The AX88180 is a high-performance and cost-effective non-PCI Gigabit Ethernet controller for various embedded systems including consumer electronics and home network markets that require a higher bandwidth of network connectivity. The AX88180 supports 16/32-bit SRAM-like host interface and Gigabit Ethernet MAC, which is IEEE802.3 10Base-T, IEEE802.3u 100Base-T, and IEEE802.3ab 1000Base-T compatible. The AX88180 supports full-duplex or half-duplex operation at 10/100/1000Mbps speed with auto-negotiation or manual setting. The AX88180 integrates large embedded SRAM for packet buffering to accommodate high bandwidth applications and supports IP/TCP/UDP checksum in hardware to offload processing loading from microprocessor/microcontroller in an embedded system.
规格:
- High-performance non-PCI local bus
- 16/32-bit SRAM-like host interface (US Patent Approval)
- Support big/little endian data bus type
- Large embedded SRAM for packet buffers
- 32K bytes for receive buffer
- 8K bytes for transmit buffer
- Support IP/TCP/UDP checksum offloads
- Support interrupt with high or low active trigger mode
- Highly-integrated Gigabit Ethernet controller
- Compatible with IEEE802.3, 802.3u, and 802.3ab standards
- Support 10/100/1000Mbps data rate
- Support full duplex operations with 1000Mbps data rate
- Support full and half duplex operations with 10/100Mbps data rate
- Support 10/100/1000Mbps N-way Auto- negotiation operation
- Support 10/100/1000Mbps data rate with RGMII interface
- Support IEEE 802.3x flow control for full-duplex operation
- Support back-pressure flow control for half-duplex operation
- Support packet length set by software
- Support max 4K bytes JUMBO packet
- Support Wake-on-LAN function by following events
- Detection of a change in the network link state
- Receipt of a Magic Packet
- Support optional EEPROM interface
- Support system reference clock from 40MHz to 100MHz
- Integrated voltage regulator
- 3.3V power supply with 5V I/O tolerance
- 128-pin LQFP with CMOS process, RoHS package
- 电话:18664397572 黄先生
