产品描述:
Product Description:
USB数字电视接收器EZTV是专为USB OTG设计的用于Android的平板电脑或手机观看ISDB-T和DVB-T制式数字电视,把你的Android设备变为高质量的便携式数字电视接收机。超小体积的外观让您的出行方便和便携。让您享受无时无刻无处不在的数字电视直播娱乐。
Digital TV Receiver EZTV is a small size digital USB TV Stick with high sensitivity,designed for watching ISDB-T TV on Android Phone/Pad with USB OTG,It turns your Android Pad/Phone into a high quality portable digital TV receiver,The sleek and compact design makes your trip easy and fun. You may enjoy digital TV live stream entertainment whenever you like and wherever you go!
产品亮点:
Product Highlights:
1.可以在任何地方实时收看电视直播;
2.不需要网络连接和数据流量;
3.紧凑设计,便携式外观和低功耗高性能芯片;
4.具有实时观看、录播、暂停、快进、倒带功能;
5.天线可选择,配置高灵敏度天线;
6.支持大部分Andriod平板电脑或手机;
1,Watch live TV on your Android device anywhere you go
2,No internet connection required
3,Compact and portable design, power-saving chip technology
4,Rewind and Fast Forward live TV shows with Time shifting recording
5,Selectable antenna,With high sensitivity antenna
6,Support most Andriod tablet or mobile phone
产品特征:
Product features
1,真正的实时直播电视
先进的电视应用,不需要WIFI信号,无需要网络,无需要数据流量,用你的拉杆天线接收数字电视信号,通过USB OTG连接EZTV观看直播电视节目。
2,操作简单,功能可不简单
只需要下载APK应用程序到你的Andriod设备,连接数字电视接收器,启动应用程序并选择一个频道,就可以观看电视直播了;
3,支持电视节目指南(EPG)和支持高清电视接收
4,连接大屏幕
EZTV使您的平板电脑或手机体验更完美。如果您需要连接更大屏幕的电脑屏幕,只需通过USB线缆连接到您的计算机,然后在你的计算机上享受清晰的电视直播。你甚至可以录制下您喜欢的电视节目,
1,Real-time broadcast television really
Television the application of advanced, do not need the WIFI signal,without the need for network, without the need for data traffic, receive digital television signals with a rod antenna, watch live TV through USB OTG connection.
2,It couldn’t be simpler
Only need to download the APK application to your Andriod device,connect the digital television receiver, start the application andselection of a channel, you can watch live TV
3,Electronic Program Guide (EPG) and Supporting HDTV Receiving
4,Move it to the big screen.
EZTV make your tablet or mobile phone experience more perfect. If you need to connect the computer screen larger screen, simply connect to your computer via a USB cable, and then enjoy clear live television on your computer. You can even record your favorite TV programs
技术参数:
1,系统要求:
以下Android设备经验证支持EZTV:
Google:Galaxy Nexus,Nexus 7,Nexus 10
HTC:One X(Android 4.1.1 or later)
Samsung Galaxy:Note,NoteⅡ,SⅡ,Note Ⅲ
*EZTV要求具有1 GHz双核心CPU或更快的Android设备,
*支持USB主机模式的功能
*至少Android 4.0.3(“冰淇淋三明治”)或更高的版本。
*MPEG-4、H.264视频需要ARM处理器支持 NEON功能;
2,EZTV支持的地区:
EZTV支持工作在澳大利亚,比利时,法国,德国,英国,意大利,日本,奥地利,波兰,西班牙,瑞士以及任何国家广播标准清晰度MPEG-2或MPEG-4、H.264视频,同时还支持巴西、马尔代夫、秘鲁、阿根廷、智利、委内瑞拉、厄瓜多尔、巴拉圭、哥斯达黎加、玻利维亚、乌拉圭、洪都拉斯、危地马拉、尼加拉瓜、安哥拉、菲律宾、莫桑比克、萨尔瓦多等,支持高清频道,不支持加密程序和/或DVB-T2广播。
System Requirements:
These Android devices support EZTV :
Google : Galaxy Nexus, Nexus 7 (2012), Nexus 10
HTC : One X (Android 4.1.1 or later)
Samsung Galaxy: Note, Note II, S II, S III, S4
*EZTV requires an Android device with a 1 GHz or faster dual-core CPU,
*Requires the device supports USB host mode function
*The operating system is Android 4.0.3 (“Ice Cream Sandwich”) or later. required
*Playback of MPEG-4/H.264 video requires a processor with NEON support (e.g. Tegra3).
Where does EyeTV Micro work?
EZTV Micro works in Australia, Belgium, France, Germany, Great Britain, Italy, Japan, Austria, Poland, Spain, Switzerland,Also supports Brazil, Maldives, Peru, Argentina, Chile, Venezuela, Ecuador, Paraguay, Costa Rica, Bolivia, Uruguay, Honduras, Guatemala, Nicaragua, Angola, the Philippines, Mozambique, El Salvador,as well as any country that broadcasts standard definition MPEG-2 or MPEG-4/H.264 video. High definition channels, encrypted programs and/or DVB-T2 broadcasts are not supported.
2,技术规格:
DVB-T:
Frequency: 177.5 – 226.5MHz (VHF); 474 – 858MHz (UHF)
COFDM demodulator: Supports modulation schemes 16, 64QAM, QPSK; bandwidths 6, 7, 8MHz
ISDB-T:
Frequency: 470 – 862MHz (UHF)
BST-OFDM demodulator: Supports modulation schemes 64QAM, QPSK; bandwidth 6MHz
Antenna input: MCX
Dimensions: 30 × 20 × 8.6mm
Weight: 4g
Input Signal: 75 Ohm Digital TV Antenna Input
Technical Specifications:
DVB-T:
ISDB-T:
Antenna input: MCX
技术参数表:
技术参数表:Technical Specifications:
| DVB-T
| Frequency:
474 – 858MHz (UHF)
| COFDM demodulator:
| ISDB-T
| Frequency:
| 470 – 862MHz (UHF)
| COFDM demodulator:
| Antenna input:
| MCX
| Dimensions:
| 30 × 20 × 8.6mm
| Weight:
| 4g
| Input Signal:
| 系统要求:System Requirements
若需了解产品详情,欢迎联系谭生,电话18688839696,QQ:648316668
Http//www.eronsun.com,
