查看: 630|回复: 0
[经验] Current-Mirror OTA Design
发表于 2022-10-9 19:35:59 | 显示全部楼层 |阅读模式
A good paper for Current-Mirror OTA Design
Abstract—A low-voltage low-power CMOS operational transconductance amplifier (OTA) with near rail-to-rail output swing is presented in this brief. The proposed circuit is based on the current-mirror OTA topology. In addition, several circuit techniques are adopted to enhance the voltage gain. Simulated from a 0.8-V supply voltage, the proposed OTA achieves a 62-dB dc gain and a gain–bandwidth product of 160 MHz while driving a 2-pF load. The OTA is designed in a 0.18- m CMOS process. The power consumption is 0.25 mW including the common-mode feedback circuit.
Current-Mirror OTA Design.pdf
574.87 KB, 下载次数: 0
GMT+8, 2024-11-24 04:37 , Processed in 0.103382 second(s), 16 queries , MemCache On.
