查看: 283|回复: 0
[经验] POR资料
发表于 2022-10-14 11:47:47 | 显示全部楼层 |阅读模式
The Power-ON reset, which is described here, is a part of the electronics of the Atlas Liquid Argon Calorimeter calibration circuit. A Power-ON Reset is a power supply supervisor which allows to generate a reset signal after a power supply level detection。
CIRCUIT DESIGN OF THE POR.pdf
556.9 KB, 下载次数: 2
GMT+8, 2024-11-24 03:12 , Processed in 0.107477 second(s), 16 queries , MemCache On.
