Maxim
E4837LF
| A 3.3V, 12.8MHz ±0.28ppm TCXO designed to be compatible with Maxim chip sets. (DS3100; DS3102; DS3104; DS3105; DS3106).
Package 7x5 mm. Temperature range -20 to 70°C.
| E4496LF
| A 3.3V, 38.88MHz ±0.28ppm TCXO designed to be compatible with Maxim chip sets. (DS34T108,DS34T104, DS34T102, DS34T101, DS4S108, DS34S104, DS34S102, DS34S101).
Package DIL. Temperature range 0 to 70°C.
| E4497LF
Package DIL. Temperature range -40 to 85°C.
| E4889LF
| A 3.3V, 10.0MHz ±0.28ppm TCXO designed to be compatible with Maxim chip sets.
| E4890LF
| A 3.3V, 19.44MHz ±0.28ppm TCXO designed to be compatible with Maxim chip sets.
| E4950LF
Package 7x5 mm. Temperature range -40 to 85°C.
| (Stratum 3E)
| A 12.8MHz OCXO meeting Stratum 3E requirements, specifically designed to be compatible with Maxim chip sets. Temperature range 0 to +70°C.
| (Stratum 3E)
| A 12.8MHz OCXO meeting Stratum 3E requirements, specifically designed to be compatible with Maxim chip sets. Temperature range -40 to +85°C.
Semtech
E2747
(Stratum 3)
| Lead-free, RoHS compliant. Ceramic package 7x5 mm.
Built with Rakon's ASIC "luto" chip.
Suitable for GR-1244-CORE Stratum 3 & GR-253-CORE Stratum 3 applications. Temperature range -20 to 70°C.
| E3198
(Startum 3)
Suitable for GR-1244-CORE Stratum 3 & GR-253-CORE Stratum 3 applications. Temperature range -40 to 85°C.
| STP2206
(Stratum 3E)
| A 12.8MHz OCXO meeting Stratum 3E requirements, specifically designed to be compatible with Semtech chip sets. Operates over -20 to +75°C
| STP2207
(Stratum 3E)
| A 12.8MHz OCXO meeting Stratum 3 requirements, specifically designed to be compatible with Semtech chip sets. Operates over -40 to +85°C
| STP2208
(Stratum 3E)
| A 12.8MHz OCXO meeting Stratum 3E requirments, specifically designed to be compatible with Semtech chip sets. Operates over 0 to +70°C
| STP2270
(Stratum 3E, 3.3V)
| A 3.3V 12.8MHz OCXO meeting Stratum 3E requirments, specifically designed to be compatible with Semtech chip sets. Operates over 0 to +70°C
| E2799
(SONET Minimum Clock)
Capable of sub 1ppm over extended temperature range, with low power usage.
Zarlink
Oscillators for GR-253-CORE SMC (SONET minimum clock) & ITU G.813 Option 2 applications
E2801
| RoHS compliant (lead-free). Ceramic package 7x5x2 mm.
Built with Rakon’s ASIC “Pluto”. Suitable for GR-253-CORE SMC (SONET minimum clock) & ITU G.813 Option 2 applications
Oscillators for GR1244-CORE Stratum 3 & GR-253-CORE Stratum 3 applications
E2791
| RoHS compliant (lead-free). Ceramic package 7x5 mm.
Built with Rakon’s ASIC “Pluto”. Suitable for GR1244-CORE Stratum 3 & GR-253-CORE Stratum 3 applications. Temperature range -20 to 70°C.
| E2889
| RoHS compliant (lead-free). Built using Rakon’s ASIC “Pluto”. Suitable for GR1244-CORE Stratum 3 & GR-253-CORE Stratum 3 applications. Temperature range -5 to 80°C.
| E3179
| RoHS compliant (lead-free). Ceramic Package 7x5mm.
Built with Rakon’s ASIC “Pluto” . Suitable for GR1244-CORE Stratum 3 & GR-253-CORE Stratum 3 applications. Temperature range -5 to 80°C.
| E3199LF
Built with Rakon’s ASIC “Pluto” . Suitable for GR1244-CORE Stratum 3 & GR-253-CORE Stratum 3 applications. Temperature range -40 to 85°C.
| STP2629LF
| RoHS compliant (lead-free). Metal solder-sealed package 36x27mm.
Suitable for GR1244-CORE Stratum 3E & GR-253-CORE Stratum 3 applications. Temperature range -40 to 80°C.
Oscillators for ITU G.813 Option 1 are available upon application, please contact me
Jesse-wu@hotmail.com MT:13032180675 |
