发表于 2009-6-30 09:31:41
显示全部楼层
回复:wimax的ofdm,mimo仿真
引用第 3 楼 yuliang1012于2008-07-29 09:04:46发表:
wimax模块打不开
wimax
Warning: Loading model 'wimax' generated with a newer version (6.5) of Simulink.
Warning: wimax.mdl, line 4: block_diagram does not have a parameter named 'MdlSubVersion'.
Warning: wimax.mdl, line 445: This model contains objects of class 'hdlcoderui.hdlcc' that can not be instantiated. If you save this model, the information associated with these objects will be lost.
Segmentation violation detected at Tue Jul 29 17:05:24 2008
Configuration:
MATLAB Version: 7.0.0.19920 (R14)
Operating System: Microsoft Windows XP
Window System: Version 5.1 (Build 2600: Service Pack 2)
Processor ID: x86 Family 15 Model 6 Stepping 2, GenuineIntel
Virtual Machine: Java 1.4.2 with Sun Microsystems Inc. Java HotSpot(TM) Client VM
(mixed mode)
Default Charset: ibm-1386_P100-2002
求高手解答啊
是不是MATLAB/simulink版本低了~~ |
