回答
收藏
[分享] 看门狗流驱动源码
飞凌嵌入式 飞凌嵌入式 2870 人阅读 | 0 人回复 | 2014-01-23
欢迎大家来到飞凌爱板网专区,对嵌入式技术感兴趣的朋友不妨多多关注一下,我们提供了公司所有开发板的所有资料,也会更新大量技术文章,欢迎大家一块学习提高!!!
看门狗流驱动源码
硬件平台:飞凌OK6410-A
操作系统:飞凌光盘中的BSPWINCE6.0
编译工具:VS2005 + WINCE6.0 + BSP
如何添加流驱动,可以参考以前章节!
源码:wdg.cpp
//        NAME OF PROJECT: uniprOS        Version: 1.0 (development) //
//        NAME OF SOURCE FILE: LED.cpp        //
//        Data of creation: 2010.02.15        //
//        Data of last modification: 2010.02.15        //
//        CONTENTS:        unipro stream driver for led control        //
//        NAME OF PROJECT FILE: LED.dll        //
//        UTILIZING COMPILER: Microsoft Visual Studio 2005        //
//                                                        YUE Wei - Unipro        //
#include "stdafx.h"
#include <s3c6410.h>
#include <DrvLib.h>
#include <winuser.h>
#include <windows.h>
#include <ceddk.h>
#include <oal.h>
// Base Definitions
#include "s3c6410_base_regs.h"
#include "s3c6410_wdog.h"
#include "wdg.h"
#define WTCON_PRESCALE(x)        (((x)&0xff)<<8)    // bit 15:8, prescale value, 0 <= (x) <= 27
#define WTCON_ENABLE            (1<<5)            // bit 5, enable watchdog timer
#define WTCON_CLK_DIV16        (0<<3)
#define WTCON_CLK_DIV32        (1<<3)
#define WTCON_CLK_DIV64        (2<<3)
#define WTCON_CLK_DIV128        (3<<3)
#define WTCON_INT_ENABLE        (1<<2)
#define WTCON_RESET            (1<<0)
#define OALPAtoVA1(pa, c)    (VOID*)((c)?(pa)pa))  //jyh
// WTCNT - watchdog counter register
#define WTCNT_CNT(x)            ((x)&0xffff)
// WTDAT - watchdog reload value register
#define WTDAT_CNT(x)            ((x)&0xffff)
// WTCLRINT - watchdog interrupt clear register
#define WTCLRINT_CLEAR            (1<<0)
// Watchdog Clock
// PCLK : 25MHz
// PCLK/PRESCALER : 25/25 = 1MHz
// PCLK/PRESCALER/DIVIDER : 1MHz/128 = 7.812 KHz
// MAX Counter = 0xffff = 65535
// Period = 65535/7812 =~ 8.4 sec
#define WD_PRESCALER            (25-1)
#define WD_REFRESH_PERIOD        3000    // tell the OS to refresh watchdog every 3 second.
// GPIO virtual address
static volatile S3C6410_GPIO_REG  *v_pIOPregs  ;
static volatile S3C6410_WATCHDOG_REG *v_pWDGregs;
//        DLL entry        //
BOOL APIENTRY DllMain(HANDLE hModule,
                      DWORD  ul_reason_for_call,
                      LPVOID lpReserved) {
        switch (ul_reason_for_call) {
    case DLL_PROCESS_ATTACH:
      OutputDebugString(L"\nwdg - DLL_PROCESS_ATTACH\n");
          RETAILMSG(1,(TEXT("wdg - DLL_PROCESS_ATTACH\n")));
                   break;
    case DLL_PROCESS_DETACH:
           //RETAILMSG(1,(TEXT("LED - DLL_PROCESS_DETACH\n")));
          //OutputDebugString(L"LED - DLL_PROCESS_DETACH\n");
                        break;
    case DLL_THREAD_ATTACH:
           //RETAILMSG(1,(TEXT("LED - DLL_THREAD_ATTACH\n")));
      //OutputDebugString(L"LED - DLL_THREAD_ATTACH\n");
                        break;
    case DLL_THREAD_DETACH:
           //RETAILMSG(1,(TEXT("LED - DLL_THREAD_DETACH\n")));
      //OutputDebugString(L"LED - DLL_THREAD_DETACH\n");
                        break;
    default:
                        break;
        return TRUE;
//        wdg initial        //
DWORD wdg_Init(LPCTSTR pContext, LPCVOID lpvBusContext) {
//Virtual address mapping
        v_pIOPregs = (volatile S3C6410_GPIO_REG*)DrvLib_MapIoSpace(S3C6410_BASE_REG_PA_GPIO,
        sizeof(S3C6410_GPIO_REG),
        FALSE);
        v_pWDGregs = (volatile S3C6410_WATCHDOG_REG*)DrvLib_MapIoSpace(S3C6410_BASE_REG_PA_WATCHDOG,
                sizeof(S3C6410_WATCHDOG_REG),
                FALSE);
        OutputDebugString(L"wdg - wdg init sucseced\n");
        return 1;
//        wdg deinit        //
BOOL wdg_Deinit(DWORD hDeviceContext) {
        VirtualFree((PVOID)v_pIOPregs, 0, MEM_RELEASE);
        v_pIOPregs = NULL;
        return TRUE;
//        wdg open        //
DWORD wdg_Open(DWORD hDeviceContext, DWORD AccessCode, DWORD ShareMode) {
        v_pWDGregs->WTCNT = 0x4000; //4s的倒计时,如果不喂狗,则重新启动
        v_pWDGregs->WTDAT=0xffff;
         v_pWDGregs->WTCON = WTCON_PRESCALE(WD_PRESCALER) | WTCON_ENABLE | WTCON_CLK_DIV128 | WTCON_RESET;
        v_pWDGregs->WTCON =0x8039;
        OutputDebugString(L"wdg - wdg Open\n");
        return 1;
//        wdg close        //
BOOL wdg_Close(DWORD hOpenContext) {
        OutputDebugString(L"wdg - wdg Close\n");
        return TRUE;
//        wdg read        //
DWORD wdg_Read(DWORD hOpenContext, LPVOID pBuffer, DWORD Count) {
        return 1;
//        wdg write        //
DWORD wdg_Write(DWORD hOpenContext, LPCVOID pBuffer, DWORD Count) {
        return 1;
//        wdg power up        //
VOID wdg_PowerUp(DWORD hDeviceContext) {
//        wdg down        //
VOID wdg_PowerDown(DWORD hDeviceContext) {
//        wdg seek        //
DWORD wdg_Seek(DWORD hOpenContext, long Amount, DWORD Type) {
  return 0;
BOOL wdg_IOControl(DWORD Handle,
        DWORD dwIoControlCode,
        PBYTE pInBuf,
        DWORD nInBufSize,
        PBYTE pOutBuf,
        DWORD nOutBufSize,
        PDWORD pBytesReturned) {
switch (dwIoControlCode) {
    //case IOCTL_LED_LED1_OPEN:                                        //LED1 OPEN
                //v_pIOPregs->GPMCON&=(~(0x0f<<4));
                //v_pIOPregs->GPMCON|=0x1<<4;
                //v_pIOPregs->GPMDAT|=(0x01<<1);
                //break;
         case  IOCTL_wdg_wdg1_OPEN:
                 v_pWDGregs->WTCNT = WTCNT_CNT(0x4000);
                 break;
  return TRUE;
源码: Wdg.h
//        NAME OF SOURCE FILE: SPI.h        //
//        CONTENTS:        unipro CNC module.        //
//        NAME OF PROJECT FILE: uniprOS.exe        //
//        UTILIZING COMPILER: Visual Studio 2005        //
#ifndef LCD_H
#define LCD_H
// constants define
#define IOCTL_wdg_wdg1_OPEN                                  0x04002060
#define IOCTL_wdg_wdg1_CLOSE                                0x04002061
//#define IOCTL_LED_LED2_OPEN                                  0x04001070
//#define IOCTL_LED_LED2_CLOSE                                0x04001071
//#define IOCTL_LED_LED3_OPEN                                  0x04001080
//#define IOCTL_LED_LED3_CLOSE                                0x04001081
//#define IOCTL_LED_LED4_OPEN                                  0x04001090
//#define IOCTL_LED_LED4_CLOSE                                0x04001091
//#define IOCTL_LED_SET_OUTPUT                                                        0x04003060
//#define IOCTL_LED_SET_HIGH        0x04003070
//#define IOCTL_LED_SET_LOWER               0x04003080
#endif
