000_DATA                (CONFIG_DM9000_BASE + 0x4)
    #define CONFIG_CMD_PING
    #define CONFIG_IPADDR                        192.168.1.120
    #define CONFIG_SERVERIP                        192.168.1.101
    #define CONFIG_ETHADDR                        1A:2A:3A:4A:5A:6A
    上面的ip地址自己可以随意更改,不限制
    编译,烧录
    看底部有个ping 192.168.1.101
    实现现了ping命令,说明连接上了pc机
    上图是pc机的网络设置
    GMT+8, 2025-1-12 18:47 , Processed in 0.118922 second(s), 16 queries , MemCache On.
