查看: 3999|回复: 1
打印 上一主题 下一主题
BPI-M3 新镜像:Ubuntu-mate-16.04-Xenial-ros-kinetic-preview-bpi-m3-sd-emmc
跳转到指定楼层
楼主
发表于 2016-6-14 11:26:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
2016-06-11-ubuntu-mate-16.04-Xenial-ros-kinetic-preview-bpi-m3-sd-emmc.img.zip
  • BPI-M3 kernel 3.4
  • username & password: pi/bananapi , root/bananapi
  • support HDMI 1080P & 720P(default)
  • support eMMC
  • support GMAC
  • support WIFI
  • support SATA
  • support bpi-bootsel cmd can switch to (bpi-m3 & bpi-m2 & bpi-m2p & bpi-m1 & bpi-m1p & bpi-r1)
  • support uEnv.txt to fatload script.bin & uImage
  • support uEnv.txt to set video 1080P & 720P & 480P ...
  • support power max. up to 2.5A ~ for DC-IN.
  • fix rootmydevice issue
  • based on armbian rootfs, thanks for armbian
  • support ros (kinetic version)
Note: GPU driver not include ,so not support GPU function on this version, but if you use bpi-bootsel run this image on BPI-M2+, GPU function is support.
Google driver:
uploading
MD5: b04a903a9c6ddfbc5b6c94505d629004
举报
  • 签到天数: 30 天
    [LV.5]常住居民I
    发表于 2016-6-14 15:36:27 | 只看该作者
    好东西,可惜手头没有板子
    举报
    站长推荐上一条 2/5 下一条
    「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
    查看 »
    GMT+8, 2025-4-29 11:47 , Processed in 0.126227 second(s), 20 queries , MemCache On.
