查看: 340|回复: 0
[经验] 高摆幅CMOS放大器
发表于 2022-11-23 15:27:40 | 显示全部楼层 |阅读模式
Abstract -A family of high-swing CMOS operational amplifiers has been developed to maximize the available dynamic range with low supply voltages. Complementary differential pairs are used to achieve an almost rail-to-rail input common-mode voltage range. High linearity is obtained by summing currents so that the small-signal differential-mode voltage gain is constant over the entire input common-mode voltage range.
00045006.pdf
325.61 KB, 下载次数: 0
GMT+8, 2024-11-23 15:46 , Processed in 0.111622 second(s), 16 queries , MemCache On.
