查看: 301|回复: 0
[经验] Designing Rfic Cmos Mixer
发表于 2022-9-30 09:33:26 | 显示全部楼层 |阅读模式
Designing a mixer to work within a radio frequency integrated circuit (RFIC) is challenging. Differing performance specifications must be prioritized based on the application. Some specifications are for receive applications with a wide range of input signal levels where maximum linearity under large signal conditions is often more critical than the noise figure.
Designing An Rfic Cmos Upconversion Mixer.pdf
104.73 KB, 下载次数: 0
GMT+8, 2024-11-24 04:32 , Processed in 0.101297 second(s), 16 queries , MemCache On.
